查看: 14741|回复: 1
[Win CE] 克隆bsp后不能启动
wangjack 发表于 2015-3-25 18:05:19 | 显示全部楼层 |阅读模式
自己克隆了一下wince6.0的bsp,结果发现不能正常启动,信息如下:
Windows CE Kernel for ARM (Thumb Enabled) Built on Nov  3 2010 at 07:30:04
INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xb
CPU CP15 Control Register = 0xc5387f
CPU CP15 Auxiliary Control Register = 0x42
+OALTimerInit(1, 24000, 200)
return I2C1Pads.
g_pCPUInfo=0xb1000000, MPU_CONTEXT_PA=0x40300024, MPU_CONTEXT_VA=0xb1000024, TLB_INV_FUNC_ADDR=0x0, EMIF_REGS=0xb4900000, CM_PER_REGS=0xb0a00000, CM_WKUP_REGS=0xb0a00400, DDR_PHY_REGS=0xb0a12000, SYS_MISC2_REGS=0xb0a11000, suspendState=0
fnCpuStart=0xb1002000 fnOALCPUIdle=0xb1002338 fnInvalidateTlb=0xb1002410 fnRomRestoreLoc=0x4030218c fnCfgEMIFOPP100Loc=0xb1002708, fnCfgEMIFOPP50Loc=0xb1002434
--- High Performance Frequecy is 24 MHz---
OALWatchdogInit is about to be called
[OAL]++OEMEnumExtensionDRAM
    cMemSections = 15
    IMAGE_WINCE_RAM_EX_CA = 0x94b00000
    pMemSections[cSections].dwStart = 0x94b00000
    Extension Size = 0xb500000
[OAL] --OEMEnumExtensionDRAM
PrcmDomainResetRelease DMN 2; mask 1
+PrcmCM3Init: init M3 events and mailbox
-PrcmCM3Init: done with M3
SetOpp to 3
SDHC: CPU revision 0xffffffff
SDHC host controller initialize: m_fastPathSDIO:1 m_fastPathSDMEM:0
SDHCCardDetectIstThreadImpl: CD detect thread.
SDHCCardDetectIstThreadImpl: CD detect inserted.
到sd卡这就不动了,过好久之后重启,如此反复,请问这是什么原因啊?
头像被屏蔽
飞凌-wince 发表于 2015-7-20 17:27:25 | 显示全部楼层
