- 21
贡献50
飞刀0 FD
注册时间2013-9-21
在线时间7 小时
该问题总算有了点眉目,在国外的论坛看到了相似的问题,http://www.draisberghof.de/usb_modeswitch/bb/viewtopic.php?t=410打开该链接需要翻墙的哦,简单粗暴的方法是下载个“自由门”。下面摘录两段与大家分享。
Josh:- There are Huawei problems introduced with the kernel series you use, due to a firmware bug. But they affected mostly the storage inte**ces of the switched devices, in many cases causing a reset which switched the whole thing back into the initial mode.
- If that is the cause of your trouble - which I'm not entirely certain of - you could remove the usb-storage driver (after unmounting any automounted devices) and see if that helps. If so, look for a kernel above 2.6.31.5 where a workaround for the problem was included.
复制代码 Josh:- This is plain wrong, unfortunately. The example being the Huawei problem with kernel 2.6.32. It is a firmware bug that was not exposed on Windows and on Linux versions before; but when the storage driver was aligned with the official USB specification a little more strictly, the bug hit.
- So, "working on Windows" is indeed no qualification for "bugfree".
复制代码 翻译一下第二段,大家不要莫笑我:
不幸的是,这(指下面的英文)是完全错误的。华为在2.6.32内核上的问题就是一个例子(弹出错误-71或-84),这是一个在Windows和以前版本的linux上不会暴露的固件(和我以前理解的”固件“二字不大一样哎)bug;但是当存储驱动程序与USB的官方规范更吻合,bug显露了。
- dchard wrote:
- The firmware/hardware failures can be excluded because these devices are working fine on windows.
复制代码 |
