- 11
贡献23
飞刀0 FD
注册时间2015-7-7
在线时间6 小时
新买的FL2416开发板(默认是WIN CE6.0),想换为Linux系统,按照用户手册步骤开始操作,已完成了SD卡制作和串口连接,将三个文件(u-boot.bin,root.bin,zImage)拷入到了SD卡可以打印提示信息,先是直接SD卡上电启动不行,之后又擦出了原有的wince数据又试了下还是不行,只读取到SD信息时就卡住不动了,没有开始烧录,具体情况见下面打印信息。请问各位大侠这是哪里的问题呢?
刚才试了下wince的镜像烧写,是成功的,现在怀疑是Linux的镜像有问题,或者是这板子就只能烧录wince?
1、先进eboot擦出了原有wince数据,输入a
Microsoft Windows CE Bootloader Common Library Version 1.4 Built FOR OK2416Mar 3 2012 10:07:39
Microsoft Windows CE Bootloader for the OK2416 Version 2.4 Built Mar 3 2012
INFO: s2416IOP->GPHCON to: 2900000A:s2416IOP->GPHDAT=7023
Initiating image launch in 5 seconds.
dwStartTime= 19046186 dwCurrTime=19046186.
dp_pBootCfg->BootDelay=4 seconds
Ethernet Boot Loader Configuration:
0) IP address: 192.168.1.6
1) Subnet mask: 255.255.255.0
2) DHCP: Enabled
3) Boot delay: 5 seconds
4) Reset to factory default configuration
5) Startup image: LAUNCH EXISTING
6) Program disk image into Nand Flash: Enabled
7) Program DM9000A MAC address (10:23:45:67:89:AB)
8) KITL Configuration: ENABLED
9) Format Boot Media for BinFS
A) Erase All Blocks
B) Mark Bad Block at Reserved Block
C) Clean Boot Option: FALSE
D) Download image now
E) Erase Reserved Block
F) Low-level format the Smart Media card
L) LAUNCH existing Boot Media image
R) Read Configuration
P) Download and Write Logo Picture to NAND Storage(USB)
U) DOWNLOAD image now(USB)
W) Write Configuration Right Now
Enter your selection: a
All block(2048) Erase...
found a bad block (0x28)!
found a bad block (0x2da)!
found a bad block (0x517)!
found a bad block (0x6a5)!
2、SD模式启动后只打印了一下信息:
U-Boot 1.3.4 (Apr 12 2014 - 15:19:55)
U-Boot code: C3E00000 -> C3E55360 BSS: -> C3E9BE54
CPU: S3C2416@400MHz
Fclk = 800MHz, Hclk = 133MHz, Pclk = 66MHz
Board: DDR2
DRAM: 64 MB
Flash: 1 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
SD/MMC: SD 2.0 SDHC / Manufacturer: 0x03,OEM: "SD/SU16G",REV: 8.0,S/N: 404970027,DATE: 2012/5
SDHC size: 15193 MiB
