查看: 28221|回复: 1
[Linux] qt程序自启动
10
AM335x通行证i.MX6UL通行证i.MX6Q通行证
liukangkang 发表于 2019-7-15 11:20:01 | 显示全部楼层 |阅读模式
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting inetd daemon.
Starting syslogd/klogd: done
/etc/rc5.d/S97matrix-gui: line 82: export: `MouseMan:/dev/input/mice
#touch and mouse use at the same time,but qt app need touch two times,affect user experiance
#export QWS_MOUSE_PROTO=Tslib:/dev/input/touchscreen0': not a valid identifier
/etc/rc5.d/S97matrix-gui: line 82: export: `Intellimouse:/dev/input/mice
export QWS_MOUSE_PROTO=Tslib:/dev/input/event0': not a valid identifier
/etc/rc5.d/S97matrix-gui: line 88: aw: command not found
/etc/rc5.d/S97matrix-gui: line 92: [: =: unary operator expected
2000-01-01 00:16:48: (log.c.166) server started
./TOD_Project: error while loading shared libraries: libQtSql.so.4: cannot open shared object file: No such file or directory
Stopping Bootlog daemon: bootlogd.
_____   _____   _____    _       _   __   _  __    __
|  ___| /  _   |  _    | |     | | |   | |    / /
| |__   | | | | | |_| |  | |     | | |   | |   / /
|  __|  | | | | |  _  /  | |     | | | |   |   }  {
| |     | |_| | | |    | |___  | | | |   |  / /
|_|     _____/ |_|  _ |_____| |_| |_|  _| /_/  _
ok335x login: root
amixer: Control default open error: No such file or directory
root@ok335x:~#
启动报少 libQtSql.so.4 , 而且前面还有好多错误,自动启动程序启动不了,但手动启动可以,,
楼主| liukangkang 发表于 2019-7-15 16:47:11 | 显示全部楼层
问题解决,修改文件系统的配置时改变了格式引起的,重烧文件系统就可以了,或者找相同板的/etc/init.d/qt.sh替换即可
