查看: 12007|回复: 1
[Linux] ok6419烧写成功后 重新启动不能进入界面
我累个去^_^ 发表于 2015-4-3 14:24:03 | 显示全部楼层 |阅读模式
问一下 我用ok6419烧写linux成功后 重新启动不能进入界面 我用DNW显示
yaffs: passed flags ""
devtmpfs: error mounting -2
Freeing init memory: 176K
Failed to execute /linuxrc.  Attempting defaults...
Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[<c003aca8>] (unwind_backtrace+0x0/0xfc) from [<c04a7f2c>] (dump_stack+0x18/0x1c)
[<c04a7f2c>] (dump_stack+0x18/0x1c) from [<c04a7f90>] (panic+0x60/0x1ac)
[<c04a7f90>] (panic+0x60/0x1ac) from [<c00345dc>] (init_post+0xc8/0x140)
[<c00345dc>] (init_post+0xc8/0x140) from [<c00084c8>] (kernel_init+0xf4/0x130)
[<c00084c8>] (kernel_init+0xf4/0x130) from [<c0035a34>] (kernel_thread_exit+0x0/0x8)
请问这是怎么回事 谢谢
kingmeng 发表于 2015-4-11 15:35:03 | 显示全部楼层
楼主你问题解决了吗?我也是这样
