- 16
贡献56
飞刀4 FD
注册时间2015-4-9
在线时间4 小时
按照手册烧写linux:超级终端监视输出如下,好多坏块,我的是新板子,头一回烧linux,自带的是wince,请问是开发板硬件问题还是光盘中给的软件有问题?
U-Boot 1.3.4 (Apr 12 2014 - 15:19:55)
U-Boot code: C3E00000 -> C3E55360 BSS: -> C3E9BE54
CPU: S3C2416@400MHz
Fclk = 800MHz, Hclk = 133MHz, Pclk = 66MHz
Board: DDR2
DRAM: 64 MB
Flash: 1 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
SD/MMC: SD 2.0 SDHC / Manufacturer: 0x03,OEM: "SD/SU08G",REV: 8.0,S/N: 54443749
1,DATE: 2014/11
SDHC size: 7580 MiB
Net: dm9000
Warning: dm9000 MAC addresses don't match:
Address in SROM is 0d:0e:0d:0e:0d:0e
Address in environment is 10:23:45:67:89:ab
Hit any key to stop autoboot: 1
Start Linux ...
NAND erase: device 0 whole chip
Skipping bad block at 0x00000000
Skipping bad block at 0x00020000
Skipping bad block at 0x00040000
Skipping bad block at 0x00060000
Skipping bad block at 0x00080000
Skipping bad block at 0x000a0000
Skipping bad block at 0x000c0000
Skipping bad block at 0x000e0000
Skipping bad block at 0x00100000
Skipping bad block at 0x00120000
Skipping bad block at 0x00140000
Skipping bad block at 0x00160000
Skipping bad block at 0x00180000
Skipping bad block at 0x001a0000
Skipping bad block at 0x001c0000
Skipping bad block at 0x001e0000
Skipping bad block at 0x00200000
Skipping bad block at 0x00220000
Skipping bad block at 0x00240000
Skipping bad block at 0x00260000
Skipping bad block at 0x00280000
Skipping bad block at 0x002a0000
Skipping bad block at 0x002c0000
Skipping bad block at 0x002e0000
Skipping bad block at 0x05c40000
Skipping bad block at 0x07f40000
Skipping bad block at 0x091a0000
Skipping bad block at 0x0d7c0000
Erasing at 0xffe0000 -- 100% complete.
OK
reading u-boot.bin
349024 bytes read
NAND write: device 0 offset 0x0, size 0x100000
Skip bad block 0x00000000
Writing data at 0x100000 -- 100% complete.
1048576 bytes written: OK
reading zImage
3507864 bytes read
NAND write: device 0 offset 0x300000, size 0x400000
4194304 bytes written: OK
reading root.bin
61860480 bytes read
NAND write: device 0 offset 0x700000, size 0x3c00000
Writing data at 0x412e800 -- 100% complete.
62916480 bytes written: OK
forlinx2416 #
Microsoft Windows CE Bootloader Common Library Version 1.4 Built FOR OK2416Mar
3 2012 10:07:39
Microsoft Windows CE Bootloader for the OK2416 Version 2.4 Built Mar 3 2012
INFO: s2416IOP->GPHCON to: 2900000A:s2416IOP->GPHDAT=7023
Press [ENTER] to launch image stored on boot media, or [SPACE] to enter boot mon
itor.
Initiating image launch in 5 seconds.
dwStartTime= 13729369 dwCurrTime=13729369.
dp_pBootCfg->BootDelay=0 seconds
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
OpenPartition: Invalid MBR. Cannot open existing partition 0x21.
ERROR: ReadOSImageFromBootMedia: Failed to open existing partition.
OEMPlatformInit ERROR: Failed to load kernel region into RAM.
