- 3
贡献13
飞刀0 FD
注册时间2015-3-18
在线时间0 小时
按照用户手册一键烧写Linux,烧写成功(发出滴滴提示声),启动屏幕花屏,都是竖纹(我的是7寸屏,买来时装好的Linux系统,可以使用)
Nand flash 启动 DNW打印消息如下:
KK
U-Boot 1.1.6 (Sep 19 2014 - 10:00:03) for SMDK6410
** u-boot 1.1.6 **
** Updated for OK6410 TE6410 Board **
** Version (2012-09-23) **
** OEM: Forlinx Embedded **
** Web: http://www.witech.com.cn **
CPU: S3C6410 @532MHz
Board: SMDK6410
DRAM: 256 MB
Flash: 0 kB
NAND: 1024 MB
In: serial
Out: serial
Err: serial
NAND read: device 0 offset 0x500000, size 0x500000
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 3.0.1 (root@ubuntu) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #676 Fri Sep 19 10:39:58 CST 2014
Ignoring unrecognised tag 0x54410008
Kernel command line: root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200
Memory: 196660k/196660k available, 65484k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff600000 - 0xffe00000 ( 8 MB)
vmalloc : 0xd0800000 - 0xf4000000 ( 568 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0036000 ( 184 kB)
.text : 0xc0036000 - 0xc07d4434 (7802 kB)
.data : 0xc07d6000 - 0xc082eaf0 ( 355 kB)
.bss : 0xc082eb14 - 0xc08b1124 ( 522 kB)
SCSI subsystem initialized
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124()
---[ end trace da227214a82491b7 ]---
type=2000 audit(0.190:1): initialized
Hello, world
Creating 4 MTD partitions on "NAND 2GiB 1,8V 8-bit":
0x000000000000-0x000000200000 : "Bootloader"
0x000000500000-0x000001e00000 : "Kernel"
0x000001e00000-0x00000e600000 : "File System"
0x00000e600000-0x000040000000 : "User"
mcp2515 spi1.0: MCP251x didn't enter in conf mode after reset
mcp2515 spi1.0: probe failed
dm9000 dm9000.0: read wrong id 0x01010101
s3c_g2d_probe called
s3c_g2d_probe Success
FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Try to bring eth0 inte**ce up......Done
Starting Qtopia2, please waiting...
Please press Enter to activate this console. touch...
请提供技术支持,谢谢 |
