查看: 43411|回复: 10
[Linux] 板载WIFI使用不能设置essid
i.MX6UL通行证i.MX6Q通行证
流沙血海 发表于 2017-6-28 11:39:26 | 显示全部楼层 |阅读模式
软件手册--板载WIFI的使用,测试的时候,发送iwconfig wlan0 essid "XTG-2F"命令后,调试不通过,具体现象如下,XTG-2F是我们这边无线,192.168.100.1是网关
root@freescale ~$ ifconfig wlan0 192.168.100.232
root@freescale ~$ iwconfig wlan0 essid "XTG-2F"
[  145.990313] RTL871X: set ssid [XTG-2F] fw_state=0x00000008
root@freescale ~$ [  146.026055] RTL871X: start auth
[  146.032089] RTL871X: auth success, start assoc
[  146.043130] RTL871X: indicate disassoc
之后就卡在这里了
i.MX6UL通行证i.MX6Q通行证
楼主| 流沙血海 发表于 2017-6-28 11:41:13 | 显示全部楼层
全部调试信息如下:
root@freescale ~$ insmod /lib/modules/3.14.38-6UL_ga\+ge4944a5/kernel/drivers/ne
t/wireless/realtek/rtl8723BU/8723bu.ko
[   20.859720] RTL871X: module init start
[   20.868776] RTL871X: rtl8723bu v4.3.16_14189.20150519_BTCOEX20150119-5844
[   20.876133] RTL871X: build time: Jan 21 2016 14:03:53
[   20.881213] RTL871X: rtl8723bu BT-Coex version = BTCOEX20150119-5844
[   21.041477] RTL871X: rtw_ndev_init(wlan0)
[   21.073390] usbcore: registered new inte**ce driver rtl8723bu
[   21.079256] RTL871X: module init ret=0
wlan0     Link encap:Ethernet  HWaddr 38:A2:8C:70:77:FF
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
root@freescale ~$ ifconfig eth0 down
root@freescale ~$ ifconfig wlan0 up
[   86.411407] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
root@freescale ~$ iwlist wlan0 scan
wlan0     Scan completed :
          Cell 01 - Address: C4:36:55:7B:F8:14
                    ESSID:"XTG-2F"
                    Protocol:IEEE 802.11bgn
                    Mode:Master
                    Frequency:2.412 GHz (Channel 1)
                    Encryption key:on
                    Bit Rates:144 Mb/s
                    Extra:wpa_ie=dd160050f20101000050f20401000050f20401000050f202
                    IE: WPA Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
                    Extra:
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                    Quality=100/100  Signal level=100/100
                    Extra:fm=0003
          Cell 02 - Address: 2E:B7:0D:2A:6F:39
                    ESSID:"XTG1"
                    Mode:Master
                    Encryption key:on
                    Bit Rates:150 Mb/s
                    Extra:rsn_ie=30140100000fac040100000fac040100000fac020000
                        Group Cipher : CCMP
                    Quality=100/100  Signal level=62/100
                    Extra:fm=0003
          Cell 03 - Address: 3C:33:00:D6:96:AE
                    ESSID:"sdjcsy"
                    Mode:Master
                    Encryption key:on
                    Bit Rates:300 Mb/s
                        Group Cipher : CCMP
                    Quality=72/100  Signal level=60/100
                    Extra:fm=0003
          Cell 04 - Address: 3C:33:00:D6:96:AE
                    ESSID:""
                    Mode:Master
                    Encryption key:on
                    Bit Rates:300 Mb/s
                        Group Cipher : CCMP
                    Quality=61/100  Signal level=60/100
                    Extra:fm=0001
          Cell 05 - Address: BC:46:99:C3:F1:18
                    ESSID:"TP-LINK_F118"
                    Mode:Master
                    Encryption key:on
                    Bit Rates:300 Mb/s
                    IE: WPA Version 1
                        Group Cipher : CCMP
                    Extra:
                        Group Cipher : CCMP
                    Quality=0/100  Signal level=58/100
                    Extra:fm=0001
          Cell 06 - Address: 44:6E:E5:9F:65:50
                    ESSID:"HUAWEI-GRE7ET"
                    Mode:Master
                    Frequency:2.437 GHz (Channel 6)
                    Encryption key:on
                    Bit Rates:300 Mb/s
                        Group Cipher : CCMP
                    IE: Unknown: DD8B0050F204104A0001101044000102103B00010310470010123456789ABCDEF01234446EE59F65501021000F48756177656920436F2E2C206C74641023000B576972656C657373204150102400033132331042000531323334351054000800060050F20400011011001248756177656920576972656C6573732041501008000206801049000600372A000120
                    Quality=36/100  Signal level=72/100
                    Extra:fm=0003
          Cell 07 - Address: 82:89:17:C4:A8:05
                    ESSID:"ausforex"
                    Mode:Master
                    Encryption key:on
                    Bit Rates:300 Mb/s
                        Group Cipher : CCMP
                    Quality=36/100  Signal level=63/100
                    Extra:fm=0003
          Cell 08 - Address: B8:F8:83:33:95:63
                    ESSID:"TP-LINK_Zhang"
                    Mode:Master
                    Encryption key:on
                    Bit Rates:300 Mb/s
                    IE: WPA Version 1
                        Group Cipher : CCMP
                    Extra:
                        Group Cipher : CCMP
                    Quality=5/100  Signal level=58/100
                    Extra:fm=0003
          Cell 09 - Address: C8:3A:35:17:F1:D0
                    ESSID:"Tenda_17F1D0"
                    Mode:Master
                    Frequency:2.447 GHz (Channel 8)
                    Encryption key:on
                    Bit Rates:300 Mb/s
                    Extra:wpa_ie=dd180050f20101000050f20401000050f20401000050f2020c00
                    IE: WPA Version 1
                        Group Cipher : CCMP
                    Quality=36/100  Signal level=67/100
                    Extra:fm=0003
          Cell 10 - Address: 9C:21:6A:E6:FA:42
                    ESSID:"XTG"
                    Mode:Master
                    Frequency:2.462 GHz (Channel 11)
                    Encryption key:on
                    Bit Rates:300 Mb/s
                    IE: WPA Version 1
                        Group Cipher : CCMP
                    Extra:
                        Group Cipher : CCMP
                    IE: Unknown: DD8E0050F204104A0001101044000102103B00010310470010000000000000100000009C216AE6FA421021000754502D4C494E4B10230009544C2D57523834324E10240003342E3010420007312E312E312E331054000800060050F204000110110018576972656C657373204E20526F757465722057523834324E100800022288103C0001011049000600372A000120
                    Quality=36/100  Signal level=70/100
                    Extra:fm=0003
          Cell 11 - Address: 30:FC:68:86:73:0A
                    ESSID:"YYCY-001"
                    Mode:Master
                    Encryption key:on
                    Bit Rates:144 Mb/s
                    IE: WPA Version 1
                        Group Cipher : CCMP
                    Extra:
                        Group Cipher : CCMP
                    Quality=10/100  Signal level=58/100
                    Extra:fm=0001
root@freescale ~$
root@freescale ~$
i.MX6UL通行证i.MX6Q通行证
楼主| 流沙血海 发表于 2017-6-28 14:26:48 | 显示全部楼层
用USB WIFI的方式调试了一下,因为我的WIFI是WPA加密,所以要用这种方式,设置完成后,ping www.baidu.com 结果如下
64 bytes from 139.129.150.193: seq=85 ttl=54 time=10.837 ms
64 bytes from 139.129.150.193: seq=86 ttl=54 time=10.419 ms
64 bytes from 139.129.150.193: seq=87 ttl=54 time=12.141 ms
64 bytes from 139.129.150.193: seq=88 ttl=54 time=21.858 ms
64 bytes from 139.129.150.193: seq=89 ttl=54 time=12.071 ms
64 bytes from 139.129.150.193: seq=90 ttl=54 time=10.943 ms
64 bytes from 139.129.150.193: seq=91 ttl=54 time=11.642 ms
64 bytes from 139.129.150.193: seq=92 ttl=54 time=12.887 ms
64 bytes from 139.129.150.193: seq=93 ttl=54 time=10.843 ms
[  522.413563] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
64 bytes from 139.129.150.193: seq=94 ttl=54 time=143.747 ms
64 bytes from 139.129.150.193: seq=95 ttl=54 time=11.628 ms
64 bytes from 139.129.150.193: seq=96 ttl=54 time=915.991 ms
64 bytes from 139.129.150.193: seq=97 ttl=54 time=10.592 ms
64 bytes from 139.129.150.193: seq=98 ttl=54 time=14.788 ms
64 bytes from 139.129.150.193: seq=99 ttl=54 time=11.127 ms
[  528.494174] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
64 bytes from 139.129.150.193: seq=100 ttl=54 time=17.493 ms
64 bytes from 139.129.150.193: seq=101 ttl=54 time=36.216 ms
64 bytes from 139.129.150.193: seq=102 ttl=54 time=10.671 ms
64 bytes from 139.129.150.193: seq=103 ttl=54 time=11.120 ms
64 bytes from 139.129.150.193: seq=104 ttl=54 time=24.322 ms
[  533.716793] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
64 bytes from 139.129.150.193: seq=105 ttl=54 time=21.910 ms
64 bytes from 139.129.150.193: seq=106 ttl=54 time=11.044 ms
64 bytes from 139.129.150.193: seq=107 ttl=54 time=11.389 ms
64 bytes from 139.129.150.193: seq=108 ttl=54 time=10.604 ms
64 bytes from 139.129.150.193: seq=109 ttl=54 time=15.415 ms
[  538.934082] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
64 bytes from 139.129.150.193: seq=110 ttl=54 time=13.713 ms
64 bytes from 139.129.150.193: seq=111 ttl=54 time=12.427 ms
64 bytes from 139.129.150.193: seq=112 ttl=54 time=10.959 ms
64 bytes from 139.129.150.193: seq=113 ttl=54 time=10.762 ms
64 bytes from 139.129.150.193: seq=114 ttl=54 time=12.499 ms
64 bytes from 139.129.150.193: seq=115 ttl=54 time=16.146 ms
出现了很多警告,不知道这些警告是什么意思,怎么消除?
i.MX6UL通行证i.MX6Q通行证
楼主| 流沙血海 发表于 2017-6-28 14:41:25 | 显示全部楼层
[ 1398.863883] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1404.725290] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1428.618983] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1436.988968] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1443.114222] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1448.142143] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1460.839740] RTL871X: ERROR rtw_check_bcn_info: start new beacon (seq=613)
[ 1460.846664] RTL871X: ERROR rtw_check_bcn_info: cur beacon key
[ 1460.852514] RTL871X: ERROR rtw_check_bcn_info: new beacon key
[ 1461.044490] RTL871X: ERROR rtw_check_bcn_info: new beacon again (seq=629)
[ 1461.147367] RTL871X: ERROR rtw_check_bcn_info: start new beacon (seq=634)
[ 1461.154286] RTL871X: ERROR rtw_check_bcn_info: new beacon key
[ 1461.372330] RTL871X: OnDeAuth(wlan0) reason=2, ta=c4:36:55:7b:f8:14, ignore=0
[ 1461.405408] RTL871X: indicate disassoc
wlan0: CTRL-EVENT-DISCONNECTED bssid=c4:36:55:7b:f8:14 reason=0
wlan0: Trying to associate with c4:36:55:7b:f8:14 (SSID='XTG-2F' [ 1469.455615] RTL871X: set ssid [XTG-2F] fw_state=0x00000008
freq=2412 MHz)
[ 1469.467769] RTL871X: set bssid:c4:36:55:7b:f8:14
[ 1469.543793] RTL871X: start auth
[ 1469.561860] RTL871X: auth success, start assoc
[ 1469.572576] RTL871X: assoc success
wlan0: Associated with c4:36:55:7b:f8:14
[ 1469.647852] RTL871X: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:2, no_gkey_mc_cnt:0
[ 1469.689503] RTL871X: send eapol packet
[ 1469.707056] RTL871X: send eapol packet
[ 1469.711410] RTL871X: set pairwise key camid:4, addr:c4:36:55:7b:f8:14, kid:0, type:AES
wlan0: WPA: Key negotiation completed with c4:36:55:7b:f8:14 [PTK=CCMP GTK=CCMP]
wlan0: CTRL-EVE[ 1469.728810] RTL871X: set group key camid:5, addr:c4:36:55:7b:f8:14, kid:1, type:AES
NT-CONNECTED - Connection to c4:36:55:7b:f8:14 completed (reauth) [id=0 id_str=]
[ 1470.597398] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1476.609408] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1484.251519] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1491.032896] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1500.158274] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1506.900275] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
[ 1515.170272] RTL871X: Warning!!! rx_query_phy_status: Confilc mac addr!!
飞凌-chongzi 发表于 2017-6-28 15:13:42 | 显示全部楼层
[ 1404.725290] RTL871X:  ...
    这是由mac地址冲突报出的警告,不影响使用,我们也正在处理这个问题,您可以先注释掉这个打印信息
请问下面打印的Log Error 是正常的吗,还是哪里出错了?? [ 1460.839740] RTL871X: ERROR rtw_check_bcn_info: start new beacon (seq=613) [ 1460.846664] RTL871X: ERROR rtw_check_bcn_info: cur beacon key  详情 回复 发表于 2017-10-23 16:52
Lq-sheng 发表于 2017-10-23 16:52:01 | 显示全部楼层
    这是由mac地址冲突报出的警告,不影响使用,我们也正在处理这个问题,您可以先注释掉这个打 ...
Lq-sheng 发表于 2017-10-23 17:11:21 | 显示全部楼层
请问,下面的这些error的信息,是正常工作的现象吗
<4>[ 5397.199893] RTL871X: ERROR rtw_check_bcn_info: start new beacon (seq=2993)
<4>[ 5397.200020] RTL871X: ERROR rtw_check_bcn_info: cur beacon key
<4>[ 5397.200086] RTL871X: ERROR rtw_check_bcn_info: new beacon key
<4>[ 5397.406875] RTL871X: ERROR rtw_check_bcn_info: new beacon again (seq=2996)
<4>[ 5397.509251] RTL871X: ERROR rtw_check_bcn_info: new beacon again (seq=2997)
<4>[ 5397.509382] RTL871X: ERROR rtw_check_bcn_info: new beacon occur!!
i.MX6UL通行证i.MX6Q通行证
茶亦爽 发表于 2018-1-29 16:37:14 | 显示全部楼层
楼主,rtl871x:indicate disassoc问题可能跟路由器有关系,我也出现这个问题。当我使用手机作为热点,就成功了。
