查看: 18932|回复: 3
[Linux] ok6410 DNW 下载
sdsszk 发表于 2018-7-17 23:48:26 | 显示全部楼层 |阅读模式
###################### User Menu for OK6410#####################
[1] Format the nand flash
[2] Burn image from SD card
[3] Burn image from USB
[4] Reboot the u-boot
[5] Exit to command line
-----------------------------Select---------------------------------
Enter your Selection:2
##### flash from SDcard  #####
##### Select the fuction #####
[1] Flash all image
[2] Flash u-boot
[3] Flash kernel
[4] Flash system
[5] Exit
Enter your Selection:1
NAND erase: device 0 whole chip
Erasing at 0x0 --   0
Erasing at 0xa00000 --   1.
Erasing at 0x1400000 --   2
Erasing at 0x1e80000 --   3
Erasing at 0x2880000 --   4
Erasing at 0x3300000 --   5
Erasing at 0x3d00000 --   6
Erasing at 0x4780000 --   7
Erasing at 0x5180000 --   8
Erasing at 0x5c00000 --   9
Erasing at 0x6600000 --  10e.
Erasing at 0x7080000 --  11
Erasing at 0x7a80000 --  12e.
Erasing at 0x8500000 --  13
Erasing at 0x8f00000 --  14
Erasing at 0x9980000 --  15
Erasing at 0xa380000 --  16
Erasing at 0xae00000 --  17
Erasing at 0xb800000 --  18
Erasing at 0xc280000 --  19
Erasing at 0xcc80000 --  20e.
Erasing at 0xd700000 --  21
Erasing at 0xe100000 --  22
Erasing at 0xeb80000 --  23te.
Erasing at 0xf580000 --  24
Erasing at 0xff80000 --  25
Erasing at 0x10a00000 --  26
Erasing at 0x11400000 --  27
Erasing at 0x11e80000 --  28ete.
Erasing at 0x12880000 --  29te.
Erasing at 0x13300000 --  30
Erasing at 0x13d00000 --  31
Erasing at 0x14780000 --  32
Erasing at 0x15180000 --  33
Erasing at 0x15c00000 --  34
Erasing at 0x16600000 --  35
Erasing at 0x17080000 --  36
Erasing at 0x17a80000 --  37
Erasing at 0x18500000 --  38
Erasing at 0x18f00000 --  39
Erasing at 0x19980000 --  40ete.
Erasing at 0x1a380000 --  41
Erasing at 0x1ae00000 --  42
Erasing at 0x1b800000 --  43
Erasing at 0x1c280000 --  44
Erasing at 0x1cc80000 --  45te.
Erasing at 0x1d700000 --  46te.
Erasing at 0x1e100000 --  47
Erasing at 0x1eb80000 --  48
Erasing at 0x1f580000 --  49
Erasing at 0x1ff80000 --  50
Erasing at 0x20a00000 --  51ete.
Erasing at 0x21400000 --  52ete.
Erasing at 0x21e80000 --  53ete.
Erasing at 0x22880000 --  54ete.
Erasing at 0x23300000 --  55ete.
Erasing at 0x23d00000 --  56ete.
Erasing at 0x24780000 --  57ete.
Erasing at 0x25180000 --  58
Erasing at 0x25c00000 --  59ete.
Erasing at 0x26600000 --  60ete.
Erasing at 0x27080000 --  61ete.
Erasing at 0x27a80000 --  62ete.
Erasing at 0x28500000 --  63ete.
Erasing at 0x28f00000 --  64ete.
Erasing at 0x29980000 --  65ete.
Erasing at 0x2a380000 --  66
Erasing at 0x2ae00000 --  67
Erasing at 0x2b800000 --  68
Erasing at 0x2c280000 --  69
Erasing at 0x2cc80000 --  70ete.
Erasing at 0x2d700000 --  71ete.
Erasing at 0x2e100000 --  72ete.
Erasing at 0x2eb80000 --  73te.
Erasing at 0x2f580000 --  74te.
Erasing at 0x2ff80000 --  75ete.
Erasing at 0x30a00000 --  76ete.
Erasing at 0x31400000 --  77ete.
Erasing at 0x31e80000 --  78ete.
Erasing at 0x32880000 --  79ete.
Erasing at 0x33300000 --  80te.
Erasing at 0x33d00000 --  81ete.
Erasing at 0x34780000 --  82te.
Erasing at 0x35180000 --  83ete.
Erasing at 0x35c00000 --  84ete.
Erasing at 0x36600000 --  85ete.
Erasing at 0x37080000 --  86te.
Erasing at 0x37a80000 --  87
Erasing at 0x38500000 --  88te.
Erasing at 0x38f00000 --  89ete.
Erasing at 0x39980000 --  90ete.
Erasing at 0x3a380000 --  91ete.
Erasing at 0x3ae00000 --  92ete.
Erasing at 0x3b800000 --  93ete.
Erasing at 0x3c280000 --  94ete.
Erasing at 0x3cc80000 --  95ete.
Erasing at 0x3d700000 --  96te.
Erasing at 0x3e100000 --  97ete.
Erasing at 0x3eb80000 --  98te.
Erasing at 0x3f580000 --  99ete.
Erasing at 0x3ff80000 -- 100ete.
OK
reading u-boot.bin
** Unable to read "u-boot.bin" from mmc 0:1 **
DNW下载出错,OK6410,怎么解决
liyang 发表于 2018-7-18 09:05:30 | 显示全部楼层
您好,您的意思是要从USB口给板子下载系统吗?这需要您制作相应SD卡,然后在uboot界面选择“3”,具体操作过程您可以对照“用户手册USB烧写”章节进行相应操作。
我直接用用DNW串口连接板子,选择SD下载,然后选择“1”,执行结果之后就是上边那样了,我需要怎么做那?因为我的板子买了好久了,一直没有用  详情 回复 发表于 2018-7-18 09:29
楼主| sdsszk 发表于 2018-7-18 09:29:21 | 显示全部楼层
您好,您的意思是要从USB口给板子下载系统吗?这需要您制作相应SD卡,然后在uboot界面选择“3”,具体操作 ...
liyang 发表于 2018-8-1 09:08:22 | 显示全部楼层
您的SD卡有进行烧写卡的制作吗?具体步骤可以参考手册,先将SD卡做好,并确保镜像的正确性和完整性
