查看: 48061|回复: 3
[Linux] Linux QT 无LCD板子,系统无法正常启动
i.MX6UL通行证i.MX6Q通行证
guoww 发表于 2016-9-22 00:23:11 | 显示全部楼层 |阅读模式
I.MX6Q无LCD 999元的板子,按照用户手册成功移植完􀀆􀀒qt-SabreSD-eMMC的内核和文件系统,重启时挂载下面Log中无法正常启动,请问专家们这种问题应该怎么处理?(当初没买LCD的原因就是想用HDMI直接输出图像)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 01:26:08 UTC (5168)
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p1): using internal journal
EXT3-fs (mmcblk0p1): recovery complete
EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:1.
Freeing init memory: 208K
starting pid 1469, tty '': '/etc/rc.d/rcS'
Mounting /proc and /sys
Starting the hotplug events dispatcher udevd
udevd (1478): /proc/1478/oom_adj is deprecated, please use /proc/1478/oom_score_adj instead.
Synthesizing initial hotplug events
Mounting filesystems
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
Starting inetd:
/etc/rc.d/rc.local: line 57: /forlinx/web/lighttpd/sbin/lighttpd: No such file or directory
xres = 800, yres = 480
飞凌-chongzi 发表于 2016-9-26 08:42:52 | 显示全部楼层
    您现在处在校准屏幕的状态,但是您没买LCD屏,所以无法进行校准也就无法进入系统
    您可以参考手册的附录三跳过校准界面,另外您想使用HDMI输出,应在uboot阶段进行显示屏的设置,这个参照附录二即可
    建议您熟读手册再进行操作
好的,谢谢支持  详情 回复 发表于 2016-9-26 19:45
i.MX6UL通行证i.MX6Q通行证
楼主| guoww 发表于 2016-9-26 19:45:51 | 显示全部楼层
    您可以 ...
谢谢回复。我刚看了用户手册,附录二和三是虚拟机的安装和ubuntu的设置《i.MX6-Linux用户手册-v2.6-2015-12-04.pdf》,没见你说的那些噢。
已从《OKMX6X-S2产品资料》下载到,谢谢  详情 回复 发表于 2016-9-26 21:00
i.MX6UL通行证i.MX6Q通行证
楼主| guoww 发表于 2016-9-26 21:00:15 | 显示全部楼层
谢谢回复。我刚看了用户手册,附录二和三是虚拟机的安装和ubuntu的设置《i.MX6-Linux用户手册-v2.6-2015-12 ...
已从《OKMX6X-S2产品资料》下载到,谢谢:D
