查看: 4840|回复: 0
TE9263 WinCE image 問題
chaser2802001 发表于 2010-3-30 11:06:14 | 显示全部楼层 |阅读模式
INFO : Low Level Init : OK
Init Data flash
Starting eboot ...
Master Clock is 47996928 Hz
Target processor Frequency is 200 MHz
Target Bus Frequency is 50 MHz
Master Clock is 49996800 Hz
vga init 0x4::0x20
                  VGA INIT DONE
Debug serial initialized ........OK
Microsoft Windows CE Ethernet Bootloader Common Library Version 1.1 Built Dec 12 2007 11:04:22
Microsoft Wind鵁s CE 5.0 Ethernet Bootloader for the AT91SAM926xEK board
Adaptation performed by ADENEO (c) 2007
Master Clock is 49996?0 Hz
Press [ENTER] to launch image stored in flash or [SPACE] to cancel.
Initiating image launch in    0 seconds
System ready!
Preparing for download...
+OEMLaunch (dwImageStart=0,dwImageLength=0,dwLaunchAddr=0
Initialize image flash .......Master Clock is 49996800 Hz
->ConfigChip
<耶onfigChip
->LoadBlocksInfo
LoadBlocksInfo::g_pBlocksInfo : 0x80050000
<-LoadBlocksInfo
OK
FMD_DirectRead to 0x8006c000 from @0 33554432 bytes
0IsValidBlock_Sect : Invalid blockFMD_DirectWrite block is not valid 00000  5120
01?RomBOOT
Init Data flash
Starting eboot ...
Master Clock is Target processor Frequency is Master Clock is vga init 0xVGA INIT DONE
Microsoft Windows CE 5.0 Ethernet Bootloader for the AT91SAM926xEK board
System ready!
->ConfigChip
<-ConfigChip
->LoadBlocksInfo
<-LoadBlocksInfo
OK
Launching windows CE image by jumping at address 0x2006d000
我的問題是它一直重複,但不可以運行WinCE,可有辦法嗎?
