- 5
贡献16
飞刀0 FD
注册时间2015-1-24
在线时间1 小时
最近用ok6410写外部中断的驱动,用的是第2组外部中断,看芯片手册是53号中断,注册中断没问题,但是怎么也进不了中断函数,我觉得是寄存器配置问题,捣鼓了好几天,参考了好些资料,还是不能进入中断,谁能不能告诉我这个的寄存器配置流程。下面贴我的代码,若能指点一二,不胜感激!!!- #include <linux/init.h>
- #include <linux/module.h>
- #include <linux/fs.h>
- #include <linux/cdev.h>
- #include <linux/device.h>
- #include <asm/io.h>
- #include <asm/uaccess.h>
- #include <linux/interrupt.h>
- volatile static unsigned long *REG_GPC_CON2;
- volatile static unsigned long *REG_GPC_DAT;
- volatile static unsigned long *REG_GPC_PULL;
- volatile static unsigned long *REG_EINT_CON2;
- volatile static unsigned long *REG_EINT_MASK2;
- volatile static unsigned long *REG_EINT_PEND2;
- volatile static unsigned long *REG_VIC1_INTENABLE;
- volatile static unsigned long *REG_VIC1_VECTADDR;
- volatile static unsigned long *REG_VIC1_CLEAR;
- volatile static unsigned long *REG_VIC1_STATUS;
- volatile static unsigned long *REG_VIC1_ADDRESS;
- volatile static unsigned long *REG_VIC0_ADDRESS;
- volatile static unsigned long *REG_VIC1_SELECT;
- static irqreturn_t EINT_TEST(int irq, void *dev_id)
- *REG_EINT_PEND2 |= (0x1 << 18);
- printk("this is interrupt!\n");
- *REG_VIC1_ADDRESS = 0x0;
- *REG_VIC0_ADDRESS = 0x0;
- return IRQ_HANDLED;
- //用户程序接口部分
- static int EINT_open(struct inode* n, struct file* f)
- int result;
- REG_GPC_CON2 = (volatile unsigned long *)ioremap(0x7F008040, 4);
- REG_GPC_DAT = (volatile unsigned long *)ioremap(0x7F008044, 4);
- REG_GPC_PULL = (volatile unsigned long *)ioremap(0x7F008048, 4);
- REG_EINT_CON2 = (volatile unsigned long *)ioremap(0x7F008200, 4);
- REG_EINT_MASK2 = (volatile unsigned long *)ioremap(0x7F008240, 4);
- REG_EINT_PEND2 = (volatile unsigned long *)ioremap(0x7F008260, 4);
- REG_VIC1_INTENABLE = (volatile unsigned long *)ioremap(0x71300010, 4);
- REG_VIC1_VECTADDR = (volatile unsigned long *)ioremap(0x71300100, 4);
- REG_VIC1_CLEAR = (volatile unsigned long *)ioremap(0x71300014, 4);
- REG_VIC1_STATUS = (volatile unsigned long *)ioremap(0x71300000, 4);
- REG_VIC1_ADDRESS = (volatile unsigned long *)ioremap(0x71300F00, 4);
- REG_VIC1_SELECT = (volatile unsigned long *)ioremap(0x7130000c, 4);
- REG_VIC0_ADDRESS = (volatile unsigned long *)ioremap(0x71200F00, 4);
- // printk("%d \n\n", sizeof(REG_GPC_CON2));
- /************引脚配置**********/
- *REG_GPC_CON2 &= ~(0xF << 8);
- *REG_GPC_CON2 |= (0x7 << 8); //外部中断
- *REG_GPC_PULL &= ~(0x3 << 4);
- *REG_GPC_PULL |= (0x1 << 4); //下拉电阻使能
- *REG_EINT_CON2 &= ~(0x7 << 16);
- *REG_EINT_CON2 |= (0x1 << 16); //high level
- *REG_EINT_MASK2 &= ~(0x1 << 18);
- /******总中断控制器配置********/
- *REG_VIC1_CLEAR |= (0x1 << 21);
- *REG_VIC1_SELECT &= ~(0x1 << 21);
- /*********中断使能************/
- *REG_VIC1_INTENABLE |= (0x1 << 21); //中断控制器中断使能
- /*********加载中断程序*******/
- REG_VIC1_VECTADDR[21] = (unsigned )EINT_TEST; //中断程序地址
- result = request_irq(53, EINT_TEST, IRQF_DISABLED, "EINT", NULL); //注册中断
- if(result != 0)
- printk("EINT error! -> %d\n", result);
- free_irq(53, NULL);
- return result;
- printk("Open Finished!\n");
- return 0;
- static int EINT_close(struct inode* n, struct file* f)
- iounmap(REG_GPC_CON2);
- iounmap(REG_GPC_DAT);
- iounmap(REG_GPC_PULL);
- iounmap(REG_EINT_CON2);
- iounmap(REG_EINT_MASK2);
- iounmap(REG_EINT_PEND2);
- iounmap(REG_VIC1_INTENABLE);
- iounmap(REG_VIC1_VECTADDR);
- iounmap(REG_VIC1_CLEAR);
- iounmap(REG_VIC1_STATUS);
- iounmap(REG_VIC1_ADDRESS);
- iounmap(REG_VIC0_ADDRESS);
- iounmap(REG_VIC1_SELECT);
- printk("Close Finished!\n");
- return 0;
- static ssize_t EINT_write(struct file* f, const char __user* buf, size_t len, loff_t* l)
- printk("Write Finished!\n");
- return len;
- static ssize_t EINT_read(struct file* f, char __user* buf, size_t len, loff_t* l)
- printk("Read Finished!\n");
- return 0;
- //操作系统接口部分
- #define DEV_NAME "EINT"
- #define DEV_COUNT 1
- static struct class* pClass;
- int major;
- static struct file_operations fops =
- .owner = THIS_MODULE,
- .open = EINT_open,
- .write = EINT_write,
- .read = EINT_read,
- .release = EINT_close,
- static int __init EINT_init(void)
- major = register_chrdev(0, DEV_NAME, &fops);
- pClass = class_create(THIS_MODULE, DEV_NAME);
- if (pClass == NULL)
- unregister_chrdev(major, DEV_NAME);
- return -1;
- device_create(pClass, NULL, MKDEV(major, 0), NULL, DEV_NAME);
- /* REG_GPC_CON2 = (volatile unsigned long *)ioremap(0x7F008040, 4);
- printk("Init Finished!\n");
- return 0;
- static void __exit EINT_exit(void)
- if (pClass)
- device_destroy(pClass, MKDEV(major, 0));
- class_destroy(pClass);
- printk("Exit Finished!\n");
- MODULE_LICENSE("GPL");
- MODULE_AUTHOR("PuJunji");
- module_init(EINT_init);
- module_exit(EINT_exit);
- //代码结束
复制代码 |
