查看: 14553|回复: 2
[已解决] 下载进linux和文件
muzhang111 发表于 2017-9-16 07:07:58 | 显示全部楼层 |阅读模式
下载了linux的Zlmage和文件后启动出错:
init started: BusyBox v1.6.0 (2008-01-09 17:10:28 CST) multi-call binary
starting pid 903, tty '': '/etc/init.d/rcS'
mount: mounting none on /dev/pts failed
mount: mounting tmpfs on /dev/shm failed
dm9000 dm9000.0: WARNING: no IRQ resource flags set.
eth0: link down
ifconfig: SIOCSIFADDR: No such device
Please press Enter to activate this console.
starting pid 910, tty '': '/bin/sh'
# [9;0][?33l[?25lCould not read calibration: /etc/pointercal
Warning: Need to run firstuse
Warning: language message - en_US
Warning: and its not null
Warning: loading /usr/i18n/en_US/qt.qm
Warning: loading /usr/i18n/en_US/qpe.qm
Warning: loading /usr/i18n/en_US/libqpe.qm
Warning: loading /usr/i18n/en_US/libqtopia.qm
Warning: loading /usr/i18n/en_US/language.qm
Warning: loading /usr/i18n/en_US/timezone.qm
Warning: loading /usr/i18n/en_US/systemtime.qm
飞凌-chongzi 发表于 2017-9-19 19:12:02 | 显示全部楼层
    看您的打印信息,您的开发板应该是已经启动了,只是有一些报错,这些报错可能不影响您的使用,您可以参考手册测试一下,看看是否影响您的正常使用
楼主| muzhang111 发表于 2017-9-25 08:40:04 | 显示全部楼层
已经正常了,谢谢。
