查看: 6418|回复: 1
[Linux] 根据linux用户手册4.3节制作的ubi.img不能工作
willieshine 发表于 2015-3-24 22:44:08 | 显示全部楼层 |阅读模式
飞凌工程师,你好。
我用linux->bin->rootfs->1G->ubi 镜像文件系统可以运行。
根据linux用户手册4.3节制作的ubi.img不能工作。
超级终端信息如下:
Net:   cpsw
Booting from nand ...
NAND read: device 0 offset 0xc00000, size 0x500000
5242880 bytes read: OK
## Booting kernel from Legacy Image at 80200000 ...
   Image Name:   Linux-3.2.0
   Data Size:    3741600 Bytes = 3.6 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Linux version 3.2.0 (root@ubuntu) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Mon Mar 23 06:29:46 PDT 2015
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] Machine: am335xevm
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=7,4096 rootfstype=ubifs rootwait=1 screentype=C screensize=800x480-7 calibrate=Y laohua=N
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 511932k/511932k available, 12356k reserved, 0K highmem
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc06c1000   (6884 kB)
[    0.000000]       .init : 0xc06c1000 - 0xc06fe000   ( 244 kB)
[    0.000000]       .data : 0xc06fe000 - 0xc076e730   ( 450 kB)
[    0.000000]        .bss : 0xc076e754 - 0xc07a25b8   ( 208 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[    0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[    0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000189] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[    0.057158] pid_max: default: 32768 minimum: 301
[    0.057287] Security Framework initialized
[    0.057391] Mount-cache hash table entries: 512
[    0.057779] CPU: Testing write buffer coherency: ok
[    0.058534] devtmpfs: initialized
[    0.078552] omap_hwmod: pruss: failed to hardreset
[    0.079660] print_constraints: dummy:
[    0.080017] NET: Registered protocol family 16
[    0.082109] OMAP GPIO hardware version 0.1
[    0.084663] omap_mux_init: Add partition: #1: core, flags: 0
[    0.086491]  omap_i2c.1: alias fck already exists
[    0.087655]  omap_hsmmc.0: alias fck already exists
[    0.087916]  omap_hsmmc.1: alias fck already exists
[    0.088482]  da8xx_lcdc.0: alias fck already exists
[    0.088754]  omap_i2c.2: alias fck already exists
[    0.090304]  d_can.0: alias fck already exists
[    0.090587]  davinci-mcasp.1: alias fck already exists
[    0.091794]  omap2_mcspi.1: alias fck already exists
[    0.092010]  omap2_mcspi.2: alias fck already exists
[    0.092273]  edma.0: alias fck already exists
[    0.092294]  edma.0: alias fck already exists
[    0.092313]  edma.0: alias fck already exists
[    0.128693] bio: create slab <bio-0> at 0
[    0.130914] SCSI subsystem initialized
[    0.132889] usbcore: registered new inte**ce driver usbfs
[    0.133210] usbcore: registered new inte**ce driver hub
[    0.133413] usbcore: registered new device driver usb
[    0.133724] registerd cppi-dma Intr @ IRQ 17
[    0.133740] Cppi41 Init Done Qmgr-base(e087a000) dma-base(e0878000)
[    0.133750] Cppi41 Init Done
[    0.133779] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.134066] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.135193] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.136901] tps65217 1-0024: TPS65217 ID 0xe version 1.2
[    0.138925] print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV
[    0.140965] print_constraints: DCDC2: 900 <--> 3300 mV at 1100 mV
[    0.142955] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV
[    0.144950] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[    0.146920] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[    0.148928] print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV
[    0.150905] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[    0.151758] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    0.153531] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.154266] Bluetooth: Core ver 2.16
[    0.154449] NET: Registered protocol family 31
[    0.154462] Bluetooth: HCI device and connection manager initialized
[    0.154479] Bluetooth: HCI socket layer initialized
[    0.154490] Bluetooth: L2CAP socket layer initialized
[    0.154519] Bluetooth: SCO socket layer initialized
[    0.155087] cfg80211: Calling CRDA to update world regulatory domain
[    0.156273] Switching to clocksource gp timer
[    0.173979] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.174197] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.174532] MUSB0 controller's USBSS revision = 4ea20800
[    0.174566] musb0: Enabled SW babble control
[    0.175515] musb-hdrc musb-hdrc.0: USB OTG mode controller at e083e000 using DMA, IRQ 18
[    0.175681] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.175976] MUSB1 controller's USBSS revision = 4ea20800
[    0.176003] musb1: Enabled SW babble control
[    0.176509] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.176604] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.176749] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.176764] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.176778] usb usb1: Product: MUSB HDRC host driver
[    0.176789] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.176799] usb usb1: SerialNumber: musb-hdrc.1
[    0.177724] hub 1-0:1.0: USB hub found
[    0.177754] hub 1-0:1.0: 1 port detected
[    0.178359] musb-hdrc musb-hdrc.1: USB Host mode controller at e084a800 using DMA, IRQ 19
[    0.178803] NET: Registered protocol family 2
[    0.178996] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.179311] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.179607] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    0.179781] TCP: Hash tables configured (established 16384 bind 16384)
[    0.179794] TCP reno registered
[    0.179807] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.179842] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.180020] NET: Registered protocol family 1
[    0.180285] RPC: Registered named UNIX socket transport module.
[    0.180299] RPC: Registered udp transport module.
[    0.180308] RPC: Registered tcp transport module.
[    0.180317] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.180546] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.180777] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.200311] VFS: Disk quotas dquot_6.5.2
[    0.200388] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.200936] msgmni has been set to 999
[    0.204061] alg: No test for stdrng (krng)
[    0.204136] io scheduler noop registered
[    0.204147] io scheduler deadline registered
[    0.204242] io scheduler cfq registered (default)
[    0.205807] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-7.0-ATXI#-T-1 panel
[    0.216241] Console: switching to colour frame buffer device 100x30
[    0.223460] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.950565] console [ttyO0] enabled
[    0.954993] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.962953] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.970865] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    0.978760] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    0.986680] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    1.004665] brd: module loaded
[    1.013091] loop: module loaded
[    1.016874] i2c-core: driver [tsl2550] using legacy suspend method
[    1.023326] i2c-core: driver [tsl2550] using legacy resume method
[    1.030072] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.040317] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.047996] omap2-nand driver initializing
[    1.052353] info->phys_base 8000000
[    1.056059] ONFI flash detected
[    1.059484] ONFI param page 0 valid
[    1.063127] NAND device: Manufacturer ID: 0x2c, Chip ID: 0x38 (Micron MT29F8G08ABABAWP)
[    1.071481] omap2-nand: detected x8 NAND flash
[    1.076201] Page size 4096 Select ECC BCH16
[    1.080569] Nand ECC BCH16 HW
[    1.083880] Creating 8 MTD partitions on "omap2-nand.0":
[    1.089453] 0x000000000000-0x000000200000 : "SPL"
[    1.096043] 0x000000200000-0x000000400000 : "SPL.backup1"
[    1.103143] 0x000000400000-0x000000600000 : "SPL.backup2"
[    1.110302] 0x000000600000-0x000000800000 : "SPL.backup3"
[    1.117396] 0x000000800000-0x000000a00000 : "U-Boot"
[    1.123987] 0x000000a00000-0x000000c00000 : "U-Boot Env"
[    1.131021] 0x000000c00000-0x000001400000 : "Kernel"
[    1.137986] 0x000001400000-0x000040000000 : "File System"
[    1.194274] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    1.202849] OneNAND driver initializing
[    1.207727] UBI: attaching mtd7 to ubi0
[    1.211742] UBI: physical eraseblock size:   524288 bytes (512 KiB)
[    1.218302] UBI: logical eraseblock size:    516096 bytes
[    1.223929] UBI: smallest flash I/O unit:    4096
[    1.228837] UBI: sub-page size:              1024
[    1.233737] UBI: VID header offset:          4096 (aligned 4096)
[    1.240003] UBI: data offset:                8192
[    1.349317] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[    1.356329] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.386913] hub 1-1:1.0: USB hub found
[    1.390902] hub 1-1:1.0: 4 ports detected
[    5.074125] UBI: max. sequence number:       9
[    5.098958] UBI: attached mtd7 to ubi0
[    5.102880] UBI: MTD device name:            "File System"
[    5.108657] UBI: MTD device size:            1004 MiB
[    5.113918] UBI: number of good PEBs:        2008
[    5.118829] UBI: number of bad PEBs:         0
[    5.123456] UBI: number of corrupted PEBs:   0
[    5.128091] UBI: max. allowed volumes:       128
[    5.132900] UBI: wear-leveling threshold:    4096
[    5.137807] UBI: number of internal volumes: 1
[    5.142436] UBI: number of user volumes:     1
[    5.147083] UBI: available PEBs:             0
[    5.151710] UBI: total number of reserved PEBs: 2008
[    5.156891] UBI: number of PEBs reserved for bad PEB handling: 20
[    5.163239] UBI: max/mean erase counter: 1/0
[    5.167694] UBI: image sequence number:  530827853
[    5.172775] UBI: background thread "ubi_bgt0d" started, PID 661
[    5.196566] CAN device driver inte**ce
[    5.200569] CAN bus driver for Bosch D_CAN controller 1.0
[    5.216674] d_can d_can.0: device registered (irq=52, irq_obj=53)
[    5.287794] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    5.294245] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[    5.318322] davinci_mdio.0: probed
[    5.321880] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[    5.337941] PPP generic driver version 2.4.2
[    5.356887] PPP BSD Compression module registered
[    5.361793] PPP Deflate Compression module registered
[    5.367071] RTL871X: module init start version:v4.1.7_9024.20130916
[    5.387621] RTL871X: module init ret=0
[    5.391729] usbcore: registered new inte**ce driver zd1201
[    5.409073] usbcore: registered new inte**ce driver cdc_ether
[    5.428925] usbcore: registered new inte**ce driver cdc_eem
[    5.434980] usbcore: registered new inte**ce driver dm9601
[    5.440855] cdc_ncm: 04-Aug-2011
[    5.458091] usbcore: registered new inte**ce driver cdc_ncm
[    5.463994] Initializing USB Mass Storage driver...
[    5.469343] usbcore: registered new inte**ce driver usb-storage
[    5.475607] USB Mass Storage support registered.
[    5.497219] usbcore: registered new inte**ce driver usbserial
[    5.508982] USB Serial support registered for generic
[    5.528427] usbcore: registered new inte**ce driver usbserial_generic
[    5.535235] usbserial: USB Serial Driver core
[    5.539924] USB Serial support registered for GSM modem (1-port)
[    5.557845] usbcore: registered new inte**ce driver option
[    5.563657] option: v0.7.2:USB Driver for GSM modems
[    5.577245] USB Serial support registered for Vizzini USB serial port
[    5.597788] usbcore: registered new inte**ce driver vizzini
[    5.603685] USB Driver for Vizzini USB serial port: v.1.1
[    5.617739]  gadget: Mass Storage Function, version: 2009/09/11
[    5.623917]  gadget: Number of LUNs=1
[    5.627747]  lun0: LUN: removable file: (no medium)
[    5.632861]  gadget: Mass Storage Gadget, version: 2009/09/11
[    5.638865]  gadget: userspace failed to provide iSerialNumber
[    5.644952]  gadget: g_mass_storage ready
[    5.649154] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    5.654745] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    5.662575] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    5.669672] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.677209] usb usb2: Product: MUSB HDRC host driver
[    5.682385] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[    5.687927] usb usb2: SerialNumber: musb-hdrc.0
[    5.707361] hub 2-0:1.0: USB hub found
[    5.711302] hub 2-0:1.0: 1 port detected
[    5.727676] mousedev: PS/2 mouse device common for all mice
[    5.748683] input: ft5x0x_ts as /devices/virtual/input/input0
[    5.949851] uc_reg_value=20
[    5.986629] rtc-ds1307 1-0068: rtc core: registered ds1307 as rtc0
[    5.993097] rtc-ds1307 1-0068: 56 bytes nvram
[    6.008812] i2c /dev entries driver
[    6.018861] Linux video capture inte**ce: v2.00
[    6.037822] usbcore: registered new inte**ce driver uvcvideo
[    6.043812] USB Video Class driver (1.1.1)
[    6.057240] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    6.063703] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[    6.078584] usbcore: registered new inte**ce driver bcm203x
[    6.084492] Bluetooth: Generic Bluetooth USB driver ver 0.6
[    6.098778] usbcore: registered new inte**ce driver btusb
[    6.138266] cpuidle: using governor ladder
[    6.143033] cpuidle: using governor menu
[    6.227460] usbcore: registered new inte**ce driver usbhid
[    6.233286] usbhid: USB HID core driver
[    6.239258] tiadc tiadc: attached adc driver
[    6.270606] _regulator_get: 2-001b supply IOVDD not found, using dummy regulator
[    6.278428] _regulator_get: 2-001b supply DVDD not found, using dummy regulator
[    6.286108] _regulator_get: 2-001b supply AVDD not found, using dummy regulator
[    6.293788] _regulator_get: 2-001b supply DRVDD not found, using dummy regulator
[    6.304372] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[    6.481377] mmc0: host does not support reading read-only switch. assuming write-enable.
[    6.506427] mmc0: new high speed SDHC card at address b368
[    6.526709] mmcblk0: mmc0:b368 LEXAR 3.73 GiB
[    6.551846]  mmcblk0: p1
[    6.797155] ALSA device list:
[    6.800260]   #0: AM335X EVM
[    6.803257] oprofile: hardware counters not available
[    6.808540] oprofile: using timer interrupt.
[    6.813017] nf_conntrack version 0.5.0 (7998 buckets, 31992 max)
[    6.819868] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.825529] TCP cubic registered
[    6.828927] NET: Registered protocol family 17
[    6.833572] can: controller area network core (rev 20090105 abi 8)
[    6.840119] NET: Registered protocol family 29
[    6.844776] can: raw protocol (rev 20090105)
[    6.849237] can: broadcast manager protocol (rev 20090105 t)
[    6.907472] Bluetooth: RFCOMM TTY layer initialized
[    6.912572] Bluetooth: RFCOMM socket layer initialized
[    6.917943] Bluetooth: RFCOMM ver 1.11
[    6.921852] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    6.927394] Bluetooth: BNEP filters: protocol multicast
[    6.932842] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    6.939480] Registering the dns_resolver key type
[    6.944470] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    6.952509] ThumbEE CPU extension supported.
[    6.957035] mux: Failed to setup hwmod io irq -22
[    6.962629] Power Management for AM33XX family
[    6.967507] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    6.974165] Copied the M3 firmware to UMEM
[    6.978539] Cortex M3 Firmware Version = 0x181
[ ? 7.002163] clock: disabling unused clocks to save power
[    7.029577] Detected MACID=d0:5f:b8:dc:b2:2b
[    7.035151] cpsw: Detected MACID = d0:5f:b8:dc:b2:2d
[?  7.059505] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    7.084079] rtc-ds1307 1-0068: setting system clock to 2015-03-24 22:14:30 UTC (1427235270)
[    7.521329] UBIFS: recovery needed
[    7.942268] UBIFS: recovery completed
[    7.946117] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    7.952422] UBIFS: file system size:   1018257408 bytes (994392 KiB, 971 MiB, 1973 LEBs)
[    7.960874] UBIFS: journal size:       10452992 bytes (10208 KiB, 9 MiB, 21 LEBs)
[    7.968685] UBIFS: media format:       w4/r0 (latest is w4/r0)
[    7.974762] UBIFS: default compressor: lzo
[    7.979038] UBIFS: reserved for root:  0 bytes (0 KiB)
[    7.995398] VFS: Mounted root (ubifs filesystem) on device 0:14.
[    8.001721] devtmpfs: error mounting -2
[    8.006075] Freeing init memory: 244K
[    8.009993] Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[    8.022972] Backtrace:
[    8.025563] [<c0017d68>] (dump_backtrace+0x0/0x110) from [<c0510fbc>] (dump_stack+0x18/0x1c)
[    8.034368]  r6:c0041770 r5:c06fd7ec r4:c07713d0 r3:c0721088
[    8.040302] [<c0510fa4>] (dump_stack+0x0/0x1c) from [<c051102c>] (panic+0x6c/0x1a0)
[    8.048309] [<c0510fc0>] (panic+0x0/0x1a0) from [<c0008700>] (init_post+0xa8/0xd8)
[    8.056197]  r3:df02bc00 r2:00000012 r1:00000080 r0:c0612f18
[    8.062121]  r7:00000013
[    8.064776] [<c0008658>] (init_post+0x0/0xd8) from [<c06c1910>] (kernel_init+0x128/0x130)
[    8.073310]  r4:c06fd7ec r3:00000026
[    8.077069] [<c06c17e8>] (kernel_init+0x0/0x130) from [<c0041770>] (do_exit+0x0/0x67c)
一直卡在这个地方,左上角LCD屏上一直是linux的企鹅。
请问这是什么原因?我的资料都是开发板附带光盘中的,开发板是OK333XD
─╄OvЁ等待 发表于 2015-4-2 10:13:11 | 显示全部楼层
光盘里有制作ubi镜像的脚本 tool/pack-ubi-1g.sh  用脚本制作吧
