查看: 5994|回复: 4
同一块ok6410核心板,分别接两块底板启动输出结果不一样。
96
52mcu 发表于 2011-5-27 08:58:15 | 显示全部楼层 |阅读模式
两块底板一块有问题不能启动CE6(称为“问题板”) 一块可正常启动CE6(称为“正常板”)
现用同一块装有linux2.6.28的核心板先后与“问题板”和“正常板”相配看启动信息。“问题板”表现为有usb相关的错误信息输出
而“正常板”却没有。
请斑竹,大虾们分析下“问题板”的问题到底出在哪里 ????“问题板”和“正常板” 是同时在3月份从飞凌买的。
“问题板”inux2.6.28 启动信息
cheaking bad block...............
................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 148K
usb 1-2: device descriptor read/64, error -62
usb 1-2: new full speed USB device using s3c2410-ohci and address 3
usb 1-2: new full speed USB device using s3c2410-ohci and address 4
usb 1-2: device not accepting address 4, error -62
usb 1-2: new full speed USB device using s3c2410-ohci and address 5
usb 1-2: device not accepting address 5, error -62
hub 1-0:1.0: unable to enumerate USB device on port 2
     http://www.witech.com.cn
“正常板”inux2.6.28 启动信息
飞凌-fatfish 发表于 2011-5-27 13:16:17 | 显示全部楼层
拔掉开发板usb和pc的连接线就没有了。
不是问题。
至于wince的问题。也可以跟帖发出来。
96
楼主| 52mcu 发表于 2011-5-27 15:03:26 | 显示全部楼层
ok6410 (256m ram 2g nand) CE6启动后停在下面的位置不动
-OALIntrRequestSysIntr(irq = 95, sysIntr = 29)
[HSMMC0] Card is Inserted!
[HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Card is Inserted!
WARN: OALIoCtlHalGetHWEntropy: Buffer too small
[HSMMC0] Turn OFF the F/B delay control.
[HSMMC0] CSDHCSlotBase::SDClockOn: Timeout waiting for CLOCK_STABLE
[HSMMC1] CSDHCSlotBase::SDClockOn: Timeout waiting for CLOCK_STABLE
[HSMMC0] Setting for 1 bit mode , Clock Rate = 100000 Hz
[HSMMC1] Setting for 1 bit mode , Clock Rate = 100000 Hz
<Davicom DM9000A driver for WinCE 6.0>
<DM9:++MiniportIntialize>
[dm9: Tries to map io space with 18000000]
[dm9: The mapped address is D2F60000]
[dm9: Chip signature is 0A469000]
<DM9:--MiniportIntialize>
[UFNPDD] USB Serial Function Class Enabled
[USB] dii.dwIrq = 96
-OALIntrRequestSysIntr(irq = 96, sysIntr = 30)
Current Client "Serial_Class"
DEBUG: CreateSerialObject 3
-OALIntrRequestSysIntr(irq = 64, sysIntr = 31)
DEBUG: CreateSerialObject 2
-OALIntrRequestSysIntr(irq = 63, sysIntr = 32)
DEBUG: CreateSerialObject 1
-OALIntrRequestSysIntr(irq = 62, sysIntr = 33)
[USBH] HcdPdd_Init()
[USBH] ++InitializeOHCI()
96
楼主| 52mcu 发表于 2011-5-27 15:06:24 | 显示全部楼层
我没有插usb的链接线啊。host  和otg 都没连    如何解释 同一个核心板一块底板能启动CE 一块底板不能启动
25
飞凌-fatfish 发表于 2011-5-27 16:49:25 | 显示全部楼层
那周一联系客服0312-3119192
