查看: 30794|回复: 4
[Ubuntu] LTIB
i.MX6Q通行证
exclusive 发表于 2016-6-3 17:27:17 | 显示全部楼层 |阅读模式
LTIB,一直编译不过
i.MX6Q通行证
楼主| exclusive 发表于 2016-6-3 17:28:50 | 显示全部楼层
Build Failed
root@ubuntu:/home/turns/Desktop/ltib/ltib# cat host_config.log
Processing platform: host support
Processing: rpm-fs
ERROR: /tmp/rpm-root/RPMS/x86_64/rpm-fs-4.0.4-1.x86_64.rpm
would clobber '/reescale/ltib'
traceback:
main::check_host_clobber:2693
  main::build_rpm:918
   main::f_buildrpms:992
    main::check_rpm_setup:2424
     main::host_checks:1435
      main:554
Started: Fri Jun  3 02:18:08 2016
Ended:   Fri Jun  3 02:18:10 2016
Elapsed: 2 seconds
Build Failed
i.MX6Q通行证
楼主| exclusive 发表于 2016-6-3 17:29:51 | 显示全部楼层
有谁能帮忙下吗-----------------------------?
i.MX6Q通行证XX18通行证i.MX6UL通行证TCU通行证AM335x通行证
impscott 发表于 2016-6-4 09:17:26 | 显示全部楼层
你好,按照手册就可以把环境搭建好,不需要搭建这个
i.MX6Q通行证
楼主| exclusive 发表于 2016-6-14 19:14:17 | 显示全部楼层
encrypt@encrypt-machine:~/projects/L3.0.35_4.1.0/ltib$ ./ltib -m config
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/(%{ <-- HERE ?([^}]+)}?)/ at /home/encrypt/projects/L3.0.35_4.1.0/ltib/bin/Ltibutils.pm line 237.
Can't use 'defined(@array)' (Maybe you should just omit the defined()?) at /home/encrypt/projects/L3.0.35_4.1.0/ltib/bin/Ltibutils.pm line 362.
Compilation failed in require at ./ltib line 39.
BEGIN failed--compilation aborted at ./ltib line 39.
