查看: 6970|回复: 2
[Android] OK335xD 无法使用SD卡刷机
煮酒 发表于 2014-10-3 13:13:22 | 显示全部楼层 |阅读模式
如题,
使用SD卡刷机的时候,串口输出CCCCCCCCC然后就无任何反应,
换了三张卡,结果一致,
另:自带的系统为Android 2.3, 完全启动需要三分钟,
附上串口信息:
U-Boot SPL 2011.09-00000-g35a1cc0-dirty (Jan 23 2014 - 16:50:26)
Texas Instruments Revision detection unimplemented
Booting from NAND...
U-Boot 2011.09-00000-g35a1cc0-dirty (Jan 23 2014 - 16:50:26)
I2C:   ready
DRAM:  512 MiB
WARNING: Caches not enabled
Did not find a recognized configuration, assuming General purpose EVM in Profile 0 with Daughter board
NAND:  HW ECC Hamming Code selected
256 MiB
MMC:   OMAP SD/MMC: 0
Net:   PHY reset timed out
cpsw
Hit any key to stop autoboot:  3  2  1  0
Booting from nand ...
HW ECC BCH8 Selected
NAND read: device 0 offset 0x280000, size 0x500000
5242880 bytes read: OK
## Booting kernel from Legacy Image at 80200000 ...
   Image Name:   Linux-3.2.0
   Data Size:    3955568 Bytes = 3.8 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Linux version 3.2.0 (root@bear-forlinx) (gcc version 4.4.0 (GCC) ) #2 Thu Jan 23 16:49:59 CST 2014
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] Machine: am335xevm
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: console=ttyO0,115200n8 earlyprintk androidboot.console=ttyO0 init=/init root=ubi0:rootfs rw ubi.mtd=7,2048 rootfstype=ubifs rootwait=1 screentype=C screensize=800x480-5
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 510344k/510344k available, 13944k reserved, 0K highmem
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0725000   (7284 kB)
[    0.000000]       .init : 0xc0725000 - 0xc0777000   ( 328 kB)
[    0.000000]       .data : 0xc0778000 - 0xc07dc670   ( 402 kB)
[    0.000000]        .bss : 0xc07dc694 - 0xc092fff0   (1359 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[    0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[    0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000220] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[    0.117103] pid_max: default: 32768 minimum: 301
[    0.117250] Security Framework initialized
[    0.117322] Mount-cache hash table entries: 512
[    0.117777] CPU: Testing write buffer coherency: ok
[    0.117854] ftrace: allocating 20290 entries in 60 pages
[    0.164495] devtmpfs: initialized
[    0.184648] omap_hwmod: pruss: failed to hardreset
[    0.185505] print_constraints: dummy:
[    0.185740] NET: Registered protocol family 16
[    0.186891] OMAP GPIO hardware version 0.1
[    0.188043] omap_mux_init: Add partition: #1: core, flags: 0
[    0.189175]  omap_i2c.1: alias fck already exists
[    0.189652]  omap_hsmmc.0: alias fck already exists
[    0.190410]  da8xx_lcdc.0: alias fck already exists
[    0.190568]  omap_i2c.2: alias fck already exists
[    0.191568]  d_can.0: alias fck already exists
[    0.191730]  davinci-mcasp.1: alias fck already exists
[    0.192265]  omap2_mcspi.1: alias fck already exists
[    0.192379]  omap2_mcspi.2: alias fck already exists
[    0.192555]  edma.0: alias fck already exists
[    0.192577]  edma.0: alias fck already exists
[    0.192597]  edma.0: alias fck already exists
[    0.202325] bio: create slab <bio-0> at 0
[    0.203391] SCSI subsystem initialized
[    0.204493] usbcore: registered new inte**ce driver usbfs
[    0.204630] usbcore: registered new inte**ce driver hub
[    0.204791] usbcore: registered new device driver usb
[    0.205104] registerd cppi-dma Intr @ IRQ 17
[    0.205119] Cppi41 Init Done Qmgr-base(e087a000) dma-base(e0878000)
[    0.205130] Cppi41 Init Done
[    0.205160] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.205316] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.205807] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.207330] tps65217 1-0024: TPS65217 ID 0xe version 1.2
[    0.209127] print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV
[    0.210945] print_constraints: DCDC2: 900 <--> 3300 mV at 1100 mV
[    0.212757] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV
[    0.214543] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[    0.216336] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[    0.218148] print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV
[    0.219972] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[    0.220543] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    0.221331] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.221928] Bluetooth: Core ver 2.16
[    0.221999] NET: Registered protocol family 31
[    0.222010] Bluetooth: HCI device and connection manager initialized
[    0.222026] Bluetooth: HCI socket layer initialized
[    0.222038] Bluetooth: L2CAP socket layer initialized
[    0.222072] Bluetooth: SCO socket layer initialized
[    0.222368] Switching to clocksource gp timer
[    0.244460] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.244687] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.244891] MUSB0 controller's USBSS revision = 4ea20800
[    0.244922] musb0: Enabled SW babble control
[    0.245764] musb-hdrc musb-hdrc.0: USB OTG mode controller at e083c000 using DMA, IRQ 18
[    0.246013] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.246166] MUSB1 controller's USBSS revision = 4ea20800
[    0.246191] musb1: Enabled SW babble control
[    0.246640] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.246741] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.246884] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.246900] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.246914] usb usb1: Product: MUSB HDRC host driver
[    0.246925] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.246936] usb usb1: SerialNumber: musb-hdrc.1
[    0.247637] hub 1-0:1.0: USB hub found
[    0.247669] hub 1-0:1.0: 1 port detected
[    0.248163] musb-hdrc musb-hdrc.1: USB Host mode controller at e083e800 using DMA, IRQ 19
[    0.248539] NET: Registered protocol family 2
[    0.248763] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.249171] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.249469] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    0.249645] TCP: Hash tables configured (established 16384 bind 16384)
[    0.249659] TCP reno registered
[    0.249672] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.249696] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.249896] NET: Registered protocol family 1
[    0.250149] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.250377] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.250397] Registering NAND on CS0
[    0.372350] ashmem: initialized
[    0.372706] VFS: Disk quotas dquot_6.5.2
[    0.372763] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.373389] fuse init (API version 7.17)
[    0.373702] msgmni has been set to 996
[    0.374818] io scheduler noop registered
[    0.374832] io scheduler deadline registered
[    0.374895] io scheduler cfq registered (default)
[    0.378149] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-5.0-ATXI#-T-1 panel
[    0.388205] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    1.087788] console [ttyO0] enabled
[    1.091992] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    1.099848] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    1.107649] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    1.115457] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    1.123261] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    1.131312] [drm] Initialized drm 1.1.0 20060810
[    1.142896] brd: module loaded
[    1.149621] loop: module loaded
[    1.153411] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.162215] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.169304] omap2-nand driver initializing
[    1.173949] ONFI flash detected
[    1.177350] ONFI param page 0 valid
[    1.180992] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
[    1.189908] Creating 8 MTD partitions on "omap2-nand.0":
[    1.195494] 0x000000000000-0x000000020000 : "SPL"
[    1.201674] 0x000000020000-0x000000040000 : "SPL.backup1"
[    1.208336] 0x000000040000-0x000000060000 : "SPL.backup2"
[    1.214962] 0x000000060000-0x000000080000 : "SPL.backup3"
[    1.221558] 0x000000080000-0x000000260000 : "U-Boot"
[    1.228526] 0x000000260000-0x000000280000 : "U-Boot Env"
[    1.235105] 0x000000280000-0x000000780000 : "Kernel"
[    1.243429] 0x000000780000-0x000010000000 : "File System"
[    1.354502] UBI: attaching mtd7 to ubi0
[    1.358515] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    1.365089] UBI: logical eraseblock size:    126976 bytes
[    1.370720] UBI: smallest flash I/O unit:    2048
[    1.375630] UBI: sub-page size:              512
[    1.380442] UBI: VID header offset:          2048 (aligned 2048)
[    1.386709] UBI: data offset:                4096
[    2.040711] UBI: max. sequence number:       697
[    2.060643] UBI: attached mtd7 to ubi0
[    2.064626] UBI: MTD device name:            "File System"
[    2.070341] UBI: MTD device size:            248 MiB
[    2.075523] UBI: number of good PEBs:        1988
[    2.080425] UBI: number of bad PEBs:         0
[    2.085075] UBI: number of corrupted PEBs:   0
[    2.089702] UBI: max. allowed volumes:       128
[    2.094524] UBI: wear-leveling threshold:    4096
[    2.099424] UBI: number of internal volumes: 1
[    2.104060] UBI: number of user volumes:     1
[    2.108691] UBI: available PEBs:             0
[    2.113328] UBI: total number of reserved PEBs: 1988
[    2.118498] UBI: number of PEBs reserved for bad PEB handling: 19
[    2.124858] UBI: max/mean erase counter: 2/0
[    2.129305] UBI: image sequence number:  475475445
[    2.134642] UBI: background thread "ubi_bgt0d" started, PID 49
[    2.141178] CAN device driver inte**ce
[    2.145216] CAN bus driver for Bosch D_CAN controller 1.0
[    2.151593] d_can d_can.0: device registered (irq=52, irq_obj=53)
[    2.202441] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    2.208892] davinci_mdio davinci_mdio.0: no live phy, scanning all
[    2.215546] davinci_mdio: probe of davinci_mdio.0 failed with error -5
[    2.222432] PPP generic driver version 2.4.2
[    2.227154] PPP BSD Compression module registered
[    2.232064] PPP Deflate Compression module registered
[    2.237468] usbcore: registered new inte**ce driver cdc_ether
[    2.243625] usbcore: registered new inte**ce driver cdc_eem
[    2.249574] usbcore: registered new inte**ce driver dm9601
[    2.255455] usbcore: registered new inte**ce driver cdc_subset
[    2.261671] cdc_ncm: 04-Aug-2011
[    2.265103] usbcore: registered new inte**ce driver cdc_ncm
[    2.271104] usbcore: registered new inte**ce driver cdc_acm
[    2.277023] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.285375] Initializing USB Mass Storage driver...
[    2.290579] usbcore: registered new inte**ce driver usb-storage
[    2.296852] USB Mass Storage support registered.
[    2.301828] usbcore: registered new inte**ce driver usbserial
[    2.307974] USB Serial support registered for generic
[    2.313312] usbcore: registered new inte**ce driver usbserial_generic
[    2.320119] usbserial: USB Serial Driver core
[    2.324720] USB Serial support registered for GSM modem (1-port)
[    2.331140] usbcore: registered new inte**ce driver option
[    2.336976] option: v0.7.2:USB Driver for GSM modems
[    2.344226]  gadget: Mass Storage Function, version: 2009/09/11
[    2.350404]  gadget: Number of LUNs=1
[    2.354267]  lun0: LUN: removable file: (no medium)
[    2.359675]  gadget: android_usb ready
[    2.363625] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    2.369219] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    2.377061] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.384157] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.391689] usb usb2: Product: MUSB HDRC host driver
[    2.396873] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[    2.402421] usb usb2: SerialNumber: musb-hdrc.0
[    2.407806] hub 2-0:1.0: USB hub found
[    2.411732] hub 2-0:1.0: 1 port detected
[    2.416697] mousedev: PS/2 mouse device common for all mice
[    2.423283] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[    2.431803] input: ft5x0x_ts as /devices/virtual/input/input1
[    3.592421] omap_i2c omap_i2c.2: controller timed out
[    3.597724] msg ft5x0x_read_reg i2c read error: -110
[    4.602416] omap_i2c omap_i2c.2: controller timed out
[    4.622424] msg ft5x0x_read_reg i2c read error: -110
[    5.622413] omap_i2c omap_i2c.2: controller timed out
[    5.642417] msg ft5x0x_read_reg i2c read error: -110
[    5.648559] rtc-ds1307: probe of 1-0068 failed with error -5
[    5.654545] i2c /dev entries driver
[    5.658644] Linux video capture inte**ce: v2.00
[    5.663832] usbcore: registered new inte**ce driver uvcvideo
[    5.669831] USB Video Class driver (1.1.1)
[    6.672420] omap_i2c omap_i2c.2: controller timed out
[    6.677721] msg ft5x0x_i2c_rxdata i2c read error: -110
[    7.682415] omap_i2c omap_i2c.2: controller timed out
[    8.702411] omap_i2c omap_i2c.2: controller timed out
[    9.722410] omap_i2c omap_i2c.2: controller timed out
[   10.742410] omap_i2c omap_i2c.2: controller timed out
[   11.762410] omap_i2c omap_i2c.2: controller timed out
[   12.782408] omap_i2c omap_i2c.2: controller timed out
[   13.802410] omap_i2c omap_i2c.2: controller timed out
[   14.822413] omap_i2c omap_i2c.2: controller timed out
[   14.843316] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   14.849665] Bluetooth: HCI UART driver ver 2.2
[   14.854330] Bluetooth: HCI H4 protocol initialized
[   14.859326] Bluetooth: HCILL protocol initialized
[   14.865134] cpuidle: using governor ladder
[   14.869554] cpuidle: using governor menu
[   14.876851] usbcore: registered new inte**ce driver usbhid
[   14.882722] usbhid: USB HID core driver
[   14.887270] logger: created 256K log 'log_main'
[   14.892139] logger: created 256K log 'log_events'
[   14.897453] logger: created 256K log 'log_radio'
[   14.902421] logger: created 256K log 'log_system'
[   14.907978] tiadc tiadc: attached adc driver
[   14.913088] usbcore: registered new inte**ce driver snd-usb-audio
[   14.993830] mmc0: host does not support reading read-only switch. assuming write-enable.
[   15.004399] mmc0: new high speed SD card at address 0bd5
[   15.010429] mmcblk0: mmc0:0bd5 SD02G 1.83 GiB
[   15.016711]  mmcblk0: p1
[   15.912424] omap_i2c omap_i2c.2: controller timed out
[   15.917750] _regulator_get: 2-001b supply IOVDD not found, using dummy regulator
[   15.925564] _regulator_get: 2-001b supply DVDD not found, using dummy regulator
[   15.933258] _regulator_get: 2-001b supply AVDD not found, using dummy regulator
[   15.940922] _regulator_get: 2-001b supply DRVDD not found, using dummy regulator
[   15.951616] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[   16.952421] omap_i2c omap_i2c.2: controller timed out
[   17.952410] omap_i2c omap_i2c.2: controller timed out
[   18.972411] omap_i2c omap_i2c.2: controller timed out
[   19.992408] omap_i2c omap_i2c.2: controller timed out
[   21.012411] omap_i2c omap_i2c.2: controller timed out
[   22.032408] omap_i2c omap_i2c.2: controller timed out
[   23.052408] omap_i2c omap_i2c.2: controller timed out
[   24.052411] omap_i2c omap_i2c.2: controller timed out
[   24.057692] msg ft5x0x_i2c_rxdata i2c read error: -110
[   25.062409] omap_i2c omap_i2c.2: controller timed out
[   26.062408] omap_i2c omap_i2c.2: controller timed out
[   27.082410] omap_i2c omap_i2c.2: controller timed out
[   28.102437] omap_i2c omap_i2c.2: controller timed out
[   29.122409] omap_i2c omap_i2c.2: controller timed out
[   30.142411] omap_i2c omap_i2c.2: controller timed out
[   31.162408] omap_i2c omap_i2c.2: controller timed out
[   32.182405] omap_i2c omap_i2c.2: controller timed out
[   33.202408] omap_i2c omap_i2c.2: controller timed out
[   34.222408] omap_i2c omap_i2c.2: controller timed out
[   35.242408] omap_i2c omap_i2c.2: controller timed out
[   36.262408] omap_i2c omap_i2c.2: controller timed out
[   37.282420] omap_i2c omap_i2c.2: controller timed out
[   38.302409] omap_i2c omap_i2c.2: controller timed out
[   39.322409] omap_i2c omap_i2c.2: controller timed out
[   40.342410] omap_i2c omap_i2c.2: controller timed out
[   41.362409] omap_i2c omap_i2c.2: controller timed out
[   42.382407] omap_i2c omap_i2c.2: controller timed out
[   43.402407] omap_i2c omap_i2c.2: controller timed out
[   44.422408] omap_i2c omap_i2c.2: controller timed out
[   45.442408] omap_i2c omap_i2c.2: controller timed out
[   46.462408] omap_i2c omap_i2c.2: controller timed out
[   47.482408] omap_i2c omap_i2c.2: controller timed out
[   48.502408] omap_i2c omap_i2c.2: controller timed out
[   49.522408] omap_i2c omap_i2c.2: controller timed out
[   50.542408] omap_i2c omap_i2c.2: controller timed out
[   51.562407] omap_i2c omap_i2c.2: controller timed out
[   52.582409] omap_i2c omap_i2c.2: controller timed out
[   53.602408] omap_i2c omap_i2c.2: controller timed out
[   54.622410] omap_i2c omap_i2c.2: controller timed out
[   54.642420] msg ft5x0x_i2c_rxdata i2c read error: -110
[   55.642409] omap_i2c omap_i2c.2: controller timed out
[   56.662408] omap_i2c omap_i2c.2: controller timed out
[   57.662408] omap_i2c omap_i2c.2: controller timed out
[   58.682409] omap_i2c omap_i2c.2: controller timed out
[   59.682410] omap_i2c omap_i2c.2: controller timed out
[   60.702408] omap_i2c omap_i2c.2: controller timed out
[   61.722408] omap_i2c omap_i2c.2: controller timed out
[   62.742410] omap_i2c omap_i2c.2: controller timed out
[   63.762409] omap_i2c omap_i2c.2: controller timed out
[   64.782408] omap_i2c omap_i2c.2: controller timed out
[   65.802409] omap_i2c omap_i2c.2: controller timed out
[   65.807689] msg ft5x0x_i2c_rxdata i2c read error: -110
[   66.812409] omap_i2c omap_i2c.2: controller timed out
[   67.832409] omap_i2c omap_i2c.2: controller timed out
[   68.852408] omap_i2c omap_i2c.2: controller timed out
[   69.872408] omap_i2c omap_i2c.2: controller timed out
[   70.892409] omap_i2c omap_i2c.2: controller timed out
[   71.912409] omap_i2c omap_i2c.2: controller timed out
[   72.932408] omap_i2c omap_i2c.2: controller timed out
[   72.952422] msg ft5x0x_i2c_rxdata i2c read error: -110
[   73.952409] omap_i2c omap_i2c.2: controller timed out
[   74.972410] omap_i2c omap_i2c.2: controller timed out
[   75.992407] omap_i2c omap_i2c.2: controller timed out
[   77.012408] omap_i2c omap_i2c.2: controller timed out
[   78.032409] omap_i2c omap_i2c.2: controller timed out
[   79.052408] omap_i2c omap_i2c.2: controller timed out
[   80.072450] omap_i2c omap_i2c.2: controller timed out
[   81.092409] omap_i2c omap_i2c.2: controller timed out
[   82.112407] omap_i2c omap_i2c.2: controller timed out
[   83.132409] omap_i2c omap_i2c.2: controller timed out
[   84.152410] omap_i2c omap_i2c.2: controller timed out
[   85.172410] omap_i2c omap_i2c.2: controller timed out
[   86.192409] omap_i2c omap_i2c.2: controller timed out
[   87.212408] omap_i2c omap_i2c.2: controller timed out
[   88.232452] omap_i2c omap_i2c.2: controller timed out
[   89.252409] omap_i2c omap_i2c.2: controller timed out
[   89.272420] msg ft5x0x_i2c_rxdata i2c read error: -110
[   90.272409] omap_i2c omap_i2c.2: controller timed out
[   91.292409] omap_i2c omap_i2c.2: controller timed out
[   92.312408] omap_i2c omap_i2c.2: controller timed out
[   93.332409] omap_i2c omap_i2c.2: controller timed out
[   94.352410] omap_i2c omap_i2c.2: controller timed out
[   95.372408] omap_i2c omap_i2c.2: controller timed out
[   96.392407] omap_i2c omap_i2c.2: controller timed out
[   97.412408] omap_i2c omap_i2c.2: controller timed out
[   98.432408] omap_i2c omap_i2c.2: controller timed out
[   98.452419] msg ft5x0x_i2c_rxdata i2c read error: -110
[   99.452410] omap_i2c omap_i2c.2: controller timed out
[  100.472408] omap_i2c omap_i2c.2: controller timed out
[  101.492408] omap_i2c omap_i2c.2: controller timed out
[  102.512409] omap_i2c omap_i2c.2: controller timed out
[  103.532408] omap_i2c omap_i2c.2: controller timed out
[  104.552408] omap_i2c omap_i2c.2: controller timed out
[  105.572409] omap_i2c omap_i2c.2: controller timed out
[  106.592408] omap_i2c omap_i2c.2: controller timed out
[  107.612408] omap_i2c omap_i2c.2: controller timed out
[  108.632409] omap_i2c omap_i2c.2: controller timed out
[  109.652408] omap_i2c omap_i2c.2: controller timed out
[  110.672409] omap_i2c omap_i2c.2: controller timed out
[  111.692408] omap_i2c omap_i2c.2: controller timed out
[  112.712408] omap_i2c omap_i2c.2: controller timed out
[  113.732408] omap_i2c omap_i2c.2: controller timed out
[  114.752408] omap_i2c omap_i2c.2: controller timed out
[  115.772409] omap_i2c omap_i2c.2: controller timed out
[  115.792419] msg ft5x0x_i2c_rxdata i2c read error: -110
[  116.792409] omap_i2c omap_i2c.2: controller timed out
[  117.812408] omap_i2c omap_i2c.2: controller timed out
[  118.832409] omap_i2c omap_i2c.2: controller timed out
[  119.852408] omap_i2c omap_i2c.2: controller timed out
[  120.872409] omap_i2c omap_i2c.2: controller timed out
[  121.892411] omap_i2c omap_i2c.2: controller timed out
[  122.912407] omap_i2c omap_i2c.2: controller timed out
[  123.932408] omap_i2c omap_i2c.2: controller timed out
[  124.952410] omap_i2c omap_i2c.2: controller timed out
[  125.972409] omap_i2c omap_i2c.2: controller timed out
[  125.993469] ALSA device list:
[  125.996578]   #0: AM335X EVM
[  125.999576] oprofile: hardware counters not available
[  126.004874] oprofile: using timer interrupt.
[  126.009504] Netfilter messages via NETLINK v0.30.
[  126.014555] nf_conntrack version 0.5.0 (7974 buckets, 31896 max)
[  126.021179] ctnetlink v0.93: registering with nfnetlink.
[  126.026829] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[  126.034106] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[  126.040642] xt_time: kernel timezone is -0000
[  126.045460] ip_tables: (C) 2000-2006 Netfilter Core Team
[  126.051227] arp_tables: (C) 2002 David S. Miller
[  126.056143] TCP cubic registered
[  126.059665] NET: Registered protocol family 10
[  126.065117] Mobile IPv6
[  126.067711] ip6_tables: (C) 2000-2006 Netfilter Core Team
[  126.073611] IPv6 over IPv4 tunneling driver
[  126.078663] NET: Registered protocol family 17
[  126.083384] NET: Registered protocol family 15
[  126.088013] can: controller area network core (rev 20090105 abi 8)
[  126.094601] NET: Registered protocol family 29
[  126.099262] can: raw protocol (rev 20090105)
[  126.103732] can: broadcast manager protocol (rev 20090105 t)
[  126.109979] Bluetooth: RFCOMM TTY layer initialized
[  126.115114] Bluetooth: RFCOMM socket layer initialized
[  126.120472] Bluetooth: RFCOMM ver 1.11
[  126.124396] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  126.129930] Bluetooth: BNEP filters: protocol multicast
[  126.135389] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[  126.141690] Registering the dns_resolver key type
[  126.146679] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[  126.154696] ThumbEE CPU extension supported.
[  126.159209] mux: Failed to setup hwmod io irq -22
[  126.164912] Power Management for AM33XX family
[  126.169773] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[  126.176487] Copied the M3 firmware to UMEM
[  126.180835] Cortex M3 Firmware Version = 0x181
[  126.190476] clock: disabling unused clocks to save power
[  126.198042] Detected MACID=1c:ba:8c:b3:25:17
[  126.205067] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[  126.212633] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[  126.282790] UBIFS: recovery needed
[  127.212489] omap_i2c omap_i2c.2: controller timed out
[  127.217844] msg ft5x0x_i2c_rxdata i2c read error: -110
[  127.367855] UBIFS: recovery completed
[  127.371830] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[  127.378136] UBIFS: file system size:   239857664 bytes (234236 KiB, 228 MiB, 1889 LEBs)
[  127.386493] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[  127.394124] UBIFS: media format:       w4/r0 (latest is w4/r0)
[  127.400201] UBIFS: default compressor: lzo
[  127.404477] UBIFS: reserved for root:  0 bytes (0 KiB)
[  127.410416] VFS: Mounted root (ubifs filesystem) on device 0:14.
[  127.417356] devtmpfs: mounted
[  127.421034] Freeing init memory: 328K
[  127.612901] init: cannot find '/system/bin/wifi/rc.wifi', disabling 'wl12xx'
[  127.670768] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
# [  127.987326] g_zero: disagrees about version of symbol module_layout
[  128.034187] warning: `dhcpcd' uses 32-bit capabilities (legacy support in use)
[  128.094283] android_usb: already disabled
[  128.098794] adb_bind_config
[  128.145617] PHY 0:00 not found
[  128.148825] PHY 0:01 not found
[  128.173854] ADDRCONF(NETDEV_UP): eth0: link is not ready
[  128.213498] adb_open
[  128.250432] Disabling lock debugging due to kernel taint
[  128.332594] omap_i2c omap_i2c.2: controller timed out
[  128.337932] msg ft5x0x_i2c_rxdata i2c read error: -110
[  129.372514] omap_i2c omap_i2c.2: controller timed out
[  129.377861] msg ft5x0x_i2c_rxdata i2c read error: -110
[  130.412883] omap_i2c omap_i2c.2: controller timed out
[  130.418223] msg ft5x0x_i2c_rxdata i2c read error: -110
[  131.422935] omap_i2c omap_i2c.2: controller timed out
[  132.422504] omap_i2c omap_i2c.2: controller timed out
[  132.427851] msg ft5x0x_i2c_rxdata i2c read error: -110
[  133.432509] omap_i2c omap_i2c.2: controller timed out
[  134.432497] omap_i2c omap_i2c.2: controller timed out
[  134.437855] msg ft5x0x_i2c_rxdata i2c read error: -110
[  135.442486] omap_i2c omap_i2c.2: controller timed out
[  136.443719] omap_i2c omap_i2c.2: controller timed out
[  136.449064] msg ft5x0x_i2c_rxdata i2c read error: -110
[  136.617274] alarm_set_rtc: no RTC, time will be lost on reboot
[  137.453179] omap_i2c omap_i2c.2: controller timed out
[  138.452523] omap_i2c omap_i2c.2: controller timed out
[  138.457873] msg ft5x0x_i2c_rxdata i2c read error: -110
[  139.462958] omap_i2c omap_i2c.2: controller timed out
[  140.462659] omap_i2c omap_i2c.2: controller timed out
[  140.468005] msg ft5x0x_i2c_rxdata i2c read error: -110
[  141.354177] er.ServerThread (133): /proc/123/oom_adj is deprecated, please use /proc/123/oom_score_adj instead.
[  141.473019] omap_i2c omap_i2c.2: controller timed out
[  141.701487] alarm_release: clear alarm, pending 0
[  141.713831] binder: 123: binder_alloc_buf, no vma
[  141.718814] binder: 134:137 transaction failed 29201, size 64-0
[  141.727981] request_suspend_state: wakeup (3->0) at 141695570768 (1970-01-02 00:00:05.110701209 UTC)
[  141.836632]  OMAPLFBManualSync Not Supported
[  142.472543] omap_i2c omap_i2c.2: controller timed out
[  142.477901] msg ft5x0x_i2c_rxdata i2c read error: -110
[  143.482501] omap_i2c omap_i2c.2: controller timed out
[  144.482526] omap_i2c omap_i2c.2: controller timed out
[  144.487875] msg ft5x0x_i2c_rxdata i2c read error: -110
[  145.492557] omap_i2c omap_i2c.2: controller timed out
[  146.492643] omap_i2c omap_i2c.2: controller timed out
[  146.497992] msg ft5x0x_i2c_rxdata i2c read error: -110
[  147.502542] omap_i2c omap_i2c.2: controller timed out
[  148.503047] omap_i2c omap_i2c.2: controller timed out
[  148.508388] msg ft5x0x_i2c_rxdata i2c read error: -110
[  149.512435] omap_i2c omap_i2c.2: controller timed out
[  150.512435] omap_i2c omap_i2c.2: controller timed out
[  150.517775] msg ft5x0x_i2c_rxdata i2c read error: -110
[  151.522435] omap_i2c omap_i2c.2: controller timed out
[  152.522434] omap_i2c omap_i2c.2: controller timed out
[  152.527775] msg ft5x0x_i2c_rxdata i2c read error: -110
[  153.532436] omap_i2c omap_i2c.2: controller timed out
[  154.532437] omap_i2c omap_i2c.2: controller timed out
[  154.537777] msg ft5x0x_i2c_rxdata i2c read error: -110
[  155.542439] omap_i2c omap_i2c.2: controller timed out
[  155.552163] init: untracked pid 81 exited
[  156.542437] omap_i2c omap_i2c.2: controller timed out
[  156.547779] msg ft5x0x_i2c_rxdata i2c read error: -110
[  157.552436] omap_i2c omap_i2c.2: controller timed out
[  158.552441] omap_i2c omap_i2c.2: controller timed out
[  158.557787] msg ft5x0x_i2c_rxdata i2c read error: -110
[  159.562438] omap_i2c omap_i2c.2: controller timed out
[  160.562434] omap_i2c omap_i2c.2: controller timed out
[  160.567767] msg ft5x0x_i2c_rxdata i2c read error: -110
[  161.592442] omap_i2c omap_i2c.2: controller timed out
[  161.597771] msg ft5x0x_i2c_rxdata i2c read error: -110
[  162.622443] omap_i2c omap_i2c.2: controller timed out
[  162.627780] msg ft5x0x_i2c_rxdata i2c read error: -110
[  163.632443] omap_i2c omap_i2c.2: controller timed out
[  164.632441] omap_i2c omap_i2c.2: controller timed out
[  164.637779] msg ft5x0x_i2c_rxdata i2c read error: -110
[  165.642438] omap_i2c omap_i2c.2: controller timed out
[  166.642435] omap_i2c omap_i2c.2: controller timed out
[  166.647770] msg ft5x0x_i2c_rxdata i2c read error: -110
[  167.652436] omap_i2c omap_i2c.2: controller timed out
[  168.652441] omap_i2c omap_i2c.2: controller timed out
[  168.657784] msg ft5x0x_i2c_rxdata i2c read error: -110
[  169.662437] omap_i2c omap_i2c.2: controller timed out
[  170.662435] omap_i2c omap_i2c.2: controller timed out
[  170.667774] msg ft5x0x_i2c_rxdata i2c read error: -110
[  171.672436] omap_i2c omap_i2c.2: controller timed out
[  172.672443] omap_i2c omap_i2c.2: controller timed out
[  172.677775] msg ft5x0x_i2c_rxdata i2c read error: -110
[  173.682431] omap_i2c omap_i2c.2: controller timed out
[  174.682431] omap_i2c omap_i2c.2: controller timed out
[  174.687767] msg ft5x0x_i2c_rxdata i2c read error: -110
[  175.692432] omap_i2c omap_i2c.2: controller timed out
[  176.692431] omap_i2c omap_i2c.2: controller timed out
[  176.697762] msg ft5x0x_i2c_rxdata i2c read error: -110
[  177.702431] omap_i2c omap_i2c.2: controller timed out
[  178.702434] omap_i2c omap_i2c.2: controller timed out
[  178.707774] msg ft5x0x_i2c_rxdata i2c read error: -110
[  179.712436] omap_i2c omap_i2c.2: controller timed out
6万
飞凌-白董 发表于 2014-10-8 09:02:28 | 显示全部楼层
你好,OK335xD做卡的时候需要注意2点,1:卡需要使用HP的格式化软件先格式化;2:拨码开关的位置烧写的话是1ON 2ON,Android2.3和4.2我这里启动稳定在2分钟左右。
楼主| 煮酒 发表于 2014-10-8 22:25:33 | 显示全部楼层
你好,OK335xD做卡的时候需要注意2点,1:卡需要使用HP的格式化软件先格式化;2:拨码开关的位置烧写的话是 ...
卡没问题,
同一个卡 我把启动方式改成 10111 和10011就好了
