- 0
贡献0
飞刀0 FD
注册时间2015-12-16
在线时间0 小时
The IIS-BUS interface includes the following features:
• 2-ports stereo IIS bus for audio interface with DMA-based operation
• Serial, 8/16/24 bit per channel data transfers
• Supports sampling rate from 8kHz to 192kHz
• Supports IIS, MSB-justified and LSB-justified data format
• 64 Bytes Tx FIFO/64 Bytes Rx FIFO per each port |
