- 40
贡献171
飞刀48 FD
注册时间2018-3-19
在线时间6 小时
U-Boot 2015.04-g1577d62 (Dec 25 2018 - 15:16:24)
CPU: Freescale i.MX6UL rev1.2 at 396 MHz
CPU: Temperature 37 C
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C: ready
DRAM: 256 MiB
force_idle_bus: sda=0 scl=0 sda.gp=0x1d scl.gp=0x1c
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Display: TFT70AB-800x480 (800x480)
Video: 800x480x24
Error: no valid bmp image at 83800000 cfb_console.c
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc0 is current device
Net: FEC1
Normal Boot
reading boot.scr
update emmc.........
reading /sdrun/zImage
1167360 bytes read in 68 ms (16.4 MiB/s)
reading /sdrun/ramdisk.img.u
798720 bytes read in 52 ms (14.6 MiB/s)
reading /sdrun/imx6ul-14x14-evk.dtb
30924 bytes read in 22 ms (1.3 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0x5cd7a0 ]
## Loading init Ramdisk from Legacy Image at 83800000 ...
Image Name: ramdisk
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 8162651 Bytes = 7.8 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... Bad Data CRC
Ramdisk image is corrupt or invalid
---------------MAIN MENU---------------
1. Screen Type Menu or DTB
2. Change The Calibrate
0. Exit To Boot Shell
Enter your number:
