- 101
贡献111
飞刀0 FD
注册时间2011-11-29
在线时间20 小时
root@sam:/home/sam/u-boot-2012.10# make all
/bin/bash: arm-linux-gcc: 未找到命令
dirname: 缺少操作数
请尝试执行"dirname --help"来获取更多信息。
/bin/bash: arm-linux-ld: 未找到命令
make: *** 没有规则可以创建“depend”需要的目标“include/autoconf.mk”。 停止。
root@sam:/home/sam/u-boot-2012.10# gedit Makefile
# set default to nothing for native builds
ifeq ($(HOSTARCH),$(ARCH))
CROSS_COMPILE ?= /usr/local/arm/4.3.2/bin/arm-linux- 这里有问题?????
endif
Auto-generate the autoconf.mk file (which is included by all makefiles)
# This target actually generates 2 files; autoconf.mk and autoconf.mk.dep.
# the dep file is only include in this top level makefile to determine when
# to regenerate the autoconf.mk file.
$(obj)include/autoconf.mk.dep: $(obj)include/config.h include/common.h 是不是这里出现了问题?怎么解决?
@$(XECHO) Generating $@ ; \
set -e ; \
: Generate the dependancies ; \
$(CC) -x c -DDO_DEPS_ONLY -M $(CFLAGS) $(CPPFLAGS) \
-MQ $(obj)include/autoconf.mk include/common.h > $@
$(obj)include/autoconf.mk: $(obj)include/config.h \
set -e ; \
: Extract the config macros ; \
$(CPP) $(CFLAGS) -DDO_DEPS_ONLY -dM include/common.h | \
sed -n -f tools/scripts/define2mk.sed > $@.tmp && \
mv $@.tmp $@
$(obj)include/generated/generic-asm-offsets.h: $(obj)include/autoconf.mk.dep \
$(obj)lib/asm-offsets.s
tools/scripts/make-asm-offsets $(obj)lib/asm-offsets.s $@
$(obj)lib/asm-offsets.s: $(obj)include/autoconf.mk.dep
$(src)lib/asm-offsets.c
@mkdir -p $(obj)lib
$(CC) -DDO_DEPS_ONLY \
$(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) \
-o $@ $(src)lib/asm-offsets.c -c -S
$(obj)include/generated/asm-offsets.h: $(obj)include/autoconf.mk.dep \
$(obj)$(CPUDIR)/$(SOC)/asm-offsets.s
tools/scripts/make-asm-offsets $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s $@
$(obj)$(CPUDIR)/$(SOC)/asm-offsets.s: $(obj)include/autoconf.mk.dep
@mkdir -p $(obj)$(CPUDIR)/$(SOC)
if [ -f $(src)$(CPUDIR)/$(SOC)/asm-offsets.c ];then \
-o $@ $(src)$(CPUDIR)/$(SOC)/asm-offsets.c -c -S; \
else \
touch $@; \
fi
请教下:哪里出错了? |
