- 96
贡献504
飞刀129 FD
注册时间2018-8-9
在线时间24 小时
我在335x上接了个10.4寸的屏,屏幕显示正常,触摸功能不可用,启动时候打印信息如下:
[ 5.152923] usbserial: USB Serial Driver core
[ 5.157606] USB Serial support registered for GSM modem (1-port)
[ 5.164287] usbcore: registered new inte**ce driver option
[ 5.170102] option: v0.7.2:USB Driver for GSM modems
[ 5.175479] USB Serial support registered for Vizzini USB serial port
[ 5.182364] usbcore: registered new inte**ce driver vizzini
[ 5.188288] USB Driver for Vizzini USB serial port: v.1.1
[ 5.194122] gadget: Mass Storage Function, version: 2009/09/11
[ 5.200304] gadget: Number of LUNs=1
[ 5.204142] lun0: LUN: removable file: (no medium)
[ 5.209255] gadget: Mass Storage Gadget, version: 2009/09/11
[ 5.215269] gadget: userspace failed to provide iSerialNumber
[ 5.221360] gadget: g_mass_storage ready
[ 5.225568] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 5.231164] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 5.239005] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.246103] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.253649] usb usb2: Product: MUSB HDRC host driver
[ 5.258825] usb usb2: Manufacturer: Linux 3.2.0-g4977ff8-dirty musb-hcd
[ 5.265733] usb usb2: SerialNumber: musb-hdrc.0
[ 5.271401] hub 2-0:1.0: USB hub found
[ 5.275368] hub 2-0:1.0: 1 port detected
[ 5.280752] mousedev: PS/2 mouse device common for all mice
[ 5.287179] <<-GTP-INFO->> GTP driver installing...
[ 5.292418] <<-GTP-INFO->> GTP Driver Version: V2.2<2014/01/14>
[ 5.298624] <<-GTP-INFO->> GTP Driver Built@17:00:33, Jul 25 2019
[ 5.304992] <<-GTP-INFO->> GTP I2C Address: 0x14
[ 5.309821] <<-GTP-INFO->> Guitar reset
[ 5.444080] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -121!
[ 5.452137] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -121! Process reset.
[ 5.460862] <<-GTP-INFO->> Guitar reset
[ 5.584015] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -121!
[ 5.591460] <<-GTP-ERROR->> GTP i2c test failed time 1.
[ 5.614015] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -121! Process reset.
[ 5.622724] <<-GTP-INFO->> Guitar reset
[ 5.744012] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -121!
[ 5.751455] <<-GTP-ERROR->> GTP i2c test failed time 2.
[ 5.774016] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -121! Process reset.
[ 5.782730] <<-GTP-INFO->> Guitar reset
[ 5.904012] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -121!
[ 5.911455] <<-GTP-ERROR->> GTP i2c test failed time 3.
[ 5.934011] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -121! Process reset.
[ 5.942725] <<-GTP-INFO->> Guitar reset
[ 6.064043] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -121!
[ 6.071490] <<-GTP-ERROR->> GTP i2c test failed time 4.
[ 6.094011] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -121! Process reset.
[ 6.102722] <<-GTP-INFO->> Guitar reset
[ 6.224013] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -121!
[ 6.231458] <<-GTP-ERROR->> GTP i2c test failed time 5.
[ 6.253394] <<-GTP-ERROR->> I2C communication ERROR!
[ 6.258595] Goodix-TS: probe of 2-0014 failed with error -121
[ 6.265106] usbcore: registered new inte**ce driver usbtouchscreen
[ 6.272291] ft5x0x_ts 2-0038: ft5x06_i2c_read: i2c read error.
[ 6.278410] ft5x0x_ts 2-0038: report rate read failed
[ 6.283624] ft5x0x_ts: probe of 2-0038 failed with error -121
[ 6.292617] rtc-ds1307 1-0068: rtc core: registered ds1307 as rtc0
[ 6.299111] rtc-ds1307 1-0068: 56 bytes nvram
[ 6.303876] forlinx rx8010_probe
[ 6.307415] rtc-rx8010 1-0032: Unable to write register #23
[ 6.313229] i2c i2c-1: probing for rx8010 failed
[ 6.318071] rtc-rx8010: probe of 1-0032 failed with error -121
[ 6.324349] i2c /dev entries driver
[ 6.328693] Linux video capture inte**ce: v2.00
[ 6.333898] usbcore: registered new inte**ce driver uvcvideo
[ 6.339892] USB Video Class driver (1.1.1)
[ 6.345128] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 6.351578] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 6.358171] usbcore: registered new inte**ce driver bcm203x
[ 6.364094] Bluetooth: Generic Bluetooth USB driver ver 0.6
[ 6.370089] usbcore: registered new inte**ce driver btusb
[ 6.377162] cpuidle: using governor ladder
[ 6.381918] cpuidle: using governor menu
[ 6.393212] usbcore: registered new inte**ce driver usbhid
[ 6.399078] usbhid: USB HID core driver
[ 6.404269] tiadc tiadc: attached adc driver
[ 6.411536] _regulator_get: 2-001b supply IOVDD not found, using dummy regulator
[ 6.419364] _regulator_get: 2-001b supply DVDD not found, using dummy regulator
[ 6.427054] _regulator_get: 2-001b supply AVDD not found, using dummy regulator
[ 6.434744] _regulator_get: 2-001b supply DRVDD not found, using dummy regulator
[ 6.445491] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[ 6.490579] ALSA device list:
[ 6.493732] #0: AM335X EVM
[ 6.496735] oprofile: hardware counters not available
[ 6.501999] oprofile: using timer interrupt.
[ 6.506485] Netfilter messages via NETLINK v0.30.
[ 6.511508] nf_conntrack version 0.5.0 (7985 buckets, 31940 max)
[ 6.518244] ctnetlink v0.93: registering with nfnetlink.
[ 6.524619] xt_time: kernel timezone is -0000
[ 6.529419] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.535209] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[ 6.541900] arp_tables: (C) 2002 David S. Miller
[ 6.546827] TCP cubic registered
[ 6.550196] NET: Registered protocol family 17
[ 6.554854] can: controller area network core (rev 20090105 abi 8)
[ 6.561406] NET: Registered protocol family 29
[ 6.566084] can: raw protocol (rev 20090105)
[ 6.570541] can: broadcast manager protocol (rev 20090105 t)
[ 6.576629] Bluetooth: RFCOMM TTY layer initialized
[ 6.581741] Bluetooth: RFCOMM socket layer initialized
[ 6.587117] Bluetooth: RFCOMM ver 1.11
[ 6.591029] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.596580] Bluetooth: BNEP filters: protocol multicast
[ 6.602031] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[ 6.608683] Registering the dns_resolver key type
[ 6.613694] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 6.621701] ThumbEE CPU extension supported.
[ 6.626238] mux: Failed to setup hwmod io irq -22
[ 6.631859] Power Management for AM33XX family
[ 6.636764] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 6.643451] Copied the M3 firmware to UMEM
[ 6.647802] Cortex M3 Firmware Version = 0x181
[ 6.657797] clock: disabling unused clocks to save power
[ 6.665576] Detected MACID=44:ea:d8:d3:b5:56
[ 6.671317] cpsw: Detected MACID = 44:ea:d8:d3:b5:58
[ 6.678726] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 6.687597] rtc-ds1307 1-0068: setting system clock to 2019-07-26 16:42:02 UTC (1564159322)
[ 6.782957] UBIFS: recovery needed
[ 7.024897] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 7.039393] UBIFS: recovery completed
[ 7.043215] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 7.049506] UBIFS: file system size: 235540480 bytes (230020 KiB, 224 MiB, 1855 LEBs)
[ 7.057870] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 7.065503] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 7.071586] UBIFS: default compressor: lzo
[ 7.075863] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 7.083411] VFS: Mounted root (ubifs filesystem) on device 0:14.
[ 7.091143] devtmpfs: mounted
[ 7.095974] Freeing init memory: 1252K
[ 7.126698] mmc0: new high speed SDHC card at address e624
[ 7.134160] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[ 7.158237] mmcblk0: p1
INIT: version 2.88 booting
Starting udev
[ 8.282012] udev[775]: starting version 164
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
ALSA: Restoring mixer settings...
No state is present for card EVM
Found hardware: "AM335X_EVM" "" "" "" ""
Hardware is initialized using a generic method
Configuring network inte**ces... [ 10.619541] net eth0: CPSW phy found : id is : 0x4dd074
done.
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting inetd daemon.
Starting syslogd/klogd: done
ts_open: No such file or directory
2019-07-26 16:42:05: (log.c.166) server started
[ 12.614974] PHY: 0:00 - Link is Up - 1000/Full
Stopping Bootlog daemon: bootlogd.
请问这个是还要改驱动什么参数吗? |
