查看: 11861|回复: 1
[Android] 刚买回的板子,SD卡烧写安卓完成后,开机界面花屏。并且停在那不动了,
ljc710871968 发表于 2016-7-22 16:56:58 | 显示全部楼层 |阅读模式
哪位大神帮我看看
CPU:  S5PV210@1000MHz(OK)
        APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz
        MPLL = 667MHz, EPLL = 80MHz
                       HclkDsys = 166MHz, PclkDsys = 83MHz
                       HclkPsys = 133MHz, PclkPsys = 66MHz
                       SCLKA2M  = 200MHz
Serial = CLKUART
Board:   SMDKV210
DRAM:    512 MB
Flash:   0 kB
SD/MMC:  3781MB
NAND:    manufac=ec dev_id=d3
Nandflash:ChipType= SLC  ChipName=Samsung K9K8G08U0Enand.c board_nand_init:1627
Samsung K9K8G08U0E No  No Calc pagesize, blocksize, erasesize,  use ids table .............
NandFlash:name=NAND 1GiB 3,3V 8-bit,id=d3, pagesize=2048 ,chipsize=1024 MB,erasesize=131072 oobsize=64
NandFlash Size is 1024 MB
*** Warning - using default environment
Video: 800x480x16 73kHz 150Hz
Video: video_hw_init complete
Video: Drawing the logo ...
checking mode for fastboot ...
Main area read (40 blocks):
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
CPU: ARMv7 Processor [412fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: SMDKV210
CPU S5PV210/S5PC110 (id 0x43110220)
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 86148
call setlcdsize 70
S3C Power Management, Copyright 2004 Simtec Electronics
---pmem_start is 0x49ea0000
et2_pud=4000forlinx.debug GPH1PUD=5591
s3c_adc_set_platdata CONFIG_S5P_ADC is ok
call sido_reset_wifi ok
        SHBAE pixclock: 17104
win->id=2, pmem_start=0x4a41f000
Start display and show logo
leds        led initialized
Initializing hello device.
Succedded to initialize hello device.
pwm        initialized
irda        initialized
PA FB = 0x4A41F000, bits per pixel = 32
screen width=800 height=480 va=0xea41f000 pa=0x4a41f000
xres_virtual = 800, yres_virtual = 960, xoffset = 0, yoffset = 0
fb_size=3842048
Back frameBuffer[0].VAddr=ea596000 PAddr=4a596000 size=1536000
manufac=ec,dev_id=d3
Nandflash:ChipType= SLC  ChipName=Samsung K9K8G08U0E s3c_nand_probe 1471
*******************maf_id=ec,dev_id=d3
RTL871X: module init start
RTL871X: rtl8189es v4.3.0.2_10792.20140318
RTL871X: build time: Dec 22 2014 17:05:48
RTL871X: module init ret=0
gpio-keys init
uc_reg_value=42
mma7660 ret result =0
*****************start init *****************
飞凌-chongzi 发表于 2016-7-25 11:21:30 | 显示全部楼层
您好,您是否尝试重新烧写
另外,看一下屏幕的排线是否连接正常
