- 11
贡献30
飞刀0 FD
注册时间2014-5-29
在线时间2 小时
写了一个程序,在pc机的linux下可以读取图像。
但是交叉编译后却不能读取了。
显示select timeout 就是在select超时了。。。
怎么回事呢。。。。
当然我是改了设备文件的。
插入摄像头/dev目下了多了一个video2设备文件的。
附上源代码:
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
#include<assert.h>
#include<fcntl.h>
#include<unistd.h>
#include<errno.h>
#include<malloc.h>
#include<sys/stat.h>
#include<sys/types.h>
#include<sys/time.h>
#include<sys/mman.h>
#include<sys/ioctl.h>
#include<asm/types.h>
#include<linux/videodev2.h>
#define CLEAR(x) memset(&(x), 0, sizeof(x))
struct buffer
void *start;
size_t length;
static char *dev_name = "/dev/video2";
static int fd = -1;
struct buffer *buffers = NULL;
static unsigned int n_buffers = 0;
FILE *fp;
char *filename = "test.yuv\0";
static void open_device(void)
fd = open(dev_name, O_RDWR|O_NONBLOCK, 0);
if(-1 == fd)
perror("open");
exit(EXIT_FAILURE);
static void init_mmap(void)
struct v4l2_requestbuffers req;
CLEAR(req);
req.count = 4;
req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
req.memory = V4L2_MEMORY_MMAP;
if(-1 == ioctl(fd, VIDIOC_REQBUFS, &req))
if(EINVAL == errno)
fprintf(stderr, "%s does not support memory mapping\n", dev_name);
exit(EXIT_FAILURE);
else
perror("VIDIOC_REQBUFS");
exit(EXIT_FAILURE);
buffers = calloc(req.count, sizeof(*buffers));
if(!buffers)
fprintf(stderr, "Out of memory");
exit(EXIT_FAILURE);
for(n_buffers = 0; n_buffers < req.count; n_buffers++)
struct v4l2_buffer buf;
CLEAR(buf);
buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
buf.memory = V4L2_MEMORY_MMAP;
buf.index = n_buffers;
if(-1 == ioctl(fd, VIDIOC_QUERYBUF, &buf))
perror("VIDIOC_QUERYBUF");
exit(EXIT_FAILURE);
buffers[n_buffers].length = buf.length;
buffers[n_buffers].start = mmap(NULL, buf.length, PROT_READ|PROT_WRITE, MAP_SHARED, fd, buf.m.offset);
if(MAP_FAILED == buffers[n_buffers].start)
perror("mmap");
exit(EXIT_FAILURE);
static void init_device(void)
struct v4l2_capability cap;
struct v4l2_format fmt;
if(-1 == ioctl(fd, VIDIOC_QUERYCAP, &cap))
if(EINVAL == errno)
fprintf(stderr, "%s is no v4l2 device\n", dev_name);
exit(EXIT_FAILURE);
else
perror("VIDIOC_QUERYCAP");
exit(EXIT_FAILURE);
if(!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE))
fprintf(stderr, "%s is no video capture device\n", dev_name);
exit(EXIT_FAILURE);
if(!(cap.capabilities & V4L2_CAP_STREAMING))
fprintf(stderr, "%s does not support streaming i/o \n", dev_name);
exit(EXIT_FAILURE);
CLEAR(fmt);
fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
fmt.fmt.pix.width = 320;
fmt.fmt.pix.height = 240;
fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_YUYV;
fmt.fmt.pix.field = V4L2_FIELD_INTERLACED;
if(-1 == ioctl(fd, VIDIOC_S_FMT, &fmt))
perror("VIDIOC_S_FMT");
exit(EXIT_FAILURE);
init_mmap();
void start_capturing(void)
unsigned int i;
enum v4l2_buf_type type;
for(i = 0; i < n_buffers; i++)
CLEAR(buf);
buf.index = i;
if(-1 == ioctl(fd, VIDIOC_QBUF, &buf))
perror("VIDIOC_QBUF");
exit(EXIT_FAILURE);
if(-1 == ioctl(fd, VIDIOC_STREAMON, &type))
perror("VIDIOC_STREAMON");
exit(EXIT_FAILURE);
static void process_image(const void *p, int size)
fwrite(p, size, 1, fp);
static int read_frame(void)
unsigned int i;
CLEAR(buf);
if(-1 == ioctl(fd, VIDIOC_DQBUF, &buf))
switch(errno)
case EAGAIN:
return 0;
case EIO:
default:
perror("VIDIOC_DQBUF");
exit(EXIT_FAILURE);
process_image(buffers[buf.index].start, buf.length);
return 1;
void mainloop()
unsigned int count;
count = 1;
while(count-- > 0)
for(;;)
fd_set fds;
struct timeval tv;
int r;
FD_ZERO(&fds);
FD_SET(fd, &fds);
tv.tv_sec = 2;
tv.tv_usec = 0;
r = select(fd + 1, &fds, NULL, NULL, &tv);
if(-1 == r)
if(EINTR == errno)
continue;
perror("select");
exit(EXIT_FAILURE);
if(0 == r)
fprintf(stderr, "select timeout\n");
exit(EXIT_FAILURE);
if(read_frame())
break;
static void stop_capturing()
if(-1 == ioctl(fd, VIDIOC_STREAMOFF, &type))
perror("VIDIOC_STREAMOFF");
exit(EXIT_FAILURE);
static void uninit_device()
unsigned int i;
if(-1 == munmap(buffers[i].start, buffers[i].length))
perror("munmap");
exit(EXIT_FAILURE);
free(buffers);
static void close_device()
if(-1 == close(fd))
perror("close");
exit(EXIT_FAILURE);
fd = -1;
int main()
// dev_name = "/dev/video0";
open_device();
init_device();
start_capturing();
fp = fopen(filename, "wa+");
mainloop();
fclose(fp);
stop_capturing();
uninit_device();
close_device();
exit(EXIT_SUCCESS);
return 0;
