查看: 7022|回复: 2
[Android] OKMX6Q-C工业级套件烧入资料里的Android 6.0镜像无法启动
i.MX6Q通行证
echoindigo 发表于 2018-12-3 14:39:42 | 显示全部楼层 |阅读模式
用的开发板是OKMX6Q-C工业级套餐+FIT-LCD7.0MIPI液晶模块。拿到的板子默认是QT系统
用资料下载里Andorid 6.0资料里的下载工具烧入Android 6.0镜像下的文件。启动后始终黑屏,屏幕没有任何显示。
用串口打出的LOG如下:
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
ntfs: driver 2.1.32 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.23)
bounce: pool size: 64 pages
io scheduler noop registered
imx-weim 21b8000.weim: Driver registered.
mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
MIPI DSI driver module loaded
mxc_sdc_fb fb@0: registered mxc display driver lcd
Console: switching to colour frame buffer device 100x30
mxc_sdc_fb fb@3: err inte**ce_pix_fmt!
mxc_sdc_fb fb@3: get mxcfb of property fail
mxc_sdc_fb: probe of fb@3 failed with error -2
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.3
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
pfuze100-regulator 1-0008: FAB: 0, FIN: 0
pfuze100-regulator 1-0008: pfuze100 found.
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 24, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 301, base_baud = 5000000) is a IMX
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 302, base_baud = 5000000) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 303, base_baud = 5000000) is a IMX
21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 304, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
zram: Created 1 device(s)
ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi host0: ahci-imx
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 314
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CAN device driver inte**ce
flexcan 2090000.flexcan: device registered (reg_base=efc18000, irq=31)
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 4e:a3:ec:71:f5:d2
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP MPPE Compression module registered
pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new inte**ce driver pegasus
usbcore: registered new inte**ce driver rtl8150
usbcore: registered new inte**ce driver r8152
usbcore: registered new inte**ce driver asix
usbcore: registered new inte**ce driver ax88179_178a
usbcore: registered new inte**ce driver cdc_ether
usbcore: registered new inte**ce driver cdc_eem
usbcore: registered new inte**ce driver net1080
usbcore: registered new inte**ce driver cdc_subset
usbcore: registered new inte**ce driver zaurus
usbcore: registered new inte**ce driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new inte**ce driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new inte**ce driver usb-storage
usbcore: registered new inte**ce driver usbserial
usbcore: registered new inte**ce driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new inte**ce driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new inte**ce driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new inte**ce driver pl2303
usbserial: USB Serial support registered for pl2303
usbcore: registered new inte**ce driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
usb_otg_vbus: supplied by SWBST
usb_h1_vbus: supplied by SWBST
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.1.15 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new inte**ce driver xpad
usbcore: registered new inte**ce driver usb_acecad
usbcore: registered new inte**ce driver aiptek
usbcore: registered new inte**ce driver gtco
usbcore: registered new inte**ce driver hanwang
usbcore: registered new inte**ce driver kbtab
edt_ft5x06 2-0038: touchscreen probe failed
edt_ft5x06: probe of 2-0038 failed with error -5
ata1: SATA link down (SStatus 0 SControl 300)
ahci-imx 2200000.sata: no device found, disabling link.
ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
-------EDT FT5x06 initialized: WAKE pin -2, Reset pin -2.
input: EP0790M09 as /devices/soc0/i2c-ft5326/i2c-3/3-0038/input/input1
<<-GTP-INFO->> GTP driver installing...
<<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
<<-GTP-INFO->> GTP I2C Address: 0x14
<<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
<<-GTP-ERROR->> GTP i2c test failed time 1.
<<-GTP-ERROR->> GTP i2c test failed time 2.
<<-GTP-ERROR->> GTP i2c test failed time 3.
<<-GTP-ERROR->> GTP i2c test failed time 4.
<<-GTP-ERROR->> GTP i2c test failed time 5.
<<-GTP-ERROR->> I2C read failed.
<<-GTP-INFO->> GTP I2C Address: 0x5d
usb 1-1: new high-speed USB device number 2 using ci_hdrc
rtc-rx8010 2-0032: rtc core: registered rx8010 as rtc0
rtc-rx8010 2-0032: IRQ 73 supplied
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
usb 1-1: New USB device found, idVendor=0424, idProduct=2514
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
ov5642_read_reg:write reg error:reg=300a
camera ov5642 is not found
usb 1-1.3: new high-speed USB device number 3 using ci_hdrc
camera ov5640_mipi is not found
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
usbcore: registered new inte**ce driver uvcvideo
USB Video Class driver (1.1.1)
imx2-wdt 20c0000.wdog: use WDOG_B to reboot.
imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: dm-devel@redhat.com
usb 1-1.3: New USB device found, idVendor=0bda, idProduct=b720
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.3: Product: 802.11n WLAN Adapter
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
usbcore: registered new inte**ce driver btusb
sdhci-pltfm: SDHCI platform and OF driver helper
/soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
usb 1-1.3: Manufacturer: Realtek
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
/soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
sdhci-esdhc-imx 2198000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
usb 1-1.3: SerialNumber: 00e04c000001
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
/soc/aips-bus@02100000/usdhc@0219c000: voltage-ranges unspecified
sdhci-esdhc-imx 219c000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 219c000.usdhc: No vqmmc regulator found
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mxc_vpu 2040000.vpu_fsl: VPU initialized
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
Galcore version 5.0.11.41671
mmc3: MAN_BKOPS_EN bit is not set
mmc3: new DDR MMC card at address 0001
mmcblk3: mmc3:0001 Q2J55L 7.09 GiB
mmcblk3boot0: mmc3:0001 Q2J55L partition 1 16.0 MiB
mmcblk3boot1: mmc3:0001 Q2J55L partition 2 16.0 MiB
mmcblk3rpmb: mmc3:0001 Q2J55L partition 3 4.00 MiB
mmcblk3: p1 p2 p3 < p5 p6 p7 p8 p9 p10 > p4
caam 2100000.caam: Entropy delay = 3200
caam 2100000.caam: Instantiated RNG4 SH0
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] e1 a2 22 7c 83 af 4e 10
platform caam_sm: [0008] 62 98 d0 d7 af 69 96 b1
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 6c fb b8 86 bd 58 50 e7
platform caam_sm: [0008] 2d 8c c2 65 6e ed 65 33
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 03 5e 23 35 79 36 5c ef
platform caam_sm: [0008] 6f d0 5e d5 fe fd 54 2d
platform caam_sm: [0016] df ac c0 68 99 e1 96 de
platform caam_sm: [0024] db 5f 1c 1f e8 5e 67 3f
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] e6 4b 5f 86 50 f4 d1 e7
platform caam_sm: [0008] ec 97 07 58 7d 80 6a 7f
platform caam_sm: [0016] 45 b8 d6 1b 3b 6e 15 b3
platform caam_sm: [0024] 6f a4 62 3a 94 3b f9 0e
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] eb 12 81 7c 06 e4 56 c2
platform caam_sm: [0008] 1f 3f 4b 61 f6 87 48 fc
platform caam_sm: [0016] 7f 73 6f 38 7f df ba 35
platform caam_sm: [0024] b7 f9 ad e3 27 9d 45 1b
platform caam_sm: [0032] a4 8e 6f ad 91 63 26 7e
platform caam_sm: [0040] 44 d0 d2 87 75 04 43 10
platform caam_sm: [0048] bc 4d f2 c4 02 b7 56 dd
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] d0 5e 40 96 65 d8 2e 6d
platform caam_sm: [0008] 91 e9 e8 2e 62 e6 0a da
platform caam_sm: [0016] 90 7a 30 5f 7e 68 09 93
platform caam_sm: [0024] 10 7b 6f d1 72 97 55 bc
platform caam_sm: [0032] 76 f0 f0 65 75 d1 71 1c
platform caam_sm: [0040] e4 a3 bd 2d ae ce ff 08
platform caam_sm: [0048] bc 97 c2 35 dd 64 d9 ea
platform caam_sm: [0056] a1 b3 6e fb b7 eb 9d 51
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] b2 c4 00 a7 0a 07 e5 72
platform caam_sm: [0008] d1 f1 eb 41 d4 e0 ec b3
platform caam_sm: [0016] 8e ea d7 81 e7 cf 07 2f
platform caam_sm: [0024] b9 67 a0 9b 43 d9 ae 3a
platform caam_sm: [0032] af cf 4e c8 10 af 99 fd
platform caam_sm: [0040] eb 41 b4 3e d5 77 99 2d
platform caam_sm: [0048] e9 8d f6 94 53 5e 4f a8
platform caam_sm: [0056] e9 ca b6 f0 a8 7e 47 1f
platform caam_sm: [0064] 6d d5 de 67 c8 b5 01 6c
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] e2 f1 8c fc 55 be 90 11
platform caam_sm: [0008] 2d a8 3f bd a9 ba 32 64
platform caam_sm: [0016] df 34 d1 c7 bf 6c 7e 25
platform caam_sm: [0024] 6e a0 9e b2 34 5d a5 46
platform caam_sm: [0032] 9d 73 20 ad e2 58 b0 b8
platform caam_sm: [0040] 92 e5 a7 71 a4 d0 82 06
platform caam_sm: [0048] 74 cc 84 53 b7 84 0c 55
platform caam_sm: [0056] ab 33 8b 7c 1e ca b5 19
platform caam_sm: [0064] 86 5e 22 ce b9 fb 9b 65
platform caam_sm: [0072] 43 25 5c 78 c7 bf da 9c
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 0a b4 e4 fe b7 0e 30 c3
platform caam_sm: [0008] 93 e4 ae 97 c5 43 0e 57
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] c5 71 24 9b 07 b1 b1 0f
platform caam_sm: [0024] c3 2c 00 df 8c a5 69 ba
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
caam_keyblob caam_keyblob: caam keyblob initialized
hidraw: raw HID events driver (C) Jiri Kosina
usbhid: USB HID core driver
ashmem: initialized
usbcore: registered new inte**ce driver snd-usb-audio
fsl-asrc 2034000.asrc: driver registered
fsl-hdmi-dai soc:hdmi_audio@00120000: failed to probe. Load HDMI-video first.
fsl-hdmi-dai: probe of soc:hdmi_audio@00120000 failed with error -12
imx-wm8960 sound: wm8960-hifi <-> 202c000.ssi mapping ok
imx-wm8960 sound: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
imx-audio-hdmi sound-hdmi: initialize HDMI-audio failed. load HDMI-video first!
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (15927 buckets, 63708 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
pwm-backlight supply power not found, using dummy regulator
input: gpio-keys as /devices/soc0/gpio-keys/input/input3
rtc-rx8010 2-0032: setting system clock to 2018-12-03 06:37:51 UTC (1543819071)
SW4: disabling
wlreg_on: disabling
CAN XCVR: disabling
hdmi-5v-supply: disabling
sensor-supply: disabling
usb_otg_vbus: disabling
ALSA device list:
  #0: wm8960-audio
Freeing unused kernel memory: 1024K (c1000000 - c1100000)
init: init started!
SELinux:  Android master kernel running Android M policy in compatibility mode.
SELinux:  Permission audit_read in class capability2 not defined in policy.
SELinux: the above unknown classes and permissions will be denied
audit: type=1403 audit(1543819071.630:2): policy loaded auid=4294967295 ses=4294967295
audit: type=1404 audit(1543819071.650:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: (Initializing SELinux enforcing took 0.14s.)
init: init second stage started!
init: waitpid failed: No child processes
init: property_set("ro.zygote", "zygote32") failed
init: (Loading properties from /default.prop took 0.01s.)
init: (Parsing /init.environ.rc took 0.00s.)
init: (Parsing /init.usb.rc took 0.00s.)
init: (Parsing init.freescale.usb.rc took 0.00s.)
init: (Parsing init.freescale.i.MX6Q.rc took 0.00s.)
init: (Parsing /init.freescale.rc took 0.01s.)
init: (Parsing /init.usb.configfs.rc took 0.00s.)
init: (Parsing /init.zygote32.rc took 0.00s.)
init: (Parsing /init.trace.rc took 0.00s.)
init: (Parsing /init.rc took 0.04s.)
init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
init: Starting service 'ueventd'...
init: Waiting for /dev/.coldboot_done...
ueventd: ueventd started!
ueventd: Coldboot took 0.35s.
init: Waiting for /dev/.coldboot_done took 0.37s.
init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
init: Starting service 'watchdogd'...
Console: switching to colour dummy device 80x30
watchdogd: watchdogd started (interval 10, margin 20)!
fs_mgr: Enabling dm-verity for system (mode 0)
EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: barrier=1
fs_mgr: __mount(source=/dev/block/dm-0,target=/system,type=ext4)=0
EXT4-fs (mmcblk3p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk3p4): recovery complete
EXT4-fs (mmcblk3p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
fs_mgr: __mount(source=/dev/block/mmcblk3p4,target=/data,type=ext4)=0
EXT4-fs (mmcblk3p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk3p6): recovery complete
EXT4-fs (mmcblk3p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
fs_mgr: __mount(source=/dev/block/mmcblk3p6,target=/cache,type=ext4)=0
EXT4-fs (mmcblk3p7): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk3p7,target=/device,type=ext4)=0
file system registered
init: Starting service 'logd'...
zram0: detected capacity change from 0 to 314572800
audit: type=1400 audit(1543819073.460:4): avc:  denied  { read write } for  pid=212 comm="mkswap" name="zram0" dev="tmpfs" ino=1538 scontext=u:r:toolbox:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=0
logd.auditd: start
logd.klogd: 6750994000
Unable to find swap-space signature
fs_mgr: swapon failed for /dev/block/zram0
init: (Loading properties from /system/build.prop took 0.01s.)
init: (Loading properties from /vendor/build.prop took 0.00s.)
init: (Loading properties from /factory/factory.prop took 0.00s.)
init: Starting service 'vold'...
init: Not bootcharting.
init: Starting service 'exec 0 (/system/bin/tzdatacheck)'...
init: Service 'exec 0 (/system/bin/tzdatacheck)' (pid 223) exited with status 0
random: init urandom read with 23 bits of entropy available
init: Starting service 'logd-reinit'...
init: Starting service 'healthd'...
init: Starting service 'console'...
init: Starting service 'lmkd'...
init: Starting service 'servicemanager'...
binder: 226:226 transaction failed 29189, size 0-0
init: Starting service 'su**ceflinger'...
logd.daemon: reinit
init: Service 'logd-reinit' (pid 225) exited with status 0
init: write_file: Unable to open '/sys/block/mmcblk0/queue/read_ahead_kb': No such file or directory
init: write_file: Unable to open '/sys/block/mmcblk1/queue/read_ahead_kb': No such file or directory
rtk_btusb: RTKBT_RELEASE_NAME: 20180702_BT_ANDROID_6.0
rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.5
rtk_btusb: Register usb char device inte**ce for BT driver
rtk_btusb: btusb_probe: usb_inte**ce d47bf200, bInte**ceNumber 0, idVendor 0x0bda, idProduct 0x0000
type=1400 audit(1543819073.770:5): avc: denied { dac_override } for pid=227 comm="sh" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=0
rtk_btusb: get_fw_table_entry: Product id = 0xb720, fw table entry size 49
rtk_btusb: firmware_info_init: Auto suspend is disabled
rtk_btusb: btusb_probe: Check bt reset flag 0
root@sabresd_6dq:/ # usbcore: registered new inte**ce driver rtk_btusb
init: Starting service 'netd'...
init: Starting service 'debuggerd'...
init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
init: Starting service 'drm'...
init: Starting service 'media'...
init: Starting service 'installd'...
init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
init: Starting service 'keystore'...
init: Starting service 'ril-daemon'...
init: Starting service 'can'...
init: Starting service 'zygote'...
init: Starting service 'gatekeeperd'...
init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
init: Starting service 'magd'...
{125000}
flexcan 2090000.flexcan can0: writing ctrl=0x0e312085
IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
init: Service 'magd' (pid 243) exited with status 255
healthd: BatteryTemperaturePath not found
healthd: BatteryTechnologyPath not found
init: Starting service 'bootanim'...
ERROR: v4l2 capture: slave not found!
capability: warning: `main' uses 32-bit capabilities (legacy support in use)
zram: 550 (system_server) Attribute mem_used_total (and others) will be removed. See zram documentation.
random: nonblocking pool is initialized
lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
lowmemorykiller: oom_adj 0 => oom_score_adj 0
lowmemorykiller: oom_adj 1 => oom_score_adj 58
lowmemorykiller: oom_adj 2 => oom_score_adj 117
lowmemorykiller: oom_adj 3 => oom_score_adj 176
lowmemorykiller: oom_adj 9 => oom_score_adj 529
lowmemorykiller: oom_adj 15 => oom_score_adj 1000
acc_open
acc_release
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
init: Service 'bootanim' (pid 308) exited with status 0
请问屏幕无显示是什么问题导致的?系统镜像里没有这个7.0mipi液晶模块的驱动?
飞凌-chongzi 发表于 2018-12-4 17:42:27 | 显示全部楼层
您好
您这边烧写的是我们的标准镜像吗,是否按照我们手册上流程来烧写的
是用mfgtools烧写的标准镜像,手册参考的是:OKMX6X-C-Android_6.0用户手册-V1.0-2018-08-20  详情 回复 发表于 2018-12-5 13:41
i.MX6Q通行证
楼主| echoindigo 发表于 2018-12-5 13:41:52 | 显示全部楼层
您好
