查看: 13295|回复: 4
[Linux] virtualbox虚拟机安装的fedora20, 开发板挂载NFS出错,哪位高手帮我看看好吗?
elviswzd 发表于 2018-8-16 13:29:13 | 显示全部楼层 |阅读模式
[root@localhost ~]# ifconfig
enp0s3:flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
       inet 192.168.1.89  netmask255.255.255.0  broadcast 0.0.0.0
       inet6 fe80::a00:27ff:fe26:bddd prefixlen 64  scopeid0x20<link>
       ether 08:00:27:26:bd:dd txqueuelen 1000  (Ethernet)
       RX packets 8887  bytes 548956(536.0 KiB)
       RX errors 0  dropped 0  overruns 0 frame 0
       TX packets 9271  bytes 11990079(11.4 MiB)
       TX errors 0  dropped 0 overruns0  carrier 0  collisions 0
lo:flags=73<UP,LOOPBACK,RUNNING>  mtu65536
       inet 127.0.0.1  netmask 255.0.0.0
       inet6 ::1  prefixlen 128  scopeid 0x10<host>
       loop  txqueuelen 0  (Local Loopback)
       RX packets 1009  bytes 101680(99.2 KiB)
       TX packets 1009  bytes 101680(99.2 KiB)
[root@localhost ~]#
这是linux系统的IP
EWEN210 # printenv
baudrate=115200
bootargs=root=/dev/nfsnfsroot=192.168.1.89:/opt/ewen/rootfs ip=192.168.1.122:192.168.1.89:192.168.1.1:255.255.255.0:localhost:eth0:offinit=/linuxrc console=ttySAC0,115200
bootcmd=run ubifsboot
bootdelay=3
bootmenu_0=commandline= echo
bootmenu_1=start Kernel= tftp 20000000uImage;bootm 20000000
ethact=dm9000
ethaddr=1A:2A:3A:4A:5A:6A
ipaddr=192.168.1.120
mtdids=nand0=s5p-nand
serverip=192.168.1.89
splashimage=0x23000000
stderr=serial
stdin=serial
stdout=serial
Environment size: 513/131068 bytes
EWEN210 #
这是uboot的环境变量
dm9000 i/o: 0x88000000, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 1a:2a:3a:4a:5a:6a
operating at 100M full duplex mode
Using dm9000 device
TFTP from server 192.168.1.89; our IPaddress is 192.168.1.120
Filename 'uImage'.
Load address: 0x20000000
Loading: T#################################################################
        255.9 KiB/s
done
Bytes transferred = 1910872 (1d2858 hex)
## Booting kernel from Legacy Image at20000000 ...
  Image Name:   Linux-3.10.46
  Image Type:   ARM Linux KernelImage (uncompressed)
  Data Size:    1910808 Bytes = 1.8MiB
  Load Address: 20008000
  Entry Point:  20008000
  Verifying Checksum ... OK
  Loading Kernel Image ... OK
Starting kernel ...
Uncompressing Linux... done, booting thekernel.
Booting Linux on physical CPU 0x0
Linux version 3.10.46(root@localhost.localdomain) (gcc version 4.5.1 (ctng-1.8.
1-FA) ) #10 PREEMPT Tue Aug 14 23:35:03 CST2018
CPU: ARMv7 Processor [412fc082] revision 2(ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache,VIPT aliasing instruction cache
Machine: SMDKV210
Memory policy: ECC disabled, Data cachewriteback
CPU S5PV210/S5PC110 (id 0x43110220)
S3C24XX Clocks, Copyright 2004 SimtecElectronics
S5PV210: PLL settings, A=1000000000,M=667000000, E=96000000 V=54000000
S5PV210: ARMCLK=1000000000,HCLKM=200000000, HCLKD=166750000
HCLKP=133400000, PCLKM=100000000,PCLKD=83375000, PCLKP=66700000
sclk_dmc: source is sclk_a2m (0), rate is200000000
sclk_onenand: source is hclk_psys (0), rateis 66700000
sclk_fimc: source is ext_xtal (0), rate is24000000
sclk_cam0: source is ext_xtal (0), rate is24000000
sclk_cam1: source is ext_xtal (0), rate is24000000
sclk_fimd: source is ext_xtal (0), rate is24000000
sclk_mfc: source is sclk_a2m (0), rate is200000000
sclk_g2d: source is sclk_a2m (0), rate is200000000
sclk_g3d: source is sclk_a2m (0), rate is200000000
sclk_csis: source is ext_xtal (0), rate is24000000
sclk_pwi: source is ext_xtal (0), rate is24000000
sclk_pwm: source is ext_xtal (0), rate is24000000
CPU: All CPU(s) started in SVC mode.
Built 1 zonelists in Zone order, mobilitygrouping on.  Total pages: 130048
Kernel command line: root=/dev/nfsnfsroot=192.168.1.89:/opt/ewen/rootfs ip=192.
PID hash table entries: 2048 (order: 1,8192 bytes)
Dentry cache hash table entries: 65536(order: 6, 262144 bytes)
Inode-cache hash table entries: 32768(order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 515804k/515804k available, 8484kreserved, 0K highmem
Virtual kernel memory layout:
   vector  : 0xffff0000 -0xffff1000   (   4 kB)
   fixmap  : 0xfff00000 -0xfffe0000   ( 896 kB)
   vmalloc : 0xa0800000 - 0xff000000  (1512 MB)
   lowmem  : 0x80000000 -0xa0000000   ( 512 MB)
   modules : 0x7f000000 - 0x80000000  (  16 MB)
     .text : 0x80008000 - 0x8033f174  (3293 kB)
     .init : 0x80340000 - 0x80361d7c  ( 136 kB)
     .data : 0x80362000 - 0x80391f80  ( 192 kB)
      .bss : 0x80391f80 - 0x803cd0a8   ( 237 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0,CPUs=1, Nodes=1
Preemptible hierarchical RCUimplementation.
NR_IRQS:208
VIC @f6000000: id 0x00041192, vendor0x41
VIC @f6010000: id 0x00041192, vendor0x41
VIC @f6020000: id 0x00041192, vendor0x41
VIC @f6030000: id 0x00041192, vendor0x41
sched_clock: 32 bits at 33MHz, resolution29ns, wraps every 128784ms
Calibrating delay loop... 663.55 BogoMIPS(lpj=1658880)
CPU: Testing write buffer coherency:ok
Setting up static identity map for0x8026c170 - 0x8026c1c8
DMA: preallocated 256 KiB pool for atomiccoherent allocations
S3C Power Management, Copyright 2004 SimtecElectronics
S5PV210: Initializing architecture
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Switching to clocksourcesamsung_clocksource_timer
TCP established hash table entries: 4096(order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order:4, 81920 bytes)
TCP: Hash tables configured (established4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1,12288 bytes)
UDP-Lite hash table entries: 256 (order: 1,12288 bytes)
RPC: Registered named UNIX socket transportmodule.
RPC: Registered tcp NFSv4.1 backchanneltransport module.
ROMFS MTD (C) 2007 Red Hat, Inc.
io scheduler noop registered
dma-pl330 dma-pl330.0: Loaded driver forPL330 DMAC-267056
dma-pl330 dma-pl330.0:  DBUFF-8x4bytes Num_Chans-8 Num_Peri-32Num_Events-32
dma-pl330 dma-pl330.1: Loaded driver forPL330 DMAC-267056
dma-pl330 dma-pl330.1:  DBUFF-8x4bytes Num_Chans-8 Num_Peri-32Num_Events-32
Serial: 8250/16550 driver, 4 ports, IRQsharing disabled
s5pv210-uart.0: ttySAC0 at MMIO 0xe2900000(irq = 74) is a S3C6400/10
console [ttySAC0] enabled
s5pv210-uart.1: ttySAC1 at MMIO 0xe2900400(irq = 75) is a S3C6400/10
s5pv210-uart.2: ttySAC2 at MMIO 0xe2900800(irq = 76) is a S3C6400/10
s5pv210-uart.3: ttySAC3 at MMIO 0xe2900c00(irq = 77) is a S3C6400/10
brd: module loaded
loop: module loaded
dm9000 dm9000: read wrong id0x01010101
eth0: dm9000a at a085a000,a085c004 IRQ 39MAC: 00:09:c0:ff:ec:48 (platform data)
mousedev: PS/2 mouse device common for allmice
TCP: cubic registered
VFP support v0.3: implementor 41architecture 3 part 30 variant c rev 2
dm9000 dm9000 eth0: link down
IP-Config: Complete:
    device=eth0, hwaddr=00:09:c0:ff:ec:48, ipaddr=192.168.1.122,mask=255.255.2
55.0, gw=192.168.1.1
    host=localhost, domain=, nis-domain=(none)
    bootserver=192.168.1.89, rootserver=192.168.1.89, rootpath=
dm9000 dm9000 eth0: link up, 100Mbps,full-duplex, lpa 0xCDE1
VFS: Unable to mount root fs via NFS,trying floppy.
VFS: Cannot open root device"nfs" or unknown-block(2,0): error -6
Please append a correct "root="boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable tomount root fs on unknown-block(2,0)
CPU: 0 PID: 1 Comm: swapper Not tainted3.10.46 #10
[<800138b4>](unwind_backtrace+0x0/0xf0) from [<8001176c>] (show_stack+0x10/0x14
[<8001176c>] (show_stack+0x10/0x14)from [<80268ca0>] (panic+0x8c/0x1e8)
[<80268ca0>] (panic+0x8c/0x1e8) from[<80340f88>] (mount_block_root+0x1a4/0x254)
[<80340f88>](mount_block_root+0x1a4/0x254) from [<80341200>] (mount_root+0xd8/0
xf4)
[<80341200>] (mount_root+0xd8/0xf4) from[<8034137c>] (prepare_namespace+0x160/0
x1b8)
[<8034137c>](prepare_namespace+0x160/0x1b8) from [<80340be8>] (kernel_init_free
able+0x16c/0x1b0)
[<80340be8>](kernel_init_freeable+0x16c/0x1b0) from [<8026872c>] (kernel_init+0
x8/0xe4)
[<8026872c>] (kernel_init+0x8/0xe4)from [<8000e458>] (ret_from_fork+0x14/0x3c)
这是内核启动的信息,总是提示
VFS: Unable to mount root fs via NFS,trying floppy.   很郁闷,哪位高手帮我看一下
Marss 发表于 2018-8-16 14:30:28 | 显示全部楼层
可以上下位机ping通了吗?
楼主| elviswzd 发表于 2018-8-16 15:23:44 | 显示全部楼层
ping是可以的,启动uboot,ping 192.168.1.89可以,tftp也可以下载程序
fedora内部也测试过了,用这条命令mount nfs 192.168.1.89:/opt/ewen/rootfs /mnt/nfs可以挂载
Marss 发表于 2018-8-16 17:57:43 | 显示全部楼层
https://www.xuebuyuan.com/2097920.html 应该是自动挂载这块,在环境变量里设置一下。
楼主| elviswzd 发表于 2018-8-16 20:40:51 | 显示全部楼层
这里我是这样设置的
/opt/ewen/rootfs *(rw,sync,no_root_squash)
所以应该是没有问题的
