查看: 16609|回复: 10
AR9271 WIFI USB网卡怎么用???
RK3506通行证
abnerle 发表于 2011-6-18 09:41:31 | 显示全部楼层 |阅读模式
我在网上买了一个AR9271 WIFI USB网卡,但不知道怎么用,有人用过嘛,指导一下,2.6.33kernel中已经包含了ar9271的驱动
我看这个网卡,蛮强大的,双天线的,所以才买了,但是不会用,查看USB总线,可以看到网卡已经被识别,出现USB设备里面,atheros XXXX的信息
相关帖子
飞凌-fatfish 发表于 2011-6-18 17:39:50 | 显示全部楼层
用 ifconfig -a命令能看到什么?贴出来看看
RK3506通行证
楼主| abnerle 发表于 2011-6-24 22:48:16 | 显示全部楼层
好像根本就没出来,eth0是本地连接使用的,我自己设置的
ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:0C:29:D8:0D:56
          inet addr:192.168.137.128  Bcast:192.168.137.255  Mask:255.255.255.0
          inet6 addr: fe80::20c:29ff:fed8:d56/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:50 errors:0 dropped:0 overruns:0 frame:0
          TX packets:87 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:5175 (5.0 KiB)  TX bytes:13395 (13.0 KiB)
          Interrupt:19 Base address:0x2000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:10 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:796 (796.0 b)  TX bytes:796 (796.0 b)
virbr0    Link encap:Ethernet  HWaddr D2:40:A2:62:84:80
          inet addr:192.168.122.1  Bcast:192.168.122.255  Mask:255.255.255.0
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:17 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:4595 (4.4 KiB)
USB信息如下:
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0cf3:9271 Atheros Communications, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
指点一下,怎么搞这个.............
RK3506通行证
楼主| abnerle 发表于 2011-6-25 11:02:02 | 显示全部楼层
dmesg
看到的信息如下:已经识别出了网卡idProduct=9271,Manufacturer: ATHEROS
sb 1-2: New USB device found, idVendor=0cf3, idProduct=9271
usb 1-2: New USB device strings: Mfr=16, Product=32, SerialNumber=48
usb 1-2: Product: UB91
usb 1-2: Manufacturer: ATHEROS
usb 1-2: SerialNumber: 12345
飞凌-fatfish 发表于 2011-6-25 13:58:10 | 显示全部楼层
你按照飞凌2.6.36手册中使用sdio wifi的方法设置一下usb wifi
然后把信息贴一下
RK3506通行证
楼主| abnerle 发表于 2011-6-25 18:49:45 | 显示全部楼层
手册中的wlan0并没有啊,所以我自己新建了一个,选网卡设备的时候没有出现ATHEROS或者AR9271,所以选了USB CDCXXXX的那个,建好之后,根本无法激活,所以ifconfig -a里面也不出现,
飞凌-fatfish 发表于 2011-7-1 09:27:09 | 显示全部楼层
用virbr0 这个节点就行了
不是所有的节点都是一样的名字
myem007 该用户已被删除
myem007 发表于 2011-7-1 20:11:26 | 显示全部楼层
RK3506通行证
楼主| abnerle 发表于 2011-7-3 21:24:45 | 显示全部楼层
回复 8# myem007
    楼上指导一下,如何使用,是USB的,但不会使用,显示的USB2.0设备
networkdev 该用户已被删除
networkdev 发表于 2011-9-2 18:14:09 | 显示全部楼层
