查看: 8782|回复: 0
启动时出现 init: untracked PID **x 问题
i.MX6Q通行证i.MX6UL通行证RK3588通行证i.MX RT通行证
weichushun 发表于 2015-11-8 23:26:29 | 显示全部楼层 |阅读模式
现象如下:
eth0: link down
*****************start init *****************
yaffs: dev is 32505859 name is "mtdblock3" rw
yaffs: passed flags ""
init (53): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj inste
ad.
/system/bin/sh: can't access tty; job control turned off
/ # enabling adb
adb_open
warning: `rild' uses 32-bit capabilities (legacy support in use)
s3c-nand: 1 bit(s) error detected, corrected successfully
s3c-rtc s3c64xx-rtc: rtc only supports 100 years
alarm_set_rtc: Failed to set RTC, time will be lost on reboot
alarm_release: clear alarm, pending 0
request_suspend_state: wakeup (3->0) at 42473201294 (1970-01-02 00:00:09.3972615
04 UTC)
init: untracked pid 63 exited
init: untracked pid 67 exited
request_suspend_state: wakeup (0->0) at 64726745400 (1970-01-02 00:00:31.6508052
49 UTC)
FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will b
e case sensitive!
不知道如何解决?谢谢!
