- 19
贡献23
飞刀0 FD
注册时间2012-10-31
在线时间5 小时
当插入U盘的时候出现下面 的提示信息应该是安装驱动成功了,但是我在对应的/dev下面没发现对应的sda4驱动名就没发挂载,请问如何解决,- # usb 1-1.2: USB disconnect, address 3
- usb 1-1.1: new full speed USB device using s3c2410-ohci and address 5
- usb 1-1.1: configuration #1 chosen from 1 choice
- scsi1 : SCSI emulation for USB Mass Storage devices
- usb 1-1.1: New USB device found, idVendor=0930, idProduct=6545
- usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
- usb 1-1.1: Product: DataTraveler G3
- usb 1-1.1: Manufacturer: Kingston
- usb 1-1.1: SerialNumber: 001372982B41EC2085D202EF
- scsi 1:0:0:0: Direct-Access Kingston DataTraveler G3 PMAP PQ: 0 ANSI: 0 CCS
- sd 1:0:0:0: [sda] 30481152 512-byte hardware sectors: (15.6 GB/14.5 GiB)
- sd 1:0:0:0: [sda] Write Protect is off
- sd 1:0:0:0: [sda] Assuming drive cache: write through
- sda: sda4
- sd 1:0:0:0: [sda] Attached SCSI removable disk
- sd 1:0:0:0: Attached scsi generic sg0 type 0
复制代码 |
