查看: 19346|回复: 2
[Linux] 问问大神出先这个是啥意思
XX18通行证
rockyluo 发表于 2018-1-18 16:00:23 | 显示全部楼层 |阅读模式
root@rocky:/opt/OKxx18-source-android51# ./device/nexell/tools/build.sh -b s5p4418_drone -r sdmmc -t u-boot
PATH setting for android toolchain
Using built-in specs.
COLLECT_GCC=arm-eabi-gcc
COLLECT_LTO_WRAPPER=/opt/OKxx18-source-android51/prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/../libexec/gcc/arm-eabi/4.8/lto-wrapper
Target: arm-eabi
Configured with: /tmp/AOSP-toolchain/build/../gcc/gcc-4.8/configure --prefix=/tmp/toolchain-build-eabi/prefix --target=arm-eabi --host=x86_64-linux-gnu --build=x86_64-linux-gnu --with-gnu-as --with-gnu-ld --enable-languages=c,c++ --with-gmp=/tmp/toolchain-build-eabi/temp-install --with-mpfr=/tmp/toolchain-build-eabi/temp-install --with-mpc=/tmp/toolchain-build-eabi/temp-install --with-cloog=/tmp/toolchain-build-eabi/temp-install --with-isl=/tmp/toolchain-build-eabi/temp-install --with-ppl=/tmp/toolchain-build-eabi/temp-install --disable-ppl-version-check --disable-cloog-version-check --disable-isl-version-check --enable-cloog-backend=isl --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --disable-libssp --enable-threads --disable-nls --disable-libmudflap --disable-libgomp --disable-libstdc__-v3 --disable-sjlj-exceptions --disable-shared --disable-tls --disable-libitm --with-float=soft --with-fpu=vfp --with-arch=armv5te --enable-target-optspace --with-abi=aapcs --enable-initfini-array --disable-nls --prefix=/tmp/toolchain-build-eabi/prefix --with-sysroot=/tmp/toolchain-build-eabi/prefix/sysroot --with-binutils-version=2.23 --with-mpfr-version=3.1.1 --with-mpc-version=1.0.1 --with-gmp-version=5.0.5 --with-gcc-version=4.8 --with-gdb-version=7.6 --with-gxx-include-dir=/tmp/toolchain-build-eabi/prefix/include/c++/4.8 --with-bugurl=http://source.android.com/source/report-bugs.html --disable-bootstrap --disable-libquadmath --enable-plugins --enable-libgomp --disable-libsanitizer --enable-gold --enable-graphite=yes --with-cloog-version=0.18.0 --with-isl-version=0.11.1 --enable-eh-frame-hdr-for-static --with-arch=armv5te --disable-gold --disable-libgomp --program-transform-name='s&^&arm-eabi-&'
Thread model: single
gcc version 4.8 (GCC)
build u-boot
post processing
/opt/OKxx18-source-android51/out/target/product/s5p4418_drone
cp: 无法获取"/opt/OKxx18-source-android51/out/target/product/s5p4418_drone/root" 的文件状态(stat): 没有那个文件或目录
XX18通行证
楼主| rockyluo 发表于 2018-1-18 16:02:09 | 显示全部楼层
为啥会访问这个目录
是我自己要建立一个目录吗
飞凌-chongzi 发表于 2018-1-19 16:12:35 | 显示全部楼层
    xx18的uboot是不开源的,这个命令是编译uboot的,您是使用不了的,在单独编译内核镜像时,也有类似语句,但是内核是可以编译完成的,该语句在你执行完Android全编译后,对应目录生成后就不会报了
