查看: 18551|回复: 2
[Linux] ok335xs 自己自作u-boot MLO uImage 显示 nodevice avaliable
yulan 发表于 2014-8-7 14:03:26 | 显示全部楼层 |阅读模式
顶格的是正常启动正常烧写的读写信息,有一个空格的是自己烧写的信息,做了一个对比
U-Boot SPL 2011.09-00000-gb9a3506-dirty (Jan 20 2014 - 12:35:11)
Texas Instruments Revision detection unimplemented
Booting from MMC...
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
        U-Boot SPL 2011.09 (Aug 07 2014 - 09:58:16)
        Booting from MMC...
        OMAP SD/MMC: 0
        reading u-boot.img
        reading u-boot.img
U-Boot 2011.09-00000-gb9a3506-dirty (Jan 20 2014 - 12:35:11)
I2C:   ready
DRAM:  512 MiB
WARNING: Caches not enabled
Did not find a recognized configuration, assuming General purpose EVM in Profile 0 with Daughter board
NAND:  HW ECC Hamming Code selected
256 MiB
MMC:   OMAP SD/MMC: 0
        U-Boot 2011.09 (Aug 07 2014 - 09:58:16)
        I2C:   ready
        DRAM:  512 MiB
        No NAND device found!!!
        0 MiB
        MMC:   OMAP SD/MMC: 0
        *** Warning - readenv() failed, using default environment
---------------Begin update system to Nand---------------
NAND erase.chip: device 0 whole chip
100% complete
OK
reading MLO
100% complete
36135 bytes read
HW ECC BCH8 Selected
        no devices available
        reading MLO
        100% complete
        36111 bytes read
NAND write: device 0 offset 0x0, size 0x8d27
100% complete
36135 bytes written: OK
reading u-boot.img
100% complete
252456 bytes read
        reading u-boot.img
        100% complete
        252416 bytes read
NAND write: device 0 offset 0x80000, size 0x3da28
100% complete
252456 bytes written: OK
reading uImage
100% complete
3450480 bytes read
        reading uImage
        100% complete
        3450504 bytes read
NAND write: device 0 offset 0x280000, size 0x34a670
100% complete
3450480 bytes written: OK
reading ubi.img
100% complete
105775104 bytes read
SW ECC selected
        reading ubi.img
        100% complete
        SW ECC selected
NAND write: device 0 offset 0x780000, size 0x64e0000
100% complete
105775104 bytes written: OK
--------------Update system to Nand success--------------
飞凌-unix 发表于 2014-8-8 08:57:28 | 显示全部楼层
手动输入命令烧写系统也是这个问题吗?
楼主| yulan 发表于 2014-8-11 16:26:14 | 显示全部楼层
run update_nand   以及但不更新,即可解决问题
