查看: 36857|回复: 3
[Linux] 大神帮帮忙,出现这个问题,我需要配置哪里。
XX18通行证
rockyluo 发表于 2018-2-7 11:35:01 | 显示全部楼层 |阅读模式
/bin/sh: 1: arm-cortex_a9-linux-gnueabi-gcc: not found
make: arm-cortex_a9-linux-gnueabi-gcc:命令未找到
  WRAP    arch/arm/include/generated/asm/auxvec.h
  WRAP    arch/arm/include/generated/asm/bitsperlong.h
  WRAP    arch/arm/include/generated/asm/cputime.h
  WRAP    arch/arm/include/generated/asm/emergency-restart.h
  WRAP    arch/arm/include/generated/asm/errno.h
  WRAP    arch/arm/include/generated/asm/ioctl.h
  WRAP    arch/arm/include/generated/asm/irq_regs.h
  WRAP    arch/arm/include/generated/asm/kdebug.h
  WRAP    arch/arm/include/generated/asm/local.h
  WRAP    arch/arm/include/generated/asm/local64.h
  WRAP    arch/arm/include/generated/asm/percpu.h
  WRAP    arch/arm/include/generated/asm/poll.h
  WRAP    arch/arm/include/generated/asm/resource.h
  WRAP    arch/arm/include/generated/asm/sections.h
  WRAP    arch/arm/include/generated/asm/siginfo.h
  WRAP    arch/arm/include/generated/asm/sizes.h
  CHK     include/linux/version.h
  UPD     include/linux/version.h
  CHK     include/generated/utsrelease.h
  UPD     include/generated/utsrelease.h
  Generating include/generated/mach-types.h
  CC      kernel/bounds.s
make[1]: *** [kernel/bounds.s] 错误 127
make: *** [prepare0] 错误 2
米哥V587 发表于 2018-2-7 13:59:06 | 显示全部楼层
你是自己搭配的环境还是使用飞凌的环境?如果是自己搭建的,应该是交叉编译器没弄好。你可以用飞凌现成的编译环境试一下(论坛上就有)
XX18通行证
楼主| rockyluo 发表于 2018-2-7 14:24:24 | 显示全部楼层
我是按照飞凌提供的linux用户手册,操作的
出现这种问题,是交叉编译器没搭好,你可尝试重新操作,搭配环境比较繁琐建议直接用飞凌配置好的平台  详情 回复 发表于 2018-2-7 15:20
米哥V587 发表于 2018-2-7 15:20:12 | 显示全部楼层
