查看: 6114|回复: 0
[Linux] 移植到1GB nandflash平台的問題
cjasionchen 发表于 2016-7-27 13:51:58 | 显示全部楼层 |阅读模式
您好:請問一下,將原本在256MB的nandflash 平台啟動的uboot,kernel,及rootfs移植到1GB的nandflash的平台,卻出現以下的錯誤
U-Boot 1.1.6 (Sep 19 2014 - 10:00:03) for SMDK6410
**    Updated for OK6410  TE6410 Board  **
**    Version (2012-09-23)          **
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NAND:    1024 MB
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x500000, size 0x500000
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 3.0.1 (root@chenfengpl) (gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67) ) #3 Wed Jul 27 11:18:20 CST 2016
Ignoring unrecognised tag 0x54410008
Kernel command line: root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200
Memory: 256MB = 256MB total
Memory: 253452k/253452k available, 8692k reserved, 0K highmem
Virtual kernel memory layout:
    DMA     : 0xff600000 - 0xffe00000   (   8 MB)
    vmalloc : 0xd0800000 - 0xf4000000   ( 568 MB)
      .init : 0xc0008000 - 0xc004e000   ( 280 kB)
      .text : 0xc004e000 - 0xc05a3000   (5460 kB)
      .data : 0xc05a4000 - 0xc05dda90   ( 231 kB)
       .bss : 0xc05ddab4 - 0xc063bce0   ( 377 kB)
NR_IRQS:246 nr_irqs:246 246
console [ttySAC0] enabled
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
devtmpfs: initialized
SMDK6410: SPI Register...
SMDK6410: SPI Register done...
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
PL080: IRQ 73, at d0804000, channels 0..8
PL080: IRQ 74, at d0806000, channels 8..16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP reno registered
BAT GPIO initial, ver 0.1 2012-0910
BAT Power Management driver initial, ver.0.1 2012-09-19
audit: initializing netlink socket (disabled)
type=2000 audit(0.270:1): initialized
msgmni has been set to 495
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
LCD TYPE :: LTE480WV will be initialized
Console: switching to colour frame buffer device 60x34
fb0: s3cfb frame buffer device
fb1: s3cfb frame buffer device
fb2: s3cfb frame buffer device
fb3: s3cfb frame buffer device
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
vcan: Virtual CAN inte**ce driver
slcan: serial line CAN inte**ce driver
slcan: 10 dynamic inte**ce channels.
CAN device driver inte**ce
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at d080a000,d0c00004 IRQ 108 MAC: 08:90:00:a0:90:90 (platform data)
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 3.0.1 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new inte**ce driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new inte**ce driver usb-storage
usbcore: registered new inte**ce driver usbserial
USB Serial support registered for generic
usbcore: registered new inte**ce driver usbserial_generic
USB Serial support registered for GSM modem (1-port)
usbcore: registered new inte**ce driver option
option: v0.7.2:USB Driver for GSM modems
usbcore: registered new inte**ce driver pl2303
dummy_hcd dummy_hcd: USB Host+Gadget Emulator, driver 02 May 2005
dummy_hcd dummy_hcd: Dummy host controller
dummy_hcd dummy_hcd: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Dummy host controller
usb usb2: Manufacturer: Linux 3.0.1 dummy_hcd
usb usb2: SerialNumber: dummy_hcd
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: gpio-keys as /devices/platform/gpio-keys/input/input0
GPIO keys poll driver initial, ver.0.1 2012-09-11
input: gpio-keys as /devices/platform/gpio-keys-poll/input/input1
i2c /dev entries driver
Linux media inte**ce: v0.10
Linux video capture inte**ce: v2.00
i2c-core: driver [tuner] using legacy suspend method
i2c-core: driver [tuner] using legacy resume method
usbcore: registered new inte**ce driver usbvision
USBVision USB Video Device Driver for Linux : 0.9.10
usbcore: registered new inte**ce driver uvcvideo
USB Video Class driver (v1.1.0)
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
usbhid: USB HID core driver
TCP cubic registered
s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-01 14:49:17 UTC (946738157)
Root-NFS: no NFS server address
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
Backtrace:
[<c0052c50>] (dump_backtrace+0x0/0x10c) from [<c0429898>] (dump_stack+0x18/0x1c)
r6:c0028994 r5:c05de770 r4:c05de770 r3:79f6f35f
[<c0429880>] (dump_stack+0x0/0x1c) from [<c0429900>] (panic+0x64/0x188)
[<c042989c>] (panic+0x0/0x188) from [<c0008e48>] (mount_block_root+0x180/0x250)
r3:c05a6008 r2:79f6f35f r1:cf833f54 r0:c052c960
[<c0008cc8>] (mount_block_root+0x0/0x250) from [<c0008fc0>] (mount_root+0xa8/0xcc)
[<c0008f18>] (mount_root+0x0/0xcc) from [<c0009118>] (prepare_namespace+0x134/0x198)
r5:c00289a9 r4:c05ddb20
[<c0008fe4>] (prepare_namespace+0x0/0x198) from [<c0008460>] (kernel_init+0xec/0x120)
r5:c0027f70 r4:c0027f70
[<c0008374>] (kernel_init+0x0/0x120) from [<c006d9cc>] (do_exit+0x0/0x700)
r5:c0008374 r4:00000000
請問該如何修改kernel中的程式,才能正確的掛載nfs,謝謝
