查看: 23002|回复: 1
[Linux] OK335xS-Ⅱ 新买的 跑不起来
A40i\T3\T507\T527通行证AM335x通行证
cwd502 发表于 2016-3-2 16:46:16 | 显示全部楼层 |阅读模式
按照说明书来烧录的,就是跑不起来,卡死在下面:
[    3.093853] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    3.103743] rtc-ds1307 2-0068: setting system clock to 2016-03-02 17:54:41 UTC (1456941281)
[    3.150009] UBIFS: recovery needed
[    3.214103] UBIFS error (pid 1): ubifs_check_node: bad CRC: calculated 0x590020ca, read 0x136468ca
[    3.223475] UBIFS error (pid 1): ubifs_check_node: bad node at LEB 870:104176
[    3.230915] UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 870:104176
[    3.245993] UBIFS error (pid 1): ubifs_scan: LEB 870 scanning failed
[    3.253425] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
[    3.260780] Please append a correct "root=" boot option; here are the available partitions:
[    3.269565] 1f00            2048 mtdblock0  (driver?)
[    3.274852] 1f01            2048 mtdblock1  (driver?)
[    3.280122] 1f02            2048 mtdblock2  (driver?)
[    3.285413] 1f03            2048 mtdblock3  (driver?)
[    3.290683] 1f04            2048 mtdblock4  (driver?)
[    3.295965] 1f05            2048 mtdblock5  (driver?)
[    3.301234] 1f06            8192 mtdblock6  (driver?)
[    3.306525] 1f07          241664 mtdblock7  (driver?)
[    3.311804] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    3.320419] Backtrace:
[    3.323012] [<c0017d68>] (dump_backtrace+0x0/0x110) from [<c050d970>] (dump_stack+0x18/0x1c)
[    3.331818]  r6:c7030000 r5:c06ec414 r4:c076bd90 r3:c071cf08
[    3.337743] [<c050d958>] (dump_stack+0x0/0x1c) from [<c050d9e0>] (panic+0x6c/0x1a0)
[    3.345745] [<c050d974>] (panic+0x0/0x1a0) from [<c06bccb4>] (mount_block_root+0x184/0x228)
[    3.354459]  r3:c071cf08 r2:00000000 r1:c701df78 r0:c060f830
[    3.360371]  r7:00008000
[    3.363026] [<c06bcb30>] (mount_block_root+0x0/0x228) from [<c06bcfd0>] (prepare_namespace+0xac/0x1e0)
[    3.372745] [<c06bcf24>] (prepare_namespace+0x0/0x1e0) from [<c06bc90c>] (kernel_init+0x124/0x130)
[    3.382091]  r5:c06f8688 r4:c06f8688
[    3.385846] [<c06bc7e8>] (kernel_init+0x0/0x130) from [<c0041624>] (do_exit+0x0/0x67c)
[    3.394105]  r5:c06bc7e8 r4:00000000
飞凌-unix 发表于 2016-3-3 13:14:30 | 显示全部楼层
看打印信息是文件系统没有烧写正确,您可以把您板子的详细信息,烧写时候使用的镜像,以及烧写时候的打印信息发到linux@forlinx.com邮箱里边,我们具体帮您分析一下
