- 0
贡献0
飞刀0 FD
注册时间2015-12-16
在线时间0 小时
[System.Runtime.InteropServices.DllImport("kernel32", SetLastError = true)]
static extern unsafe System.IntPtr CreateFile
string FileName, // file name
uint DesiredAccess, // access mode
uint ShareMode, // share mode
uint SecurityAttributes, // Security Attributes
uint CreationDisposition, // how to create
uint FlagsAndAttributes, // file attributes
int hTemplateFile // handle to template file
static extern unsafe bool ReadFile
System.IntPtr hFile, // handle to file
void* pBuffer, // data buffer
int NumberOfBytesToRead, // number of bytes to read
int* pNumberOfBytesRead, // number of bytes read
int Overlapped // overlapped buffer
static extern unsafe bool CloseHandle
System.IntPtr hObject // handle to object
public bool Open(string FileName)
// open the existing file for reading
handle = CreateFile
FileName,
GENERIC_READ,
0,
0,
OPEN_EXISTING,
0,
if (handle != System.IntPtr.Zero)
return true;
else
return false;
public unsafe int Read(byte[] buffer, int index, int count)
int n = 0;
fixed (byte* p = buffer)
if (!ReadFile(handle, p + index, count, &n, 0))
return 0;
return n;
