- 242
贡献396
飞刀2 FD
注册时间2014-4-12
在线时间115 小时
- #include <stdio.h> /*标准输入输出定义*/
- #include <stdlib.h>
- #include <unistd.h> /*Unix标准函数定义*/
- #include <sys/types.h> /**/
- #include <sys/stat.h> /**/
- #include <fcntl.h> /*文件控制定义*/
- #include <termios.h> /*PPSIX终端控制定义*/
- #include <errno.h> /*错误号定义*/
- #include <getopt.h>
- #include <string.h>
- #define TITLE "485 TEST"
- #define FALSE 1
- #define TRUE 0
- #define RS485_SEND "echo 1 > /sys/class/misc/io_ctl/gpio_state"
- #define RS485_RECEIVE "echo 0 > /sys/class/misc/io_ctl/gpio_state"
- FILE *outfile;
- void print_usage();
- char buf[512] = {0};/* Recvice data buffer */
- char message[104] = {0};
- int fd = 0;
- static int hex = 0;
- int speed_arr[] = {
- B921600, B460800, B230400, B115200, B57600, B38400, B19200,
- B9600, B4800, B2400, B1200, B300,
- int name_arr[] = {
- 921600, 460800, 230400, 115200, 57600, 38400, 19200,
- 9600, 4800, 2400, 1200, 300,
- void shownInformation(void)
- printf("*********************************************\n");
- printf("\t %s \t\n", TITLE);
- printf("*********************************************\n\n");
- void set_speed(int fd, int speed)
- int i;
- int status;
- struct termios Opt;
- tcgetattr(fd, &Opt);
- cfmakeraw(&Opt);
- for ( i= 0; i < sizeof(speed_arr) / sizeof(int); i++) {
- if (speed == name_arr[i]){
- tcflush(fd, TCIOFLUSH);
- cfsetispeed(&Opt, speed_arr[i]);
- cfsetospeed(&Opt, speed_arr[i]);
- status = tcsetattr(fd, TCSANOW, &Opt);
- if (status != 0)
- perror("tcsetattr fd1");
- return;
- tcflush(fd,TCIOFLUSH);
- if (i == 12){
- printf("\tSorry, please set the correct baud rate!\n\n");
- print_usage(stderr, 1);
- *@brief 设置串口数据位,停止位和效验位
- *@param fd 类型 int 打开的串口文件句柄*
- *@param databits 类型 int 数据位 取值 为 7 或者8*
- *@param stopbits 类型 int 停止位 取值为 1 或者2*
- *@param parity 类型 int 效验类型 取值为N,E,O,,S
- int set_Parity(int fd,int databits,int stopbits,int parity)
- struct termios options;
- if ( tcgetattr( fd,&options) != 0) {
- perror("SetupSerial 1");
- return(FALSE);
- options.c_cflag &= ~CSIZE ;
- options.c_oflag = 0;
- switch (databits) /*设置数据位数*/ {
- case 7:
- options.c_cflag |= CS7;
- break;
- case 8:
- options.c_cflag |= CS8;
- break;
- default:
- fprintf(stderr,"Unsupported data size\n");
- return (FALSE);
- switch (parity) {
- case 'n':
- case 'N':
- options.c_cflag &= ~PARENB; /* Clear parity enable */
- options.c_iflag &= ~INPCK; /* Enable parity checking */
- break;
- case 'o':
- case 'O':
- options.c_cflag |= (PARODD | PARENB); /* 设置为奇效验*/
- options.c_iflag |= INPCK; /* Disnable parity checking */
- break;
- case 'e':
- case 'E':
- options.c_cflag |= PARENB; /* Enable parity */
- options.c_cflag &= ~PARODD; /* 转换为偶效验*/
- break;
- case 'S':
- case 's': /*as no parity*/
- options.c_cflag &= ~CSTOPB;
- break;
- default:
- fprintf(stderr,"Unsupported parity\n");
- return (FALSE);
- /* 设置停止位*/
- switch (stopbits) {
- case 1:
- break;
- case 2:
- options.c_cflag |= CSTOPB;
- break;
- default:
- fprintf(stderr,"Unsupported stop bits\n");
- return (FALSE);
- /* Set input parity option */
- if (parity != 'n')
- options.c_cc[VTIME] = 150; // 15 seconds
- options.c_cc[VMIN] = 0;
- options.c_lflag &= ~(ECHO | ICANON);
- tcflush(fd,TCIFLUSH); /* Update the options and do it NOW */
- if (tcsetattr(fd,TCSANOW,&options) != 0) {
- perror("SetupSerial 3");
- return (FALSE);
- return (TRUE);
- *@breif 打开串口
- int OpenDev(char *Dev)
- int fd = open( Dev, O_RDWR ); //| O_NOCTTY | O_NDELAY
- if (-1 == fd) { /*设置数据位数*/
- perror("Can't Open Serial Port");
- return -1;
- } else{
- return fd;
- /* The name of this program */
- const char * program_name;
- /* Prints usage information for this program to STREAM (typically
- * stdout or stderr), and exit the program with EXIT_CODE. Does not
- * return.
- void print_usage (FILE *stream, int exit_code)
- fprintf(stream, "Usage: %s option [ dev... ] \n", program_name);
- fprintf(stream,
- "\t-h --help Display this usage information.\n"
- "\t-d i --device The device ttyS[0-3] or ttyO[0-5]\n"
- "\t-b --baudrate Set the baud rate you can select\n"
- "\t [230400, 115200, 57600, 38400, 19200, 9600, 4800, 2400, 1200, 300]\n"
- "\t-s --string Write the device data\n"
- "\t-l --hexadecimal recv in hexadecimal");
- exit(exit_code);
- void *thread_receive_function(void *arg)
- unsigned int i = 0, j = 1,num_read;
- // outfile = fopen("./tmp","w+");
- tcflush(fd, TCIOFLUSH); //清空串口缓冲区数据
- while(1){
- num_read = read(fd, buf, sizeof(buf));
- if (num_read > 0){
- if(hex == 1)
- printf("sum = %4d num = %2d recv = ",j++,num_read);
- for(i = 0;i< num_read;i++)
- printf("%x",buf[i]);
- printf("\n");
- memset(buf,'\0',sizeof(buf));
- else
- // fprintf(outfile,"receive num = %d ",i++);
- buf[num_read] = '\n';
- // fwrite(buf,num_read,1,outfile);
- // fprintf(outfile,"%s","\n");
- printf("sum = %4d num = %2d recv = %s", j++,num_read, buf);
- memset(buf, '\0', sizeof(buf));
- void func_receive()
- int res;
- int stop;
- pthread_t a_thread;
- system(RS485_RECEIVE);
- usleep(100);
- res = pthread_create(&a_thread, NULL, thread_receive_function, NULL);
- if (res != 0){
- perror("Thread creation failed");
- exit(1);
- usleep(100);
- while (1){
- printf("Select 3 : Stop Receive\n");
- printf(">\n");
- scanf ("%d", &stop);
- getchar();
- if (stop == 3){
- /* fclose(outfile);*/
- res = pthread_cancel(a_thread);
- if (res != 0){
- perror("Thread cancelation failed");
- exit(1);
- break;
- }else{
- printf("Sorry! Please select [3] stop receive\n\n");
- void *thread_send_function(void *arg)
- unsigned int num_send = 0, j = 0;
- while (1){
- j = write(fd, message, strlen(message));
- num_send++;
- printf("sum = %4d num = %2d send = %s\n",num_send,j,message );
- sleep(1);
- void func_send()
- unsigned char len;
- int stop;
- int res;
- printf("\tPlease enter the information to be sent off!\n");
- system(RS485_SEND);//控制GPIO0_13引脚电平使485允许发送,禁止接收。
- usleep(100);
- while (1){
- memset (message, '\0', sizeof(message));
- scanf("%[^\n]", message);
- printf("message = %s\n", message);
- len = strlen(message);
- printf("len = %d\n", len);
- if (len > 0){
- res = pthread_create(&a_thread, NULL, thread_send_function, (void *)message);
- if (res != 0){
- exit(1);
- while (1){
- printf("Information is sent......\n");
- printf("Select 3 : Stop Send\n");
- printf(">");
- getchar();
- if (stop == 3){
- if (res != 0){
- exit(1);
- break;
- }else{
- printf("Sorry! Please select [3] stop send\n\n");
- break;
- }else{
- printf("Sorry you can not enter an empty message!\n\n");
- /*显示二级菜单*/
- void display_two_menu()
- int flag_num;
- while (1){
- printf("\nSelect 1 : Send a message\n");
- printf("Select 2 : Receive messages\n");
- printf(">");
- scanf("%d", &flag_num);
- getchar();
- switch (flag_num){
- case 1 :
- func_send();
- break;
- case 2 :
- func_receive();
- break;
- default :
- printf("\n\nSorry! Please select the number of 1 to 2...\n");
- void funct_select()
- display_two_menu();
- *@breif main()
- int main(int argc, char *argv[])
- int next_option, havearg = 0;
- char *device;
- int i=0,j=0;
- int nread; /* Read the counts of data */
- int speed = 0;
- char *xmit = "6"; /* Default send data */
- const char *const short_options = "lhd:s:b:";
- const struct option long_options[] = {
- { "help", 0, NULL, 'h'},
- { "device", 1, NULL, 'd'},
- { "string", 1, NULL, 's'},
- { "baudrate", 1, NULL, 'b'},
- {"hexadecimal",0,NULL,'l'},
- { NULL, 0, NULL, 0 }
- program_name = argv[0];
- do {
- next_option = getopt_long (argc, argv, short_options, long_options, NULL);
- switch (next_option) {
- case 'h':
- print_usage (stdout, 0);
- case 'd':
- device = optarg;
- havearg = 1;
- break;
- case 'b':
- speed = atoi(optarg);
- break;
- case 's':
- xmit = optarg;
- havearg = 1;
- break;
- case 'l':
- hex = 1;
- havearg = 1;
- break;
- case -1:
- if (havearg)
- break;
- case '?':
- print_usage (stderr, 1);
- default:
- abort ();
- }while(next_option != -1);
- sleep(1);
- fd = OpenDev(device);
- shownInformation();
- if (fd > 0) {
- set_speed(fd, speed);
- } else {
- fprintf(stderr, "Error opening %s: %s\n", device, strerror(errno));
- exit(1);
- if (set_Parity(fd,8,1,'N')== FALSE) {
- fprintf(stderr, "Set Parity Error\n");
- close(fd);
- exit(1);
- funct_select();
- close(fd);
- exit(0);
复制代码 |
