- 27
贡献160
飞刀51 FD
注册时间2016-2-24
在线时间5 小时
root@ok335x:~# 3g_test start_ums 3812
ZET-MF190
HW-E1750
HW-E261
ZET-AC582
ZET-AC2787
ZET-A356
FL-AD3812
root@ok335x:~#
root@ok335x:~#
root@ok335x:~# 3g_test FL-AD3812
start_ums or start_ppp or stop_ppp
root@ok335x:~# 3g_test start_ums FL-AD3812
wcdma-AD3812
pppd call wcdma-AD3812
Starting usb_modeswitch ...
No default vendor/product ID given. Aborting.
/forlinx/bin/3g_test: line 62: 1: command not found
SUCCESS: starting usb_modeswitch.
start_usb_modeswitch
root@ok335x:~# lsusb
lsusb: cannot open "/usr/share/usb.ids", No such file or directory
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 19d2:ffeb
Bus 002 Device 001: ID 1d6b:0002
root@ok335x:~# ifconfig
eth0 Link encap:Ethernet HWaddr 68:C9:0B:E7:BC:00
inet addr:192.168.0.232 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:131 errors:0 dropped:0 overruns:0 frame:0
TX packets:131 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:313127 (305.7 KiB) TX bytes:313127 (305.7 KiB)
