查看: 3763|回复: 1
ok6410 (256m ram 2g nand) CE6启动后停在下面的位置不动
96
52mcu 发表于 2011-5-26 14:27:59 | 显示全部楼层 |阅读模式
-OALIntrRequestSysIntr(irq = 95, sysIntr = 29)
[HSMMC0] Card is Inserted!
[HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Card is Inserted!
WARN: OALIoCtlHalGetHWEntropy: Buffer too small
[HSMMC0] Turn OFF the F/B delay control.
[HSMMC0] CSDHCSlotBase::SDClockOn: Timeout waiting for CLOCK_STABLE
[HSMMC1] CSDHCSlotBase::SDClockOn: Timeout waiting for CLOCK_STABLE
[HSMMC0] Setting for 1 bit mode , Clock Rate = 100000 Hz
[HSMMC1] Setting for 1 bit mode , Clock Rate = 100000 Hz
<Davicom DM9000A driver for WinCE 6.0>
<DM9:++MiniportIntialize>
[dm9: Tries to map io space with 18000000]
[dm9: The mapped address is D2F60000]
[dm9: Chip signature is 0A469000]
<DM9:--MiniportIntialize>
[UFNPDD] USB Serial Function Class Enabled
[USB] dii.dwIrq = 96
-OALIntrRequestSysIntr(irq = 96, sysIntr = 30)
Current Client "Serial_Class"
DEBUG: CreateSerialObject 3
-OALIntrRequestSysIntr(irq = 64, sysIntr = 31)
DEBUG: CreateSerialObject 2
-OALIntrRequestSysIntr(irq = 63, sysIntr = 32)
DEBUG: CreateSerialObject 1
-OALIntrRequestSysIntr(irq = 62, sysIntr = 33)
[USBH] HcdPdd_Init()
[USBH] ++InitializeOHCI()
飞凌-fatfish 发表于 2011-5-26 16:58:05 | 显示全部楼层
请贴映像来源、烧写过程。
