- 28
贡献77
飞刀10 FD
注册时间2013-10-14
在线时间15 小时
ok6410A-256MDDR+nandflash 4G 的开发板,自己根据网上编译的linux3.2.53的内核,根据网上修改了arch/arm/mach-s3c64xx/mach-ok6410.c文件添加了nand结构和dm9000结构体相关的东西,编译也通过了,启动内核出现以下信息,用官方给的内核可以挂载成功说明nfs配置没问题,内核启动的信息真心看不懂,菜鸟一枚闷头搞了一周了,请求各位大神指点
SMDK6410 # tftp c0008000 uImage
Found DM9000 ID:90000a46 at address 18000300 !
DM9000 work in 16 bus width
bd->bi_entaddr: 00:40:5c:26:0a:5b
[eth_init]MAC:0:40:5c:26:a:5b:
TFTP from server 192.168.2.100; our IP address is 192.168.2.111
Filename 'uImage'.
Load address: 0xc0008000
Loading: T T T #################################################################
done
Bytes transferred = 2432872 (251f68 hex)
SMDK6410 # bootm c0008000
## Booting image at c0008000 ...
Image Name: Linux-3.2.53
Created: 2013-12-05 13:19:22 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2432808 Bytes = 2.3 MB
Load Address: 50008000
Entry Point: 50008000
Verifying Checksum ... OK
OK
Starting kernel ...
Linux version 3.2.53 (root@ubuntu) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #7 Thu Dec 5 21:18:57 CST 2013
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
CPU: found DTCM0 8k @ 00000000, not enabled
CPU: moved DTCM0 8k to fffe8000, enabled
CPU: found DTCM1 8k @ 00000000, not enabled
CPU: moved DTCM1 8k to fffea000, enabled
CPU: found ITCM0 8k @ 00000000, not enabled
CPU: moved ITCM0 8k to fffe0000, enabled
CPU: found ITCM1 8k @ 00000000, not enabled
CPU: moved ITCM1 8k to fffe2000, enabled
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: root=/dev/nfs nfsroot=192.168.2.100:/nfs/FileSystem-Yaffs2
ip=192.168.2.111:192.168.2.100:192.168.2.1:255.255.255.0:witech.com.cn:eth0:off console=ttySAC0,115200
Memory: 256MB = 256MB total
Memory: 254888k/254888k available, 7256k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
DTCM : 0xfffe8000 - 0xfffec000 ( 16 kB)
ITCM : 0xfffe0000 - 0xfffe4000 ( 16 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xd0800000 - 0xf6000000 ( 600 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0449d48 (4360 kB)
.init : 0xc044a000 - 0xc046e000 ( 144 kB)
.data : 0xc046e000 - 0xc049d3a0 ( 189 kB)
.bss : 0xc049e024 - 0xc04d4604 ( 218 kB)
NR_IRQS:246
VIC @f6000000: id 0x00041192, vendor 0x41
VIC @f6010000: id 0x00041192, vendor 0x41
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
PL080: IRQ 73, at d0804000, channels 0..8
PL080: IRQ 74, at d0806000, channels 8..16
bio: create slab <bio-0> at 0
s3c-i2c s3c2440-i2c.1: slave address 0x10
s3c-i2c s3c2440-i2c.1: bus frequency set to 64 KHz
s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter
TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
TCP reno registered
UDP hash table entries: 128 (order: 0, 6144 bytes)
UDP-Lite hash table entries: 128 (order: 0, 6144 bytes)
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
ROMFS MTD (C) 2007 Red Hat, Inc.
io scheduler noop registered
start plist test
end plist test
s3c-fb s3c-fb: window 0: fb
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 69) is a S3C6400/10
console [ttySAC0] enabled
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 70) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 71) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 72) is a S3C6400/10
brd: module loaded
loop: module loaded
dm9000 Ethernet Driver, V1.31
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
usbcore: registered new inte**ce driver rt73usb
s3c2410-ohci s3c2410-ohci: init err (00000000 0000)
ohci_hcd: can't start s3c24xx
s3c2410-ohci s3c2410-ohci: startup error -75
s3c2410-ohci s3c2410-ohci: USB bus 1 deregistered
s3c2410-ohci: probe of s3c2410-ohci failed with error -75
i2c /dev entries driver
mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
usbhid: USB HID core driver
TCP cubic registered
mmc0: mmc_rescan_try_freq: trying to init card at 300000 Hz
s3c-rtc s3c64xx-rtc: setting system clock to 2000-02-25 23:43:09 UTC (951522189)
mmc0: mmc_rescan_try_freq: trying to init card at 200000 Hz
mmc0: mmc_rescan_try_freq: trying to init card at 100000 Hz
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[<c0013b70>] (unwind_backtrace+0x0/0xf8) from [<c0338ff8>] (panic+0x58/0x1a0)
[<c0338ff8>] (panic+0x58/0x1a0) from [<c044ad50>] (mount_block_root+0x16c/0x224)
[<c044ad50>] (mount_block_root+0x16c/0x224) from [<c044ae88>] (mount_root+0x80/0x100)
[<c044ae88>] (mount_root+0x80/0x100) from [<c044b014>] (prepare_namespace+0x10c/0x1cc)
[<c044b014>] (prepare_namespace+0x10c/0x1cc) from [<c044a2a0>] (kernel_init+0xfc/0x140)
[<c044a2a0>] (kernel_init+0xfc/0x140) from [<c000ef7c>] (kernel_thread_exit+0x0/0x8)
