查看: 14273|回复: 12
[Linux] OK335XS-II开发板执行reboot命令无法重启
霹雳游客 发表于 2014-7-12 17:41:17 | 显示全部楼层 |阅读模式
OK335XS-II开发板执行reboot命令无法重启,然后板子就一直死机在那,按复位按钮也没用,只能断电重启,请问这是不是飞凌的一个BUG 。求解答
[root@rootfs /]# umount: ramfs busy - remounted read-only
umount: var busy - remounted read-only
umount: tmpfs busy - remounted read-only
umount: devtmpfs busy - remounted read-only
The system is going down NOW!
Sent SIGTERM to all processes
[   33.374043] musb-hdrc musb-hdrc.0: remove, state 1
[   33.380124] usb usb2: USB disconnect, device number 1
[   33.392621] musb-hdrc musb-hdrc.0: USB bus 2 deregistered
Sent SIGKILL to all processes
Requesting syst[   35.371019] musb-hdrc musb-hdrc.1: remove, state 1
[   35.376093] usb usb1: USB disconnect, device number 1
[   35.382209] musb-hdrc musb-hdrc.1: USB bus 1 deregistered
[   35.388250] Restarting system.
楼主| 霹雳游客 发表于 2014-7-14 13:09:22 | 显示全部楼层
为什么没有人回复
楼主,输入reboot命令确实可以重启的。你应该是上午跟我联系的那个客户吧?  详情 回复 发表于 2014-7-14 13:46
飞凌-unix 发表于 2014-7-14 13:46:32 | 显示全部楼层
为什么没有人回复
楼主| 霹雳游客 发表于 2014-7-14 19:42:50 | 显示全部楼层
这个是用你上午发给我的demo镜像文件重新烧写程序到NAND的全部log信息。进入文件系统后执行reboot后系统还是直接死机,你说你可以重启,那你那边是不是在NAND启动的情况下、
U-Boot SPL 2011.09-00000-g98f151d (Jul 02 2014 - 13:47:21)
Texas Instruments Revision detection unimplemented
Booting from NAND...
MT29F2G08mkimage signature not found - ih_magic = ffffffff
Assuming u-boot.bin ..
Booting from MMC...
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00000-g98f151d (Jul 02 2014 - 13:47:21)
I2C:   ready
DRAM:  128 MiB
WARNING: Caches not enabled
Did not find a recognized configuration, assuming General purpose EVM in Profile 0 with Daughter board
NAND:  HW ECC BCH16 Selected
ONFI flash detected
ONFI param page 0 valid
HW ECC BCH8 Selected
Detect MT29F2G08
256 MiB
MMC:   OMAP SD/MMC: 0
391736 bytes read
---------------Begin update system to Nand---------------
NAND erase.chip: device 0 whole chip
100% complete
OK
reading MLO
100% complete
40423 bytes read
NAND write: device 0 offset 0x0, size 0x9de7
100% complete
40423 bytes written: OK
reading u-boot.img
100% complete
272192 bytes read
NAND write: device 0 offset 0x800000, size 0x42740
100% complete
272192 bytes written: OK
reading uImage
100% complete
3733056 bytes read
NAND write: device 0 offset 0xc00000, size 0x38f640
100% complete
3733056 bytes written: OK
reading ubi.img
100% complete
114294784 bytes read
NAND write: device 0 offset 0x1400000, size 0x6d00000
100% complete
114294784 bytes written: OK
100% complete
391736 bytes read
NAND write: device 0 offset 0x600000, size 0x5fa38
100% complete
391736 bytes written: OK
--------------Update system to Nand success--------------
MT29F2G08
I2C:   ready
DRAM:  128 MiB
ONFI flash detected
Detect MT29F2G08
256 MiB
MMC:   OMAP SD/MMC: 0
Video : Drawing the logo from nand.
NAND read: device 0 offset 0x600000, size 0x36
54 bytes read: OK
NAND read: device 0 offset 0x600000, size 0x5fa38
391736 bytes read: OK
Net:   cpsw
Booting from nand ...
NAND read: device 0 offset 0xc00000, size 0x500000
5242880 bytes read: OK
## Booting kernel from Legacy Image at 80200000 ...
   Image Name:   Linux-3.2.0
   Data Size:    3732992 Bytes = 3.6 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Linux version 3.2.0 (root@bear-forlinx) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #60 Fri Jun 27 11:21:26 CST 2014
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] Machine: am335xevm
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=7,2048 rootfstype=ubifs rootwait=1 screentype=R screensize=480x272-4
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 128MB = 128MB total
[    0.000000] Memory: 122108k/122108k available, 8964k reserved, 0K highmem
[    0.000000]     vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc06bc000   (6864 kB)
[    0.000000]       .init : 0xc06bc000 - 0xc06f9000   ( 244 kB)
[    0.000000]       .data : 0xc06fa000 - 0xc0769100   ( 445 kB)
[    0.000000]        .bss : 0xc0769124 - 0xc079d778   ( 210 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[    0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[    0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000191] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[    0.057162] pid_max: default: 32768 minimum: 301
[    0.057289] Security Framework initialized
[    0.057396] Mount-cache hash table entries: 512
[    0.057781] CPU: Testing write buffer coherency: ok
[    0.058543] devtmpfs: initialized
[    0.078527] omap_hwmod: pruss: failed to hardreset
[    0.079617] print_constraints: dummy:
[    0.079963] NET: Registered protocol family 16
[    0.082070] OMAP GPIO hardware version 0.1
[    0.084637] omap_mux_init: Add partition: #1: core, flags: 0
[    0.086433]  omap_i2c.1: alias fck already exists
[    0.087581]  omap_hsmmc.0: alias fck already exists
[    0.087843]  omap_hsmmc.1: alias fck already exists
[    0.088392]  da8xx_lcdc.0: alias fck already exists
[    0.088673]  omap_i2c.2: alias fck already exists
[    0.090138]  d_can.0: alias fck already exists
[    0.090392]  d_can.1: alias fck already exists
[    0.091888]  omap2_mcspi.1: alias fck already exists
[    0.092104]  omap2_mcspi.2: alias fck already exists
[    0.092372]  edma.0: alias fck already exists
[    0.092394]  edma.0: alias fck already exists
[    0.092413]  edma.0: alias fck already exists
[    0.128398] bio: create slab <bio-0> at 0
[    0.130641] SCSI subsystem initialized
[    0.132638] usbcore: registered new inte**ce driver usbfs
[    0.132962] usbcore: registered new inte**ce driver hub
[    0.133172] usbcore: registered new device driver usb
[    0.133485] registerd cppi-dma Intr @ IRQ 17
[    0.133500] Cppi41 Init Done Qmgr-base(c887a000) dma-base(c8878000)
[    0.133510] Cppi41 Init Done
[    0.133538] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.133832] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.147230] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.147915] tps65217 1-0024: Failed to read revision register: -121
[    0.147966] tps65217: probe of 1-0024 failed with error -121
[    0.167215] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    0.168926] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.169709] Bluetooth: Core ver 2.16
[    0.169883] NET: Registered protocol family 31
[    0.169896] Bluetooth: HCI device and connection manager initialized
[    0.169913] Bluetooth: HCI socket layer initialized
[    0.169924] Bluetooth: L2CAP socket layer initialized
[    0.169952] Bluetooth: SCO socket layer initialized
[    0.170534] cfg80211: Calling CRDA to update world regulatory domain
[    0.171731] Switching to clocksource gp timer
[    0.189692] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.189902] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.190227] MUSB0 controller's USBSS revision = 4ea20800
[    0.190261] musb0: Enabled SW babble control
[    0.191165] musb-hdrc musb-hdrc.0: USB OTG mode controller at c883e000 using DMA, IRQ 18
[    0.191326] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.191618] MUSB1 controller's USBSS revision = 4ea20800
[    0.191644] musb1: Enabled SW babble control
[    0.192145] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.192241] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.192380] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.192396] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.192409] usb usb1: Product: MUSB HDRC host driver
[    0.192420] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.192431] usb usb1: SerialNumber: musb-hdrc.1
[    0.193357] hub 1-0:1.0: USB hub found
[    0.193387] hub 1-0:1.0: 1 port detected
[    0.193986] musb-hdrc musb-hdrc.1: USB Host mode controller at c884a800 using DMA, IRQ 19
[    0.194415] NET: Registered protocol family 2
[    0.194606] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.194907] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.194996] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.195051] TCP: Hash tables configured (established 4096 bind 4096)
[    0.195064] TCP reno registered
[    0.195076] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.195099] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.195286] NET: Registered protocol family 1
[    0.195538] RPC: Registered named UNIX socket transport module.
[    0.195552] RPC: Registered udp transport module.
[    0.195560] RPC: Registered tcp transport module.
[    0.195569] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.195788] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.196019] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.202879] VFS: Disk quotas dquot_6.5.2
[    0.202947] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.203504] msgmni has been set to 238
[    0.206657] alg: No test for stdrng (krng)
[    0.206734] io scheduler noop registered
[    0.206745] io scheduler deadline registered
[    0.206851] io scheduler cfq registered (default)
[    0.209088] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-4.3-ATXI#-T-1 panel
[    0.215558] Console: switching to colour frame buffer device 60x34
[    0.220659] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.906651] console [ttyO0] enabled
[    0.911102] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.919059] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.926948] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    0.934834] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    0.942723] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    0.960822] brd: module loaded
[    0.969228] loop: module loaded
[    0.972987] i2c-core: driver [tsl2550] using legacy suspend method
[    0.979441] i2c-core: driver [tsl2550] using legacy resume method
[    0.986166] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.996811] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.004176] omap2-nand driver initializing
[    1.008521] info->phys_base 8000000
[    1.012441] ONFI flash detected
[    1.015858] ONFI param page 0 valid
[    1.019498] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
[    1.027854] omap2-nand: detected x8 NAND flash
[    1.032584] Page size 2048 Select ECC BCH8
[    1.036847] Nand ECC BCH8 HW
[    1.040063] Creating 8 MTD partitions on "omap2-nand.0":
[    1.045645] 0x000000000000-0x000000200000 : "SPL"
[    1.053122] 0x000000200000-0x000000400000 : "SPL.backup1"
[    1.060981] 0x000000400000-0x000000600000 : "SPL.backup2"
[    1.068836] 0x000000600000-0x000000800000 : "SPL.backup3"
[    1.076629] 0x000000800000-0x000000a00000 : "U-Boot"
[    1.083966] 0x000000a00000-0x000000c00000 : "U-Boot Env"
[    1.091635] 0x000000c00000-0x000001400000 : "Kernel"
[    1.101512] 0x000001400000-0x000010000000 : "File System"
[    1.206252] OneNAND driver initializing
[    1.211052] UBI: attaching mtd7 to ubi0
[    1.215097] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    1.221626] UBI: logical eraseblock size:    126976 bytes
[    1.227263] UBI: smallest flash I/O unit:    2048
[    1.232171] UBI: sub-page size:              512
[    1.236980] UBI: VID header offset:          2048 (aligned 2048)
[    1.243247] UBI: data offset:                4096
[    2.117343] UBI: max. sequence number:       0
[    2.142220] UBI: volume 0 ("rootfs") re-sized from 1652 to 1866 LEBs
[    2.149936] UBI: attached mtd7 to ubi0
[    2.153888] UBI: MTD device name:            "File System"
[    2.159603] UBI: MTD device size:            236 MiB
[    2.164786] UBI: number of good PEBs:        1888
[    2.169683] UBI: number of bad PEBs:         0
[    2.174319] UBI: number of corrupted PEBs:   0
[    2.178945] UBI: max. allowed volumes:       128
[    2.183763] UBI: wear-leveling threshold:    4096
[    2.188661] UBI: number of internal volumes: 1
[    2.193296] UBI: number of user volumes:     1
[    2.197924] UBI: available PEBs:             0
[    2.202558] UBI: total number of reserved PEBs: 1888
[    2.207728] UBI: number of PEBs reserved for bad PEB handling: 18
[    2.214086] UBI: max/mean erase counter: 1/0
[    2.218531] UBI: image sequence number:  1849104178
[    2.223701] UBI: background thread "ubi_bgt0d" started, PID 644
[    2.251949] CAN device driver inte**ce
[    2.255952] CAN bus driver for Bosch D_CAN controller 1.0
[    2.272446] d_can d_can.0: device registered (irq=52, irq_obj=53)
[    2.279510] d_can d_can.1: device registered (irq=55, irq_obj=56)
[    2.352406] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    2.358857] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[    2.382231] davinci_mdio.0: probed
[    2.385781] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[    2.402683] PPP generic driver version 2.4.2
[    2.412739] PPP BSD Compression module registered
[    2.417643] PPP Deflate Compression module registered
[    2.422929] RTL871X: module init start version:v4.1.7_9024.20130916
[    2.442392] RTL871X: module init ret=0
[    2.452497] usbcore: registered new inte**ce driver zd1201
[    2.472144] usbcore: registered new inte**ce driver cdc_ether
[    2.478399] usbcore: registered new inte**ce driver cdc_eem
[    2.492132] usbcore: registered new inte**ce driver dm9601
[    2.497990] cdc_ncm: 04-Aug-2011
[    2.512611] usbcore: registered new inte**ce driver cdc_ncm
[    2.518511] Initializing USB Mass Storage driver...
[    2.532356] usbcore: registered new inte**ce driver usb-storage
[    2.538616] USB Mass Storage support registered.
[    2.562537] usbcore: registered new inte**ce driver usbserial
[    2.568760] USB Serial support registered for generic
[    2.581879] usbcore: registered new inte**ce driver usbserial_generic
[    2.588682] usbserial: USB Serial Driver core
[    2.601873] USB Serial support registered for GSM modem (1-port)
[    2.612682] usbcore: registered new inte**ce driver option
[    2.618492] option: v0.7.2:USB Driver for GSM modems
[    2.642591]  gadget: Mass Storage Function, version: 2009/09/11
[    2.648765]  gadget: Number of LUNs=1
[    2.652595]  lun0: LUN: removable file: (no medium)
[    2.657704]  gadget: Mass Storage Gadget, version: 2009/09/11
[    2.663711]  gadget: userspace failed to provide iSerialNumber
[    2.669798]  gadget: g_mass_storage ready
[    2.674000] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    2.679595] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    2.687435] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.694533] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.702080] usb usb2: Product: MUSB HDRC host driver
[    2.707253] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[    2.712798] usb usb2: SerialNumber: musb-hdrc.0
[    2.732959] hub 2-0:1.0: USB hub found
[    2.736887] hub 2-0:1.0: 1 port detected
[    2.753338] mousedev: PS/2 mouse device common for all mice
[    2.772644] [wds tsc probe]x.min=140,x.max=3946,y.min=319,y.max=3865,x.inverted=0,y.inverted=1
[    2.782067] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[    2.821971] rtc-ds1307 2-0068: rtc core: registered ds1307 as rtc0
[    2.828437] rtc-ds1307 2-0068: 56 bytes nvram
[    2.842620] i2c /dev entries driver
[    2.852124] Linux video capture inte**ce: v2.00
[    2.862441] usbcore: registered new inte**ce driver uvcvideo
[    2.868431] USB Video Class driver (1.1.1)
[    2.882227] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    2.892125] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[    2.912328] usbcore: registered new inte**ce driver bcm203x
[    2.918233] Bluetooth: Generic Bluetooth USB driver ver 0.6
[    2.931906] usbcore: registered new inte**ce driver btusb
[    2.937715] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[    2.962629] cpuidle: using governor ladder
[    2.981869] cpuidle: using governor menu
[    3.045060] usbcore: registered new inte**ce driver usbhid
[    3.050884] usbhid: USB HID core driver
[    3.062560] tiadc tiadc: attached adc driver
[    3.092488] ALSA device list:
[    3.095585]   No soundcards found.
[    3.099125] oprofile: hardware counters not available
[    3.104421] oprofile: using timer interrupt.
[    3.108897] nf_conntrack version 0.5.0 (1907 buckets, 7628 max)
[    3.115550] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.121214] TCP cubic registered
[    3.124611] NET: Registered protocol family 17
[    3.129253] can: controller area network core (rev 20090105 abi 8)
[    3.135791] NET: Registered protocol family 29
[    3.140465] can: raw protocol (rev 20090105)
[    3.144925] can: broadcast manager protocol (rev 20090105 t)
[    3.158922] Bluetooth: RFCOMM TTY layer initialized
[    3.164050] Bluetooth: RFCOMM socket layer initialized
[    3.169403] Bluetooth: RFCOMM ver 1.11
[    3.173323] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.178857] Bluetooth: BNEP filters: protocol multicast
[    3.184310] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    3.193636] Registering the dns_resolver key type
[    3.198636] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    3.206656] ThumbEE CPU extension supported.
[    3.211171] mux: Failed to setup hwmod io irq -22
[    3.216781] Power Management for AM33XX family
[    3.221653] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    3.228339] Copied the M3 firmware to UMEM
[    3.232694] Cortex M3 Firmware Version = 0x181
[    3.256367] clock: disabling unused clocks to save power
[    3.273537] Detected MACID=d0:39:72:17:b6:60
[    3.279154] cpsw: Detected MACID = d0:39:72:17:b6:62
[    3.302574] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    3.312154] mmc0: host does not support reading read-only switch. assuming write-enable.
[    3.322655] rtc-ds1307 2-0068: setting system clock to 2014-07-14 19:39:09 UTC (1405366749)
[    3.342624] mmc0: new high speed SDHC card at address 1234
[    3.372661] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    3.384506]  mmcblk0: p1 p2
[    3.483317] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    3.489595] UBIFS: file system size:   235540480 bytes (230020 KiB, 224 MiB, 1855 LEBs)
[    3.497965] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[    3.505617] UBIFS: media format:       w4/r0 (latest is w4/r0)
[    3.511693] UBIFS: default compressor: lzo
[    3.515972] UBIFS: reserved for root:  0 bytes (0 KiB)
[    3.523197] VFS: Mounted root (ubifs filesystem) on device 0:14.
[    3.531549] devtmpfs: mounted
[    3.535036] Freeing init memory: 244K
INIT: version 2.88 booting
Starting udev
[    4.392336] udev[787]: starting version 164
[    6.965571] kjournald starting.  Commit interval 5 seconds
[    7.610590] EXT3-fs (mmcblk0p2): using internal journal
[    7.616096] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
Configuring network inte**ces... [    8.186578] net eth0: CPSW phy found : id is : 0x20005c90
done.
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting inetd daemon.
Starting syslogd/klogd: done
xres = 480, yres = 272
Took 4 samples...
Top left : X =  614 Y = 3389
Took 9 samples...
Top right : X = 3572 Y = 3353
Took 14 samples...
Bot right : X = 3449 Y = 1073
Took 2 samples...
Bot left : X =  625 Y = 1054
Took 7 samples...
Center : X = 2049 Y = 2238
-23.868286 0.131358 -0.003136
302.026123 -0.000238 -0.074519
Calibration constants: -1564232 8608 -205 19793584 -15 -4883 65536
2014-07-14 19:39:24: (log.c.166) server started
Stopping Bootlog daemon: bootlogd.
_____   _____   _____    _       _   __   _  __    __
|  ___| /  _   |  _    | |     | | |   | |    / /
| |__   | | | | | |_| |  | |     | | |   | |   / /
|  __|  | | | | |  _  /  | |     | | | |   |   }  {
| |     | |_| | | |    | |___  | | | |   |  / /
|_|     _____/ |_|  _ |_____| |_| |_|  _| /_/  _
ok335x login: root
root@ok335x:~# cd /
root@ok335x:/# ls
bin      etc      home     media    opt      sbin     sys      usr
dev      forlinx  lib      mnt      proc     srv      tmp      var
root@ok335x:/# ls
root@ok335x:/# ls
root@ok335x:/# ls
root@ok335x:/# mkdir renbj
root@ok335x:/# ls
bin      etc      home     media    opt      renbj    srv      tmp      var
dev      forlinx  lib      mnt      proc     sbin     sys      usr
root@ok335x:/# rm -rf renbj/
root@ok335x:/# ls
root@ok335x:/# reboot
Broadcast message from root@ok335x (ttyO0) (Mon Ju7"&#189;Y1 for reboot NOW!
INIT: Sending processes the TERM signal
INIT: Sending processes the KILL signal
Stopping telnet daemon.
Stopping system message bus: Stopping syslogd/klogd: stopped syslogd (pid 1309)
stopped klogd (pid 1310)
done
Stopping thttpd.
Deconfiguring network inte**ces... done.
Sending all processes the TERM signal...
Sending all processes the KILL signal...
Unmounting remote filesystems...
Deactivating swap...
Unmounting local filesystems...
Rebooting... [   51.698229] musb-hdrc musb-hdrc.1: remove, state 1
[   51.703314] usb usb1: USB disconnect, device number 1
[   51.709342] musb-hdrc musb-hdrc.1: USB bus 1 deregistered
[   51.715311] Restarting system.
楼主| 霹雳游客 发表于 2014-7-14 21:20:02 | 显示全部楼层
这个是从NFS方式启动的,也是执行reboot就死机
MT29F2G08
I2C:   ready
DRAM:  128 MiB
ONFI flash detected
Detect MT29F2G08
256 MiB
MMC:   OMAP SD/MMC: 0
54 bytes read: OK
Net:   cpsw
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.30.155; our IP address is 192.168.30.8
Filename 'uImage'.
Load address: 0x80a00000
Loading: #################################################################
done
Bytes transferred = 3733056 (38f640 hex)
## Booting kernel from Legacy Image at 80a00000 ...
OK
Starting kernel ...
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/nfs nfsroot=192.168.30.10:/home/giant/test_nfs/,nolock rw ip=192.168.30.8:192.168.30.155:192.168.30.254:255.255.255.0::eth0:off
[    0.000193] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[    0.057292] Security Framework initialized
[    0.057399] Mount-cache hash table entries: 512
[    0.057784] CPU: Testing write buffer coherency: ok
[    0.058559] devtmpfs: initialized
[    0.078538] omap_hwmod: pruss: failed to hardreset
[    0.079645] print_constraints: dummy:
[    0.080001] NET: Registered protocol family 16
[    0.082109] OMAP GPIO hardware version 0.1
[    0.084672] omap_mux_init: Add partition: #1: core, flags: 0
[    0.086468]  omap_i2c.1: alias fck already exists
[    0.087603]  omap_hsmmc.0: alias fck already exists
[    0.087861]  omap_hsmmc.1: alias fck already exists
[    0.088410]  da8xx_lcdc.0: alias fck already exists
[    0.088694]  omap_i2c.2: alias fck already exists
[    0.090176]  d_can.0: alias fck already exists
[    0.090434]  d_can.1: alias fck already exists
[    0.091913]  omap2_mcspi.1: alias fck already exists
[    0.092136]  omap2_mcspi.2: alias fck already exists
[    0.092399]  edma.0: alias fck already exists
[    0.092420]  edma.0: alias fck already exists
[    0.092439]  edma.0: alias fck already exists
[    0.128437] bio: create slab <bio-0> at 0
[    0.130667] SCSI subsystem initialized
[    0.132656] usbcore: registered new inte**ce driver usbfs
[    0.132977] usbcore: registered new inte**ce driver hub
[    0.133185] usbcore: registered new device driver usb
[    0.133496] registerd cppi-dma Intr @ IRQ 17
[    0.133511] Cppi41 Init Done Qmgr-base(c887a000) dma-base(c8878000)
[    0.133521] Cppi41 Init Done
[    0.133551] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.133846] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.147228] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.147913] tps65217 1-0024: Failed to read revision register: -121
[    0.168948] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.169738] Bluetooth: Core ver 2.16
[    0.169919] NET: Registered protocol family 31
[    0.169932] Bluetooth: HCI device and connection manager initialized
[    0.169948] Bluetooth: HCI socket layer initialized
[    0.169959] Bluetooth: L2CAP socket layer initialized
[    0.169987] Bluetooth: SCO socket layer initialized
[    0.170570] cfg80211: Calling CRDA to update world regulatory domain
[    0.171774] Switching to clocksource gp timer
[    0.189780] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.189996] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.190327] MUSB0 controller's USBSS revision = 4ea20800
[    0.190362] musb0: Enabled SW babble control
[    0.191281] musb-hdrc musb-hdrc.0: USB OTG mode controller at c883e000 using DMA, IRQ 18
[    0.191444] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.191749] MUSB1 controller's USBSS revision = 4ea20800
[    0.191776] musb1: Enabled SW babble control
[    0.192280] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.192378] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.192517] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.192533] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.192547] usb usb1: Product: MUSB HDRC host driver
[    0.192557] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.192568] usb usb1: SerialNumber: musb-hdrc.1
[    0.193498] hub 1-0:1.0: USB hub found
[    0.193528] hub 1-0:1.0: 1 port detected
[    0.194121] musb-hdrc musb-hdrc.1: USB Host mode controller at c884a800 using DMA, IRQ 19
[    0.194555] NET: Registered protocol family 2
[    0.194745] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.195046] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.195134] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.195190] TCP: Hash tables configured (established 4096 bind 4096)
[    0.195203] TCP reno registered
[    0.195215] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.195239] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.195427] NET: Registered protocol family 1
[    0.195686] RPC: Registered named UNIX socket transport module.
[    0.195700] RPC: Registered udp transport module.
[    0.195709] RPC: Registered tcp transport module.
[    0.195717] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.195934] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.196167] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.203000] VFS: Disk quotas dquot_6.5.2
[    0.203068] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.203625] msgmni has been set to 238
[    0.206781] alg: No test for stdrng (krng)
[    0.206855] io scheduler noop registered
[    0.206866] io scheduler deadline registered
[    0.206972] io scheduler cfq registered (default)
[    0.209196] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-5.0-ATXI#-T-1 panel
[    0.219662] Console: switching to colour frame buffer device 100x30
[    0.226891] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.916641] console [ttyO0] enabled
[    0.921100] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.929068] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.936957] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    0.944851] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    0.952750] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    0.970807] brd: module loaded
[    0.979252] loop: module loaded
[    0.983024] i2c-core: driver [tsl2550] using legacy suspend method
[    0.989468] i2c-core: driver [tsl2550] using legacy resume method
[    0.996205] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.006830] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.014183] omap2-nand driver initializing
[    1.018526] info->phys_base 8000000
[    1.022442] ONFI flash detected
[    1.025856] ONFI param page 0 valid
[    1.029496] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
[    1.037851] omap2-nand: detected x8 NAND flash
[    1.042587] Page size 2048 Select ECC BCH8
[    1.046851] Nand ECC BCH8 HW
[    1.050190] Creating 8 MTD partitions on "omap2-nand.0":
[    1.055767] 0x000000000000-0x000000200000 : "SPL"
[    1.063120] 0x000000200000-0x000000400000 : "SPL.backup1"
[    1.070967] 0x000000400000-0x000000600000 : "SPL.backup2"
[    1.078832] 0x000000600000-0x000000800000 : "SPL.backup3"
[    1.086649] 0x000000800000-0x000000a00000 : "U-Boot"
[    1.093993] 0x000000a00000-0x000000c00000 : "U-Boot Env"
[    1.101645] 0x000000c00000-0x000001400000 : "Kernel"
[    1.111495] 0x000001400000-0x000010000000 : "File System"
[    1.216257] OneNAND driver initializing
[    1.222355] CAN device driver inte**ce
[    1.226358] CAN bus driver for Bosch D_CAN controller 1.0
[    1.232870] d_can d_can.0: device registered (irq=52, irq_obj=53)
[    1.239917] d_can d_can.1: device registered (irq=55, irq_obj=56)
[    1.291838] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    1.298286] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[    1.305509] davinci_mdio.0: probed
[    1.309059] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[    1.316619] PPP generic driver version 2.4.2
[    1.321527] PPP BSD Compression module registered
[    1.326453] PPP Deflate Compression module registered
[    1.331720] RTL871X: module init start version:v4.1.7_9024.20130916
[    1.338408] RTL871X: module init ret=0
[    1.342525] usbcore: registered new inte**ce driver zd1201
[    1.348540] usbcore: registered new inte**ce driver cdc_ether
[    1.354801] usbcore: registered new inte**ce driver cdc_eem
[    1.360862] usbcore: registered new inte**ce driver dm9601
[    1.366730] cdc_ncm: 04-Aug-2011
[    1.370255] usbcore: registered new inte**ce driver cdc_ncm
[    1.376172] Initializing USB Mass Storage driver...
[    1.381471] usbcore: registered new inte**ce driver usb-storage
[    1.387749] USB Mass Storage support registered.
[    1.392940] usbcore: registered new inte**ce driver usbserial
[    1.399168] USB Serial support registered for generic
[    1.404607] usbcore: registered new inte**ce driver usbserial_generic
[    1.411409] usbserial: USB Serial Driver core
[    1.416106] USB Serial support registered for GSM modem (1-port)
[    1.422659] usbcore: registered new inte**ce driver option
[    1.428473] option: v0.7.2:USB Driver for GSM modems
[    1.433849]  gadget: Mass Storage Function, version: 2009/09/11
[    1.440023]  gadget: Number of LUNs=1
[    1.443861]  lun0: LUN: removable file: (no medium)
[    1.448968]  gadget: Mass Storage Gadget, version: 2009/09/11
[    1.454974]  gadget: userspace failed to provide iSerialNumber
[    1.461063]  gadget: g_mass_storage ready
[    1.465264] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    1.470859] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    1.478693] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.485789] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.493325] usb usb2: Product: MUSB HDRC host driver
[    1.498500] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[    1.504042] usb usb2: SerialNumber: musb-hdrc.0
[    1.509666] hub 2-0:1.0: USB hub found
[    1.513641] hub 2-0:1.0: 1 port detected
[    1.518970] mousedev: PS/2 mouse device common for all mice
[    1.525467] [wds tsc probe]x.min=140,x.max=3946,y.min=319,y.max=3865,x.inverted=0,y.inverted=1
[    1.534865] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[    1.545851] rtc-ds1307 2-0068: rtc core: registered ds1307 as rtc0
[    1.552340] rtc-ds1307 2-0068: 56 bytes nvram
[    1.557056] i2c /dev entries driver
[    1.561393] Linux video capture inte**ce: v2.00
[    1.566582] usbcore: registered new inte**ce driver uvcvideo
[    1.572594] USB Video Class driver (1.1.1)
[    1.577826] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    1.584307] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[    1.590845] usbcore: registered new inte**ce driver bcm203x
[    1.596773] Bluetooth: Generic Bluetooth USB driver ver 0.6
[    1.602769] usbcore: registered new inte**ce driver btusb
[    1.608578] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[    1.617373] cpuidle: using governor ladder
[    1.622153] cpuidle: using governor menu
[    1.632974] usbcore: registered new inte**ce driver usbhid
[    1.638797] usbhid: USB HID core driver
[    1.643775] tiadc tiadc: attached adc driver
[    1.650358] ALSA device list:
[    1.653508]   No soundcards found.
[    1.657050] oprofile: hardware counters not available
[    1.662325] oprofile: using timer interrupt.
[    1.666801] nf_conntrack version 0.5.0 (1907 buckets, 7628 max)
[    1.673464] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.679136] TCP cubic registered
[    1.682528] NET: Registered protocol family 17
[    1.687170] can: controller area network core (rev 20090105 abi 8)
[    1.693721] NET: Registered protocol family 29
[    1.698395] can: raw protocol (rev 20090105)
[    1.702858] can: broadcast manager protocol (rev 20090105 t)
[    1.708925] Bluetooth: RFCOMM TTY layer initialized
[    1.714093] Bluetooth: RFCOMM socket layer initialized
[    1.719446] Bluetooth: RFCOMM ver 1.11
[    1.723369] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.728903] Bluetooth: BNEP filters: protocol multicast
[    1.734355] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    1.740961] Registering the dns_resolver key type
[    1.745965] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    1.753982] ThumbEE CPU extension supported.
[    1.758496] mux: Failed to setup hwmod io irq -22
[    1.764115] Power Management for AM33XX family
[    1.768978] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    1.775664] Copied the M3 firmware to UMEM
[    1.780021] Cortex M3 Firmware Version = 0x181
[    1.793060] clock: disabling unused clocks to save power
[    1.800881] Detected MACID=d0:39:72:17:b6:60
[    1.806627] cpsw: Detected MACID = d0:39:72:17:b6:62
[    1.816796] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    1.825630] rtc-ds1307 2-0068: setting system clock to 2014-07-14 21:14:50 UTC (1405372490)
[    1.838667] net eth0: CPSW phy found : id is : 0x20005c90
[    1.912543] mmc0: host does not support reading read-only switch. assuming write-enable.
[    1.923514] mmc0: new high speed SDHC card at address 1234
[    1.929871] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    1.936989]  mmcblk0: p1 p2
[    3.832474] PHY: 0:00 - Link is Up - 100/Full
[    3.862035] IP-Config: Complete:
[    3.865400]      device=eth0, addr=192.168.30.8, mask=255.255.255.0, gw=192.168.30.254,
[    3.873516]      host=192.168.30.8, domain=, nis-domain=(none),
[    3.879686]      bootserver=192.168.30.155, rootserver=192.168.30.10, rootpath=
[    3.901697] VFS: Mounted root (nfs filesystem) on device 0:15.
[    3.908753] devtmpfs: mounted
[    3.912249] Freeing init memory: 244K
Please press Enter to activate this console.
[root@rootfs /]# ls
Settings                mnt                     tmp
autostart               opt                     trash_monitor
bin                     proc                    usb
dev                     renbj                   usr
etc                     root                    var
home                    rootfs-ok.yaffs2        vehicle_gpio-driver.ko
lib                     sbin
linuxrc                 sys
root@ok335x:~# umount: ramfs busy - remounted read-only
[  155.106173] musb-hdrc musb-hdrc.0: remove, state 1
[  155.115225] usb usb2: USB disconnect, device number 1
[  155.131110] musb-hdrc musb-hdrc.0: USB bus 2 deregistered
Requesting syst[  157.103277] musb-hdrc musb-hdrc.1: remove, state 1
[  157.108310] usb usb1: USB disconnect, device number 1
[  157.114463] musb-hdrc musb-hdrc.1: USB bus 1 deregistered
[  157.120498] Restarting system.
楼主| 霹雳游客 发表于 2014-7-14 21:20:04 | 显示全部楼层
MT29F2G08
I2C:   ready
DRAM:  128 MiB
ONFI flash detected
Detect MT29F2G08
256 MiB
MMC:   OMAP SD/MMC: 0
54 bytes read: OK
Net:   cpsw
Using cpsw device
Filename 'uImage'.
done
OK
Starting kernel ...
[    0.057155] pid_max: default: 32768 minimum: 301
[    0.057284] Security Framework initialized
[    0.057390] Mount-cache hash table entries: 512
[    0.057783] CPU: Testing write buffer coherency: ok
[    0.058563] devtmpfs: initialized
[    0.078545] omap_hwmod: pruss: failed to hardreset
[    0.079638] print_constraints: dummy:
[    0.079986] NET: Registered protocol family 16
[    0.082102] OMAP GPIO hardware version 0.1
[    0.084664] omap_mux_init: Add partition: #1: core, flags: 0
[    0.086455]  omap_i2c.1: alias fck already exists
[    0.087586]  omap_hsmmc.0: alias fck already exists
[    0.087840]  omap_hsmmc.1: alias fck already exists
[    0.088376]  da8xx_lcdc.0: alias fck already exists
[    0.088658]  omap_i2c.2: alias fck already exists
[    0.090123]  d_can.0: alias fck already exists
[    0.090377]  d_can.1: alias fck already exists
[    0.091829]  omap2_mcspi.1: alias fck already exists
[    0.092051]  omap2_mcspi.2: alias fck already exists
[    0.092318]  edma.0: alias fck already exists
[    0.092339]  edma.0: alias fck already exists
[    0.092358]  edma.0: alias fck already exists
[    0.128360] bio: create slab <bio-0> at 0
[    0.130582] SCSI subsystem initialized
[    0.132580] usbcore: registered new inte**ce driver usbfs
[    0.132909] usbcore: registered new inte**ce driver hub
[    0.133111] usbcore: registered new device driver usb
[    0.133425] registerd cppi-dma Intr @ IRQ 17
[    0.133440] Cppi41 Init Done Qmgr-base(c887a000) dma-base(c8878000)
[    0.133450] Cppi41 Init Done
[    0.133480] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.133773] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.147222] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.147914] tps65217 1-0024: Failed to read revision register: -121
[    0.147967] tps65217: probe of 1-0024 failed with error -121
[    0.167210] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    0.168958] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.169749] Bluetooth: Core ver 2.16
[    0.169932] NET: Registered protocol family 31
[    0.169946] Bluetooth: HCI device and connection manager initialized
[    0.169962] Bluetooth: HCI socket layer initialized
[    0.169973] Bluetooth: L2CAP socket layer initialized
[    0.170000] Bluetooth: SCO socket layer initialized
[    0.170591] cfg80211: Calling CRDA to update world regulatory domain
[    0.171795] Switching to clocksource gp timer
[    0.189732] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.189940] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.190257] MUSB0 controller's USBSS revision = 4ea20800
[    0.190291] musb0: Enabled SW babble control
[    0.191206] musb-hdrc musb-hdrc.0: USB OTG mode controller at c883e000 using DMA, IRQ 18
[    0.191367] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.191668] MUSB1 controller's USBSS revision = 4ea20800
[    0.191695] musb1: Enabled SW babble control
[    0.192186] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.192284] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.192424] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.192439] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.192453] usb usb1: Product: MUSB HDRC host driver
[    0.192463] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.192474] usb usb1: SerialNumber: musb-hdrc.1
[    0.193402] hub 1-0:1.0: USB hub found
[    0.193434] hub 1-0:1.0: 1 port detected
[    0.194033] musb-hdrc musb-hdrc.1: USB Host mode controller at c884a800 using DMA, IRQ 19
[    0.194464] NET: Registered protocol family 2
[    0.194656] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.194965] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.195053] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.195109] TCP: Hash tables configured (established 4096 bind 4096)
[    0.195122] TCP reno registered
[    0.195134] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.195157] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.195342] NET: Registered protocol family 1
[    0.195604] RPC: Registered named UNIX socket transport module.
[    0.195618] RPC: Registered udp transport module.
[    0.195626] RPC: Registered tcp transport module.
[    0.195635] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.195847] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.196081] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.202937] VFS: Disk quotas dquot_6.5.2
[    0.203007] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.203568] msgmni has been set to 238
[    0.206723] alg: No test for stdrng (krng)
[    0.206793] io scheduler noop registered
[    0.206804] io scheduler deadline registered
[    0.206905] io scheduler cfq registered (default)
[    0.209157] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-5.0-ATXI#-T-1 panel
[    0.219615] Console: switching to colour frame buffer device 100x30
[    0.226838] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.916598] console [ttyO0] enabled
[    0.921044] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.929014] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.936905] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    0.944807] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    0.952696] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    0.970755] brd: module loaded
[    0.979176] loop: module loaded
[    0.982945] i2c-core: driver [tsl2550] using legacy suspend method
[    0.989391] i2c-core: driver [tsl2550] using legacy resume method
[    0.996133] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.006773] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.014136] omap2-nand driver initializing
[    1.018483] info->phys_base 8000000
[    1.022399] ONFI flash detected
[    1.025816] ONFI param page 0 valid
[    1.029455] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
[    1.037813] omap2-nand: detected x8 NAND flash
[    1.042550] Page size 2048 Select ECC BCH8
[    1.046815] Nand ECC BCH8 HW
[    1.050152] Creating 8 MTD partitions on "omap2-nand.0":
[    1.055735] 0x000000000000-0x000000200000 : "SPL"
[    1.063080] 0x000000200000-0x000000400000 : "SPL.backup1"
[    1.070946] 0x000000400000-0x000000600000 : "SPL.backup2"
[    1.078808] 0x000000600000-0x000000800000 : "SPL.backup3"
[    1.086608] 0x000000800000-0x000000a00000 : "U-Boot"
[    1.093957] 0x000000a00000-0x000000c00000 : "U-Boot Env"
[    1.101621] 0x000000c00000-0x000001400000 : "Kernel"
[    1.111494] 0x000001400000-0x000010000000 : "File System"
[    1.216250] OneNAND driver initializing
[    1.222348] CAN device driver inte**ce
[    1.226351] CAN bus driver for Bosch D_CAN controller 1.0
[    1.232864] d_can d_can.0: device registered (irq=52, irq_obj=53)
[    1.239908] d_can d_can.1: device registered (irq=55, irq_obj=56)
[    1.291856] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    1.298306] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[    1.305487] davinci_mdio.0: probed
[    1.309036] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[    1.316595] PPP generic driver version 2.4.2
[    1.321508] PPP BSD Compression module registered
[    1.326436] PPP Deflate Compression module registered
[    1.331705] RTL871X: module init start version:v4.1.7_9024.20130916
[    1.338388] RTL871X: module init ret=0
[    1.342501] usbcore: registered new inte**ce driver zd1201
[    1.348507] usbcore: registered new inte**ce driver cdc_ether
[    1.354767] usbcore: registered new inte**ce driver cdc_eem
[    1.360832] usbcore: registered new inte**ce driver dm9601
[    1.366702] cdc_ncm: 04-Aug-2011
[    1.370232] usbcore: registered new inte**ce driver cdc_ncm
[    1.376152] Initializing USB Mass Storage driver...
[    1.381461] usbcore: registered new inte**ce driver usb-storage
[    1.387741] USB Mass Storage support registered.
[    1.392931] usbcore: registered new inte**ce driver usbserial
[    1.399155] USB Serial support registered for generic
[    1.404593] usbcore: registered new inte**ce driver usbserial_generic
[    1.411396] usbserial: USB Serial Driver core
[    1.416094] USB Serial support registered for GSM modem (1-port)
[    1.422649] usbcore: registered new inte**ce driver option
[    1.428465] option: v0.7.2:USB Driver for GSM modems
[    1.433838]  gadget: Mass Storage Function, version: 2009/09/11
[    1.440011]  gadget: Number of LUNs=1
[    1.443848]  lun0: LUN: removable file: (no medium)
[    1.448957]  gadget: Mass Storage Gadget, version: 2009/09/11
[    1.454966]  gadget: userspace failed to provide iSerialNumber
[    1.461050]  gadget: g_mass_storage ready
[    1.465252] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    1.470845] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    1.478683] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.485781] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.493318] usb usb2: Product: MUSB HDRC host driver
[    1.498493] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[    1.504036] usb usb2: SerialNumber: musb-hdrc.0
[    1.509668] hub 2-0:1.0: USB hub found
[    1.518986] mousedev: PS/2 mouse device common for all mice
[    1.525482] [wds tsc probe]x.min=140,x.max=3946,y.min=319,y.max=3865,x.inverted=0,y.inverted=1
[    1.534883] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[    1.545901] rtc-ds1307 2-0068: rtc core: registered ds1307 as rtc0
[    1.552390] rtc-ds1307 2-0068: 56 bytes nvram
[    1.557105] i2c /dev entries driver
[    1.561444] Linux video capture inte**ce: v2.00
[    1.566634] usbcore: registered new inte**ce driver uvcvideo
[    1.572648] USB Video Class driver (1.1.1)
[    1.577887] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    1.584371] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[    1.590909] usbcore: registered new inte**ce driver bcm203x
[    1.596834] Bluetooth: Generic Bluetooth USB driver ver 0.6
[    1.602833] usbcore: registered new inte**ce driver btusb
[    1.608649] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[    1.617431] cpuidle: using governor ladder
[    1.622209] cpuidle: using governor menu
[    1.633027] usbcore: registered new inte**ce driver usbhid
[    1.638851] usbhid: USB HID core driver
[    1.643823] tiadc tiadc: attached adc driver
[    1.650425] ALSA device list:
[    1.653576]   No soundcards found.
[    1.657118] oprofile: hardware counters not available
[    1.662393] oprofile: using timer interrupt.
[    1.666869] nf_conntrack version 0.5.0 (1907 buckets, 7628 max)
[    1.673528] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.679192] TCP cubic registered
[    1.682587] NET: Registered protocol family 17
[    1.687228] can: controller area network core (rev 20090105 abi 8)
[    1.693782] NET: Registered protocol family 29
[    1.698456] can: raw protocol (rev 20090105)
[    1.702918] can: broadcast manager protocol (rev 20090105 t)
[    1.708987] Bluetooth: RFCOMM TTY layer initialized
[    1.714153] Bluetooth: RFCOMM socket layer initialized
[    1.719506] Bluetooth: RFCOMM ver 1.11
[    1.723427] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.728961] Bluetooth: BNEP filters: protocol multicast
[    1.734418] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    1.741026] Registering the dns_resolver key type
[    1.746041] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    1.754056] ThumbEE CPU extension supported.
[    1.758570] mux: Failed to setup hwmod io irq -22
[    1.764188] Power Management for AM33XX family
[    1.769049] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    1.775740] Copied the M3 firmware to UMEM
[    1.780100] Cortex M3 Firmware Version = 0x181
[    1.793127] clock: disabling unused clocks to save power
[    1.800940] Detected MACID=d0:39:72:17:b6:60
[    1.806695] cpsw: Detected MACID = d0:39:72:17:b6:62
[    1.816884] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    1.825718] rtc-ds1307 2-0068: setting system clock to 2014-07-14 21:27:43 UTC (1405373263)
[    1.838787] net eth0: CPSW phy found : id is : 0x20005c90
[    1.912784] mmc0: host does not support reading read-only switch. assuming write-enable.
[    1.923751] mmc0: new high speed SDHC card at address 1234
[    1.930110] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    1.937236]  mmcblk0: p1 p2
[    3.832530] PHY: 0:00 - Link is Up - 100/Full
[    3.862065] IP-Config: Complete:
[    3.865431]      device=eth0, addr=192.168.30.8, mask=255.255.255.0, gw=192.168.30.254,
[    3.873542]      host=192.168.30.8, domain=, nis-domain=(none),
[    3.879789]      bootserver=192.168.30.155, rootserver=192.168.30.10, rootpath=
[   18.962280] VFS: Mounted root (nfs filesystem) on device 0:15.
[   18.969441] devtmpfs: mounted
[   18.972943] Freeing init memory: 244K
Starting udev
[   19.737644] udev[784]: starting version 164
[   23.469116] kjournald starting.  Commit interval 5 seconds
[   23.485220] EXT3-fs (mmcblk0p2): using internal journal
[   23.490698] EXT3-fs (mmcblk0p2): recovery complete
[   23.495722] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
bootlogd.
NOT configuring network inte**ces: / is an NFS mount
ok335x login: root
root@ok335x:~# ls
Settings
root@ok335x:~# cd /
Broadcast message from root@ok335x (ttyO0) (Mon Jul 14 21:28:28 2014):
NOW!
INIT: Switching to runlevel: 6
INIT: SeStopping telnet daemon.
Stopping system message bus: Stopping syslogd/klogd: stopped syslogd (pid 1285)
stopped klogd (pid 1287)
done
Stopping thttpd.
NOT deconfiguring network inte**ces: / is an NFS mount
Rebooting... [   61.310884] musb-hdrc musb-hdrc.1: remove, state 1
[   61.315980] usb usb1: USB disconnect, device number 1
[   61.322047] musb-hdrc musb-hdrc.1: USB bus 1 deregistered
[   61.327992] Restarting system.
楼主| 霹雳游客 发表于 2014-7-14 21:30:47 | 显示全部楼层
是不是这个板子硬件的复位电路有问题?
我在NAND启动方式和NFS启动方式都有试过reboot和reset按键重启,确实没有问题,如果,您那里一直死机,您可以联系我们,建议您返修  详情 回复 发表于 2014-7-15 08:35
飞凌-unix 发表于 2014-7-15 08:35:41 | 显示全部楼层
是不是这个板子硬件的复位电路有问题?
楼主| 霹雳游客 发表于 2014-7-15 08:47:30 | 显示全部楼层
我在NAND启动方式和NFS启动方式都有试过reboot和reset按键重启,确实没有问题,如果,您那里一直死机,您 ...
http://bbs.witech.com.cn/thread-50806-1-1.html
你可以看看这个帖子,他出现的问题跟我一样,你们这批出的货是不是都是这个问题?
那个帖子我看到了,问一下,你的xS-II的版本号是多少?版本号就在核心板周围写着呐  详情 回复 发表于 2014-7-15 08:51
飞凌-unix 发表于 2014-7-15 08:51:01 | 显示全部楼层
你可以看看这个帖子,他出现的问题跟我一样,你们这批 ...
