查看: 3308|回复: 1
ok6410a(2g nand 256m ram) 一键烧写成功后启动到下面就不能动弹了。
96
52mcu 发表于 2011-5-31 15:36:30 | 显示全部楼层 |阅读模式
用的是光盘中的bsp编译生成的映像。而用光盘中已编译过的映像可成功启动。
[HSMMC0] Turn OFF the F/B delay control.
[HSMMC0] Setting for 1 bit mode , Clock Rate = 100000 Hz
ERR CMD:5 : ERR CMD:1 : [HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Setting for 1 bit mode , Clock Rate = 100000 Hz
ERR CMD:5 : ERR CMD:8 : ERR CMD:1 : ERR CMD:55 : [HSMMC1] CMD Timeout Error...
<Davicom DM9000A driver for WinCE 6.0>
<DM9:++MiniportIntialize>
[dm9: Tries to map io space with 18000000]
[dm9: The mapped address is D2F60000]
[dm9: Chip signature is 0A469000]
<DM9:--MiniportIntialize>
[UFNPDD] USB Serial Function Class Enabled
[USB] dii.dwIrq = 96
-OALIntrRequestSysIntr(irq = 96, sysIntr = 30)
[SDBUS] SD Card Spec Version : 2.00
[SDBUS] SD/SDHC supports the high-speed mode.
[HSMMC0] Setting for 4 bit mode , Clock Rate = 50000000 Hz
Current Client "Serial_Class"
[USBH] HcdPdd_Init()
[USBH] ++InitializeOHCI()
[USBH] --InitializeOHCI() : Success
-OALIntrRequestSysIntr(irq = 13, sysIntr = 31)
-OALIntrRequestSysIntr(irq = 14, sysIntr = 32)
DEBUG: CreateSerialObject 0
-OALIntrRequestSysIntr(irq = 61, sysIntr = 33)
飞凌-fatfish 发表于 2011-5-31 16:53:44 | 显示全部楼层
好吧,我习惯性的问问楼主,什么pc系统?pc系统是正版的还是ghost还是安装版?
有没有按照飞凌提供的wince手册来安装wince6的集成开发环境。
如果有问的有遗漏,请楼主补充回答
