查看: 9452|回复: 1
[Linux] 麻烦帮忙看下 Freescale i.MX6UL rev1.2 sd卡启动失败
fffzzzlllxxx 发表于 2019-11-9 11:39:36 | 显示全部楼层 |阅读模式
U-Boot 2015.04-g3779e6b (Aug 08 2017 - 08:38:37)
CPU:   Freescale i.MX6UL rev1.2 at 396 MHz
CPU:   Temperature 43 C
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C:   ready
DRAM:  256 MiB
Display: TFT70AB (800x480)
Video: 800x480x24
Error: no valid bmp image at 83800000 cfb_console.c
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc0 is current device
Net:   FEC0
Error: FEC0 address not set.
Normal Boot
reading boot.scr
mmc boot..........
reading /bin/zImage
6424896 bytes read in 299 ms (20.5 MiB/s)
reading /bin/imx6ul-14x14-evk.dtb
29445 bytes read in 23 ms (1.2 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0x620940 ]
   Using Device Tree in place at 83000000, end 8300a304
Starting kernel ...
[    0.000000] Linux version 3.14.38-6UL_ga (root@ubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 --        Built at 2011/08/10 09:20) ) #2 SMP PREEMPT Mon Apr 2 12:43:11 CST 2018
[    0.000000] Machine model: Freescale i.MX6 UltraLite 14x14 EVK Board
[    0.000000] cma: CMA: reserved 64 MiB at 8c000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 8 pages/cpu @8bdc3000 s8832 r8192 d15744 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60928
[    0.000000] Kernel command line: console=ttymxc0,115200 cma=64M root=/dev/mmcblk0p2
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 165668K/245760K available (7910K kernel code, 480K rwdata, 2788K rodata, 396K init, 433K bss, 80092K reserved,        0K highmem)
[    0.000000]     vmalloc : 0x90800000 - 0xff000000   (1768 MB)
[    0.000000]     lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x80a7ac20   (10700 kB)
[    0.000000]       .init : 0x80a7b000 - 0x80ade280   ( 397 kB)
[    0.000000]       .data : 0x80ae0000 - 0x80b582a0   ( 481 kB)
[    0.000000]        .bss : 0x80b582ac - 0x80bc4874   ( 434 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000019] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[    0.002316] clocksource_of_init: no matching clocksources found
[    0.002690] Console: colour dummy device 80x30
[    0.002737] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.002770] pid_max: default: 32768 minimum: 301
[    0.003184] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.003216] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.004832] Initializing cgroup subsys net_cls
[    0.004922] CPU: Testing write buffer coherency: ok
[    0.005426] /cpus/cpu@0 missing clock-frequency property
[    0.005469] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005528] Setting up static identity map for 0x80782c28 - 0x80782c80
[    0.040761] Brought up 1 CPUs
[    0.040798] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.040817] CPU: All CPU(s) started in SVC mode.
[    0.042138] devtmpfs: initialized
[    0.053340] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.054151] pinctrl core: initialized pinctrl subsystem
[    0.055080] regulator-dummy: no parameters
[    0.060612] NET: Registered protocol family 16
[    0.078491] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.080196] cpuidle: using governor ladder
[    0.080225] cpuidle: using governor menu
[    0.080649] Use WDOG1 as reset source
[    0.099424] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[    0.100149] vdd3p0: 2625 <--> 3400 mV at 3000 mV
[    0.101204] cpu: 725 <--> 1450 mV at 1150 mV
[    0.102164] vddsoc: 725 <--> 1450 mV at 1175 mV
[    0.107545] syscon 20e4000.iomuxc-gpr: regmap [mem 0x020e4000-0x020e7fff] registered
[    0.113887] syscon 21ac000.romcp: regmap [mem 0x021ac000-0x021affff] registered
[    0.115357] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[    0.121540] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.121570] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.125792] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.128595] 20dc000.gpc supply pu not found, using dummy regulator
[    0.164868] bio: create slab <bio-0> at 0
[    0.171970] mxs-dma 1804000.dma-apbh: initialized
[    0.172859] VSD_3V3: 3300 mV
[    0.174220] gpio_dvfs: 1300 <--> 1400 mV at 1400 mV
[    0.175480] i2c-core: driver [max17135] using legacy suspend method
[    0.175503] i2c-core: driver [max17135] using legacy resume method
[    0.176813] SCSI subsystem initialized
[    0.178093] usbcore: registered new inte**ce driver usbfs
[    0.178276] usbcore: registered new inte**ce driver hub
[    0.178602] usbcore: registered new device driver usb
[    0.181962] i2c i2c-1: IMX I2C adapter registered
[    0.182239] Linux video capture inte**ce: v2.00
[    0.182419] pps_core: LinuxPPS API ver. 1 registered
[    0.182444] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.182527] PTP clock support registered
[    0.185222] MIPI CSI2 driver module loaded
[    0.185791] Advanced Linux Sound Architecture Driver Initialized.
[    0.187844] Bluetooth: Core ver 2.18
[    0.187971] NET: Registered protocol family 31
[    0.187994] Bluetooth: HCI device and connection manager initialized
[    0.188037] Bluetooth: HCI socket layer initialized
[    0.188072] Bluetooth: L2CAP socket layer initialized
[    0.188191] Bluetooth: SCO socket layer initialized
[    0.189206] cfg80211: Calling CRDA to update world regulatory domain
[    0.190110] Switched to clocksource mxc_timer1
[    0.216821] NET: Registered protocol family 2
[    0.218849] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.218932] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.219023] TCP: Hash tables configured (established 2048 bind 2048)
[    0.219139] TCP: reno registered
[    0.219179] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.219239] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.219834] NET: Registered protocol family 1
[    0.220746] RPC: Registered named UNIX socket transport module.
[    0.220779] RPC: Registered udp transport module.
[    0.220798] RPC: Registered tcp transport module.
[    0.220817] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.223528] imx rpmsg driver is registered.
[    0.225192] Bus freq driver module loaded
[    0.227229] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.247235] VFS: Disk quotas dquot_6.5.2
[    0.248034] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.254502] NFS: Registering the id_resolver key type
[    0.254610] Key type id_resolver registered
[    0.254634] Key type id_legacy registered
[    0.254730] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[    0.256667] fuse init (API version 7.22)
[    0.257963] msgmni has been set to 451
[    0.266640] io scheduler noop registered
[    0.266673] io scheduler deadline registered
[    0.267159] io scheduler cfq registered (default)
[    0.268254] imx-weim 21b8000.weim: Driver registered.
[    0.275426] MIPI DSI driver module loaded
[    0.285956] imx-sdma 20ec000.sdma: no event needs to be remapped
[    0.286194] imx-sdma 20ec000.sdma: loaded firmware 3.1
[    0.295340] imx-sdma 20ec000.sdma: initialized
[    0.296696] Serial: IMX driver
[    0.297187] has none gpio
[    0.297399] 2018000.serial: ttymxc6 at MMIO 0x2018000 (irq = 71, base_baud = 5000000) is a IMX
[    0.298436] has none gpio
[    0.298632] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[    1.012883] console [ttymxc0] enabled
[    1.017646] has none gpio
[    1.020571] 2024000.serial: ttymxc7 at MMIO 0x2024000 (irq = 72, base_baud = 5000000) is a IMX
[    1.030762] has none gpio
[    1.033603] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    1.043293] has none gpio
[    1.046121] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
[    1.055918] has none gpio
[    1.058757] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61, base_baud = 5000000) is a IMX
[    1.068482] has none gpio
[    1.071385] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 62, base_baud = 5000000) is a IMX
[    1.081150] has none gpio
[    1.083984] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 49, base_baud = 5000000) is a IMX
[    1.093643] serial: Freescale lpuart driver
[    1.101821] imx sema4 driver is registered.
[    1.106197] [drm] Initialized drm 1.1.0 20060810
[    1.112072] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    1.140792] brd: module loaded
[    1.156205] loop: module loaded
[    1.165027] CAN device driver inte**ce
[    1.171577] 20b4000.ethernet supply phy not found, using dummy regulator
[    1.179601] pps pps0: new PPS source ptp0
[    1.184226] fec 20b4000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    1.193355] fec 20b4000.ethernet (unregistered net_device): Using random MAC address: e6:b3:6b:fc:e9:73
[    1.203506] libphy: fec_enet_mii_bus: probed
[    1.211663] fec 20b4000.ethernet eth0: registered PHC device 0
[    1.219199] 2188000.ethernet supply phy not found, using dummy regulator
[    1.227363] pps pps1: new PPS source ptp1
[    1.231946] fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    1.241153] fec 2188000.ethernet (unregistered net_device): Using random MAC address: 8a:54:19:0b:db:0e
[    1.252681] fec 2188000.ethernet eth1: registered PHC device 1
[    1.260307] PPP generic driver version 2.4.2
[    1.265133] PPP BSD Compression module registered
[    1.269876] PPP Deflate Compression module registered
[    1.275243] usbcore: registered new inte**ce driver asix
[    1.280877] usbcore: registered new inte**ce driver cdc_ether
[    1.286875] usbcore: registered new inte**ce driver cdc_eem
[    1.292891] usbcore: registered new inte**ce driver cdc_ncm
[    1.298591] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.305203] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.311035] usbcore: registered new inte**ce driver usb-storage
[    1.317423] usbcore: registered new inte**ce driver usbserial
[    1.323472] usbcore: registered new inte**ce driver usbserial_generic
[    1.330195] usbserial: USB Serial support registered for generic
[    1.336352] usbcore: registered new inte**ce driver ftdi_sio
[    1.342285] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.349744] usbcore: registered new inte**ce driver option
[    1.355523] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.362699] usbcore: registered new inte**ce driver pl2303
[    1.368416] usbserial: USB Serial support registered for pl2303
[    1.374580] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    1.381180] xr_usb_serial_common: Exar USB UART (serial port) driver
[    1.387708] usbcore: registered new inte**ce driver usb_ehset_test
[    1.396275] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    1.860888] 2184200.usb supply vbus not found, using dummy regulator
[    1.871184] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    1.876174] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    1.900209] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    1.907873] hub 1-0:1.0: USB hub found
[    1.911852] hub 1-0:1.0: 1 port detected
[    1.917988] mousedev: PS/2 mouse device common for all mice
[    1.925704] input: 20cc000.snvs-pwrkey as /devices/soc0/soc.0/2000000.aips-bus/20cc000.snvs-pwrkey/input/input0
[    1.936619] snvs_pwrkey 20cc000.snvs-pwrkey: i.MX snvs powerkey probed
[    1.945100] <<-GTP-INFO->> GTP driver installing...
[    1.950948] i2c-core: driver [isl29023] using legacy suspend method
[    1.957255] i2c-core: driver [isl29023] using legacy resume method
[    1.967326] rtc-rx8010 1-0032: Update timer was detected
[    1.975798] rtc-rx8010 1-0032: rtc core: registered rx8010 as rtc0
[    1.983382] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc1
[    1.992040] i2c /dev entries driver
[    1.996406] IR NEC protocol handler initialized
[    2.001050] IR RC5(x) protocol handler initialized
[    2.005871] IR RC6 protocol handler initialized
[    2.011499] IR JVC protocol handler initialized
[    2.016069] IR Sony protocol handler initialized
[    2.020765] IR RC5 (streamzap) protocol handler initialized
[    2.026366] IR SANYO protocol handler initialized
[    2.031127] IR MCE Keyboard/mouse protocol handler initialized
[    2.039888] pxp-v4l2 pxp_v4l2.8: initialized
[    2.044686] usbcore: registered new inte**ce driver uvcvideo
[    2.050608] USB Video Class driver (1.1.1)
[    2.055731] i2c-core: driver [mag3110] using legacy suspend method
[    2.062017] i2c-core: driver [mag3110] using legacy resume method
[    2.069225] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[    2.077832] Bluetooth: HCI UART driver ver 2.2
[    2.082363] Bluetooth: HCI H4 protocol initialized
[    2.087183] Bluetooth: HCI BCSP protocol initialized
[    2.092211] Bluetooth: HCIATH3K protocol initialized
[    2.097420] usbcore: registered new inte**ce driver bcm203x
[    2.103345] usbcore: registered new inte**ce driver btusb
[    2.109071] usbcore: registered new inte**ce driver ath3k
[    2.115204] sdhci: Secure Digital Host Controller Inte**ce driver
[    2.121473] sdhci: Copyright(c) Pierre Ossman
[    2.125859] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.134634] mmc0: no vqmmc regulator found
[    2.180231] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    2.225037] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[    2.231601] nand: Micron MT29F2G08ABAEAWP
[    2.235652] nand: 256MiB, SLC, page size: 2048, OOB size: 64
[    2.242183] gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
[    2.249196] Scanning device for bad blocks
[    2.284167] mmc0: host does not support reading read-only switch. assuming write-enable.
[    2.301479] mmc0: Problem setting current limit!
[    2.420167] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[    2.432085] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[    2.453691]  mmcblk0: p1 p2
[    2.497311] 6 ofpart partitions found on MTD device gpmi-nand
[    2.503233] Creating 6 MTD partitions on "gpmi-nand":
[    2.508332] 0x000000000000-0x000000400000 : "boot"
[    2.516063] 0x000000400000-0x000000600000 : "logo"
[    2.523810] 0x000000600000-0x000000700000 : "ENV"
[    2.531462] 0x000000700000-0x000000a00000 : "DTB"
[    2.538749] 0x000000a00000-0x000001200000 : "kernel"
[    2.546580] 0x000001200000-0x000010000000 : "rootfs"
[    2.554669] gpmi-nand 1806000.gpmi-nand: driver registered.
[    2.563492] usbcore: registered new inte**ce driver usbhid
[    2.569109] usbhid: USB HID core driver
[    2.580437] fsl-asrc 2034000.asrc: driver registered
[    2.594893] NET: Registered protocol family 26
[    2.599393] Netfilter messages via NETLINK v0.30.
[    2.604345] nfnl_acct: registering with nfnetlink.
[    2.609303] nf_conntrack version 0.5.0 (3612 buckets, 14448 max)
[    2.616700] ctnetlink v0.93: registering with nfnetlink.
[    2.622382] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[    2.628958] nf_tables_compat: (c) 2012 Pablo Neira Ayuso <pablo@netfilter.org>
[    2.636752] xt_time: kernel timezone is -0000
[    2.641951] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.647722] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[    2.654310] arp_tables: (C) 2002 David S. Miller
[    2.659048] TCP: cubic registered
[    2.663953] NET: Registered protocol family 10
[    2.670862] sit: IPv6 over IPv4 tunneling driver
[    2.677253] NET: Registered protocol family 17
[    2.681958] can: controller area network core (rev 20120528 abi 9)
[    2.688355] NET: Registered protocol family 29
[    2.692962] can: raw protocol (rev 20120528)
[    2.697269] can: broadcast manager protocol (rev 20120528 t)
[    2.703072] can: netlink gateway (rev 20130117) max_hops=1
[    2.709251] Bluetooth: RFCOMM TTY layer initialized
[    2.714420] Bluetooth: RFCOMM socket layer initialized
[    2.719640] Bluetooth: RFCOMM ver 1.11
[    2.723498] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.728843] Bluetooth: BNEP filters: protocol multicast
[    2.734158] Bluetooth: BNEP socket layer initialized
[    2.739155] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    2.745156] Bluetooth: HIDP socket layer initialized
[    2.750285] 8021q: 802.1Q VLAN Support v1.8
[    2.754631] Key type dns_resolver registered
[    2.760572] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[    2.784577] gpio_dvfs: disabling
[    2.787859] regulator-dummy: disabling
[    2.792253] imx mcc test is registered.
[    2.798437] rtc-rx8010 1-0032: setting system clock to 2019-11-09 11:17:01 UTC (1573298221)
[    2.828601] ALSA device list:
[    2.831703]   No soundcards found.
[    2.849007] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem
[    2.856011] EXT3-fs (mmcblk0p2): write access will be enabled during recovery
[    3.177721] random: nonblocking pool is initialized
[    3.328940] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.338616] mmcblk0: retrying write for general error
[    3.347339] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.356322] mmcblk0: retrying write for general error
[    3.365016] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.373950] mmcblk0: retrying write for general error
[    3.382594] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.391521] mmcblk0: retrying write for general error
[    3.400135] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.409059] mmcblk0: retrying write for general error
[    3.417700] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.426620] mmcblk0: retrying write for general error
[    3.431738] end_request: I/O error, dev mmcblk0, sector 1063300
[    3.437684] Buffer I/O error on device mmcblk0p2, logical block 0
[    3.443825] lost page write due to I/O error on mmcblk0p2
[    3.449298] end_request: I/O error, dev mmcblk0, sector 1063308
[    3.455270] Buffer I/O error on device mmcblk0p2, logical block 1
[    3.461476] lost page write due to I/O error on mmcblk0p2
[    3.477994] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.486952] mmcblk0: retrying write for general error
[    3.495443] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.504381] mmcblk0: retrying write for general error
[    3.512841] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.521780] mmcblk0: retrying write for general error
[    3.530257] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.539145] mmcblk0: retrying write for general error
[    3.547629] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.556548] mmcblk0: retrying write for general error
[    3.565046] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.573965] mmcblk0: retrying write for general error
[    3.579042] end_request: I/O error, dev mmcblk0, sector 1066852
[    3.585024] Buffer I/O error on device mmcblk0p2, logical block 444
[    3.591338] lost page write due to I/O error on mmcblk0p2
[    3.600383] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.609274] mmcblk0: retrying write for general error
[    3.617943] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.626863] mmcblk0: retrying write for general error
[    3.635515] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.644435] mmcblk0: retrying write for general error
[    3.653044] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.661965] mmcblk0: retrying write for general error
[    3.670603] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.679491] mmcblk0: retrying write for general error
[    3.688121] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.697041] mmcblk0: retrying write for general error
[    3.702157] end_request: I/O error, dev mmcblk0, sector 1587596
[    3.708100] Buffer I/O error on device mmcblk0p2, logical block 65537
[    3.714581] lost page write due to I/O error on mmcblk0p2
[    3.720048] end_request: I/O error, dev mmcblk0, sector 1587604
[    3.726018] Buffer I/O error on device mmcblk0p2, logical block 65538
[    3.732563] lost page write due to I/O error on mmcblk0p2
[    3.749383] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.758310] mmcblk0: retrying write for general error
[    3.767130] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.776054] mmcblk0: retrying write for general error
[    3.784846] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.793770] mmcblk0: retrying write for general error
[    3.802559] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.811476] mmcblk0: retrying write for general error
[    3.820256] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.829144] mmcblk0: retrying write for general error
[    3.837938] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.846859] mmcblk0: retrying write for general error
[    3.851975] end_request: I/O error, dev mmcblk0, sector 1587660
[    3.857917] Buffer I/O error on device mmcblk0p2, logical block 65545
[    3.864400] lost page write due to I/O error on mmcblk0p2
[    3.869868] end_request: I/O error, dev mmcblk0, sector 1587668
[    3.875848] Buffer I/O error on device mmcblk0p2, logical block 65546
[    3.882392] lost page write due to I/O error on mmcblk0p2
[    3.887846] end_request: I/O error, dev mmcblk0, sector 1587676
[    3.893818] Buffer I/O error on device mmcblk0p2, logical block 65547
[    3.900299] lost page write due to I/O error on mmcblk0p2
[    3.916791] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.925741] mmcblk0: retrying write for general error
[    3.934221] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.943159] mmcblk0: retrying write for general error
[    3.951625] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.960563] mmcblk0: retrying write for general error
[    3.969020] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.977942] mmcblk0: retrying write for general error
[    3.986437] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    3.995354] mmcblk0: retrying write for general error
[    4.003841] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.012767] mmcblk0: retrying write for general error
[    4.017843] end_request: I/O error, dev mmcblk0, sector 1833348
[    4.023827] Buffer I/O error on device mmcblk0p2, logical block 96256
[    4.030313] lost page write due to I/O error on mmcblk0p2
[    4.039189] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.048114] mmcblk0: retrying write for general error
[    4.056882] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.065823] mmcblk0: retrying write for general error
[    4.074324] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.083251] mmcblk0: retrying write for general error
[    4.091724] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.100646] mmcblk0: retrying write for general error
[    4.109108] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.118028] mmcblk0: retrying write for general error
[    4.126515] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.135433] mmcblk0: retrying write for general error
[    4.140551] end_request: I/O error, dev mmcblk0, sector 4733380
[    4.146494] Buffer I/O error on device mmcblk0p2, logical block 458760
[    4.153067] lost page write due to I/O error on mmcblk0p2
[    4.162113] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.171054] mmcblk0: retrying write for general error
[    4.179663] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.188624] mmcblk0: retrying write for general error
[    4.197285] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.206213] mmcblk0: retrying write for general error
[    4.214871] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.223790] mmcblk0: retrying write for general error
[    4.232392] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.241316] mmcblk0: retrying write for general error
[    4.249925] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.258862] mmcblk0: retrying write for general error
[    4.267940] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.276868] mmcblk0: retrying write for general error
[    4.285837] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.294758] mmcblk0: retrying write for general error
[    4.303707] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.312634] mmcblk0: retrying write for general error
[    4.321582] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.330501] mmcblk0: retrying write for general error
[    4.339423] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.348344] mmcblk0: retrying write for general error
[    4.357295] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.366214] mmcblk0: retrying write for general error
[    4.374890] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.383824] mmcblk0: retrying write for general error
[    4.392308] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.401230] mmcblk0: retrying write for general error
[    4.409689] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.418609] mmcblk0: retrying write for general error
[    4.427100] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.436022] mmcblk0: retrying write for general error
[    4.444500] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.453429] mmcblk0: retrying write for general error
[    4.461905] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.470823] mmcblk0: retrying write for general error
[    4.479356] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.488281] mmcblk0: retrying write for general error
[    4.496770] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.505691] mmcblk0: retrying write for general error
[    4.514170] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.523093] mmcblk0: retrying write for general error
[    4.531564] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.540484] mmcblk0: retrying write for general error
[    4.548928] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.557846] mmcblk0: retrying write for general error
[    4.566344] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.575263] mmcblk0: retrying write for general error
[    4.583810] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.592737] mmcblk0: retrying write for general error
[    4.601213] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.610132] mmcblk0: retrying write for general error
[    4.618580] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.627499] mmcblk0: retrying write for general error
[    4.635985] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.644904] mmcblk0: retrying write for general error
[    4.653363] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.662284] mmcblk0: retrying write for general error
[    4.670743] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.679629] mmcblk0: retrying write for general error
[    4.688195] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.697123] mmcblk0: retrying write for general error
[    4.705635] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.714556] mmcblk0: retrying write for general error
[    4.723028] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.731953] mmcblk0: retrying write for general error
[    4.740414] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.749304] mmcblk0: retrying write for general error
[    4.757780] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.766699] mmcblk0: retrying write for general error
[    4.775185] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.784104] mmcblk0: retrying write for general error
[    4.792656] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.801656] mmcblk0: retrying write for general error
[    4.810123] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.819047] mmcblk0: retrying write for general error
[    4.827544] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.836464] mmcblk0: retrying write for general error
[    4.844951] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.853870] mmcblk0: retrying write for general error
[    4.862342] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.871262] mmcblk0: retrying write for general error
[    4.879711] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.888636] mmcblk0: retrying write for general error
[    4.897211] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.906141] mmcblk0: retrying write for general error
[    4.914631] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.923552] mmcblk0: retrying write for general error
[    4.932024] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.940947] mmcblk0: retrying write for general error
[    4.949402] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.958322] mmcblk0: retrying write for general error
[    4.966819] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.975739] mmcblk0: retrying write for general error
[    4.984224] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    4.993142] mmcblk0: retrying write for general error
[    5.001702] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.010631] mmcblk0: retrying write for general error
[    5.019082] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.028003] mmcblk0: retrying write for general error
[    5.036499] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.045419] mmcblk0: retrying write for general error
[    5.053977] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.062901] mmcblk0: retrying write for general error
[    5.071378] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.080302] mmcblk0: retrying write for general error
[    5.088750] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.097670] mmcblk0: retrying write for general error
[    5.106397] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.115323] mmcblk0: retrying write for general error
[    5.123973] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.132892] mmcblk0: retrying write for general error
[    5.141523] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.150446] mmcblk0: retrying write for general error
[    5.159067] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.167986] mmcblk0: retrying write for general error
[    5.176629] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.185589] mmcblk0: retrying write for general error
[    5.194242] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.203161] mmcblk0: retrying write for general error
[    5.211763] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.220689] mmcblk0: retrying write for general error
[    5.229129] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.238091] mmcblk0: retrying write for general error
[    5.246596] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.255515] mmcblk0: retrying write for general error
[    5.264011] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.272929] mmcblk0: retrying write for general error
[    5.281405] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.290326] mmcblk0: retrying write for general error
[    5.298760] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.307679] mmcblk0: retrying write for general error
[    5.316247] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.325174] mmcblk0: retrying write for general error
[    5.333668] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.342588] mmcblk0: retrying write for general error
[    5.351064] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.359953] mmcblk0: retrying write for general error
[    5.368434] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.377353] mmcblk0: retrying write for general error
[    5.385825] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.394743] mmcblk0: retrying write for general error
[    5.403202] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.412121] mmcblk0: retrying write for general error
[    5.420663] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.429554] mmcblk0: retrying write for general error
[    5.438037] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.446956] mmcblk0: retrying write for general error
[    5.455472] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.464391] mmcblk0: retrying write for general error
[    5.472877] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.481800] mmcblk0: retrying write for general error
[    5.490263] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.499150] mmcblk0: retrying write for general error
[    5.507644] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.516563] mmcblk0: retrying write for general error
[    5.525321] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.534246] mmcblk0: retrying write for general error
[    5.542889] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.551815] mmcblk0: retrying write for general error
[    5.560437] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.569326] mmcblk0: retrying write for general error
[    5.577971] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.586893] mmcblk0: retrying write for general error
[    5.595550] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.604466] mmcblk0: retrying write for general error
[    5.613105] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.622028] mmcblk0: retrying write for general error
[    5.631689] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.640628] mmcblk0: retrying write for general error
[    5.650184] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.659072] mmcblk0: retrying write for general error
[    5.668656] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.677573] mmcblk0: retrying write for general error
[    5.687154] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.696075] mmcblk0: retrying write for general error
[    5.705657] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.714578] mmcblk0: retrying write for general error
[    5.724147] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.733070] mmcblk0: retrying write for general error
[    5.741831] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.750758] mmcblk0: retrying write for general error
[    5.759217] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.768137] mmcblk0: retrying write for general error
[    5.776640] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.785563] mmcblk0: retrying write for general error
[    5.794039] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.802963] mmcblk0: retrying write for general error
[    5.811442] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.820365] mmcblk0: retrying write for general error
[    5.828823] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.837740] mmcblk0: retrying write for general error
[    5.846295] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.855219] mmcblk0: retrying write for general error
[    5.863697] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.872620] mmcblk0: retrying write for general error
[    5.881093] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.889980] mmcblk0: retrying write for general error
[    5.898458] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.907376] mmcblk0: retrying write for general error
[    5.915852] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.924769] mmcblk0: retrying write for general error
[    5.933237] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.942163] mmcblk0: retrying write for general error
[    5.950708] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.959597] mmcblk0: retrying write for general error
[    5.968093] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.977013] mmcblk0: retrying write for general error
[    5.985506] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    5.994425] mmcblk0: retrying write for general error
[    6.002901] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.011822] mmcblk0: retrying write for general error
[    6.020285] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.029172] mmcblk0: retrying write for general error
[    6.037659] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.046577] mmcblk0: retrying write for general error
[    6.055186] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.064116] mmcblk0: retrying write for general error
[    6.072595] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.081521] mmcblk0: retrying write for general error
[    6.089980] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.098902] mmcblk0: retrying write for general error
[    6.107389] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.116308] mmcblk0: retrying write for general error
[    6.124799] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.133719] mmcblk0: retrying write for general error
[    6.142202] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.151126] mmcblk0: retrying write for general error
[    6.159846] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.168775] mmcblk0: retrying write for general error
[    6.177419] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.186382] mmcblk0: retrying write for general error
[    6.195038] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.203959] mmcblk0: retrying write for general error
[    6.212592] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.221514] mmcblk0: retrying write for general error
[    6.230195] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.239084] mmcblk0: retrying write for general error
[    6.247729] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.256650] mmcblk0: retrying write for general error
[    6.265252] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.274180] mmcblk0: retrying write for general error
[    6.282657] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.291582] mmcblk0: retrying write for general error
[    6.300035] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.308956] mmcblk0: retrying write for general error
[    6.317445] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.326363] mmcblk0: retrying write for general error
[    6.334857] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.343778] mmcblk0: retrying write for general error
[    6.352243] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.361166] mmcblk0: retrying write for general error
[    6.369697] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.378625] mmcblk0: retrying write for general error
[    6.387117] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.396037] mmcblk0: retrying write for general error
[    6.404518] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.413433] mmcblk0: retrying write for general error
[    6.421909] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.430832] mmcblk0: retrying write for general error
[    6.439290] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.448208] mmcblk0: retrying write for general error
[    6.456701] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.465621] mmcblk0: retrying write for general error
[    6.474191] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.483117] mmcblk0: retrying write for general error
[    6.491595] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.500519] mmcblk0: retrying write for general error
[    6.508984] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.517904] mmcblk0: retrying write for general error
[    6.526396] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.535313] mmcblk0: retrying write for general error
[    6.543800] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.552720] mmcblk0: retrying write for general error
[    6.561188] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.570074] mmcblk0: retrying write for general error
[    6.578634] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.587557] mmcblk0: retrying write for general error
[    6.596059] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.604978] mmcblk0: retrying write for general error
[    6.613441] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.622360] mmcblk0: retrying write for general error
[    6.630838] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.639726] mmcblk0: retrying write for general error
[    6.648202] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.657125] mmcblk0: retrying write for general error
[    6.665618] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.674536] mmcblk0: retrying write for general error
[    6.683232] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.692161] mmcblk0: retrying write for general error
[    6.700797] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.709686] mmcblk0: retrying write for general error
[    6.718344] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.727262] mmcblk0: retrying write for general error
[    6.735905] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.744824] mmcblk0: retrying write for general error
[    6.753454] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.762377] mmcblk0: retrying write for general error
[    6.770991] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.779880] mmcblk0: retrying write for general error
[    6.788632] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.797559] mmcblk0: retrying write for general error
[    6.806293] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.815217] mmcblk0: retrying write for general error
[    6.823858] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.832784] mmcblk0: retrying write for general error
[    6.841410] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.850330] mmcblk0: retrying write for general error
[    6.858936] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.867855] mmcblk0: retrying write for general error
[    6.876496] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.885415] mmcblk0: retrying write for general error
[    6.894007] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.902938] mmcblk0: retrying write for general error
[    6.911424] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.920346] mmcblk0: retrying write for general error
[    6.928798] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.937720] mmcblk0: retrying write for general error
[    6.946216] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.955136] mmcblk0: retrying write for general error
[    6.963606] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.972529] mmcblk0: retrying write for general error
[    6.981004] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    6.989892] mmcblk0: retrying write for general error
[    6.998459] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.007385] mmcblk0: retrying write for general error
[    7.015887] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.024808] mmcblk0: retrying write for general error
[    7.033290] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.042218] mmcblk0: retrying write for general error
[    7.050665] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.059554] mmcblk0: retrying write for general error
[    7.068050] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.076972] mmcblk0: retrying write for general error
[    7.085466] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.094385] mmcblk0: retrying write for general error
[    7.102935] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.111867] mmcblk0: retrying write for general error
[    7.120334] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.129223] mmcblk0: retrying write for general error
[    7.137726] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.146647] mmcblk0: retrying write for general error
[    7.155138] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.164056] mmcblk0: retrying write for general error
[    7.172530] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.181491] mmcblk0: retrying write for general error
[    7.189943] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.198865] mmcblk0: retrying write for general error
[    7.207432] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.216358] mmcblk0: retrying write for general error
[    7.224845] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.233803] mmcblk0: retrying write for general error
[    7.242280] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.251201] mmcblk0: retrying write for general error
[    7.259650] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.268571] mmcblk0: retrying write for general error
[    7.277060] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.285981] mmcblk0: retrying write for general error
[    7.294465] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.303385] mmcblk0: retrying write for general error
[    7.311958] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.320891] mmcblk0: retrying write for general error
[    7.329351] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.338271] mmcblk0: retrying write for general error
[    7.346761] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.355681] mmcblk0: retrying write for general error
[    7.364169] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.373089] mmcblk0: retrying write for general error
[    7.381563] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.390485] mmcblk0: retrying write for general error
[    7.398935] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.407855] mmcblk0: retrying write for general error
[    7.416586] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.425510] mmcblk0: retrying write for general error
[    7.434176] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.443096] mmcblk0: retrying write for general error
[    7.451719] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.460641] mmcblk0: retrying write for general error
[    7.469240] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.478160] mmcblk0: retrying write for general error
[    7.486811] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.495729] mmcblk0: retrying write for general error
[    7.504381] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.513303] mmcblk0: retrying write for general error
[    7.521883] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.530811] mmcblk0: retrying write for general error
[    7.539269] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.548188] mmcblk0: retrying write for general error
[    7.556679] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.565599] mmcblk0: retrying write for general error
[    7.574093] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.583013] mmcblk0: retrying write for general error
[    7.591488] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.600414] mmcblk0: retrying write for general error
[    7.608868] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.617786] mmcblk0: retrying write for general error
[    7.626659] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.635582] mmcblk0: retrying write for general error
[    7.644384] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.653305] mmcblk0: retrying write for general error
[    7.662104] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.671029] mmcblk0: retrying write for general error
[    7.679787] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.688723] mmcblk0: retrying write for general error
[    7.697503] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.706421] mmcblk0: retrying write for general error
[    7.715225] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    7.724143] mmcblk0: retrying write for general error
[    7.729325] JBD: recovery failed
[    7.732704] EXT3-fs (mmcblk0p2): error loading journal
[    7.760446] EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (4)
[    7.774892] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    7.782332] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    8.266569] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.276675] mmcblk0: retrying write for general error
[    8.285410] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.294398] mmcblk0: retrying write for general error
[    8.303011] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.311944] mmcblk0: retrying write for general error
[    8.320586] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.329474] mmcblk0: retrying write for general error
[    8.338119] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.347040] mmcblk0: retrying write for general error
[    8.355688] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.364609] mmcblk0: retrying write for general error
[    8.373222] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.382148] mmcblk0: retrying write for general error
[    8.390629] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.399519] mmcblk0: retrying write for general error
[    8.408005] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.416925] mmcblk0: retrying write for general error
[    8.425436] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.434356] mmcblk0: retrying write for general error
[    8.442822] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.451747] mmcblk0: retrying write for general error
[    8.460216] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.469102] mmcblk0: retrying write for general error
[    8.474219] blk_update_request: 55 callbacks suppressed
[    8.479460] end_request: I/O error, dev mmcblk0, sector 1066852
[    8.485428] quiet_error: 55 callbacks suppressed
[    8.490063] Buffer I/O error on device mmcblk0p2, logical block 444
[    8.496373] lost page write due to I/O error on mmcblk0p2
[    8.505410] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.514338] mmcblk0: retrying write for general error
[    8.522978] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.531902] mmcblk0: retrying write for general error
[    8.540514] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.549403] mmcblk0: retrying write for general error
[    8.558053] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.566972] mmcblk0: retrying write for general error
[    8.575616] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.584536] mmcblk0: retrying write for general error
[    8.593157] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.602074] mmcblk0: retrying write for general error
[    8.607152] end_request: I/O error, dev mmcblk0, sector 1587596
[    8.613133] Buffer I/O error on device mmcblk0p2, logical block 65537
[    8.619588] lost page write due to I/O error on mmcblk0p2
[    8.625080] end_request: I/O error, dev mmcblk0, sector 1587604
[    8.631053] Buffer I/O error on device mmcblk0p2, logical block 65538
[    8.637509] lost page write due to I/O error on mmcblk0p2
[    8.654415] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.663365] mmcblk0: retrying write for general error
[    8.672157] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.681091] mmcblk0: retrying write for general error
[    8.689868] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.698788] mmcblk0: retrying write for general error
[    8.707597] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.716517] mmcblk0: retrying write for general error
[    8.725306] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.734229] mmcblk0: retrying write for general error
[    8.743036] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.751956] mmcblk0: retrying write for general error
[    8.757032] end_request: I/O error, dev mmcblk0, sector 1587660
[    8.763012] Buffer I/O error on device mmcblk0p2, logical block 65545
[    8.769465] lost page write due to I/O error on mmcblk0p2
[    8.774961] end_request: I/O error, dev mmcblk0, sector 1587668
[    8.780935] Buffer I/O error on device mmcblk0p2, logical block 65546
[    8.787391] lost page write due to I/O error on mmcblk0p2
[    8.792931] end_request: I/O error, dev mmcblk0, sector 1587676
[    8.798872] Buffer I/O error on device mmcblk0p2, logical block 65547
[    8.805426] lost page write due to I/O error on mmcblk0p2
[    8.821968] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.830921] mmcblk0: retrying write for general error
[    8.839384] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.848307] mmcblk0: retrying write for general error
[    8.856809] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.865731] mmcblk0: retrying write for general error
[    8.874226] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.883146] mmcblk0: retrying write for general error
[    8.891621] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.900543] mmcblk0: retrying write for general error
[    8.909008] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.917930] mmcblk0: retrying write for general error
[    8.923046] end_request: I/O error, dev mmcblk0, sector 1833348
[    8.928987] Buffer I/O error on device mmcblk0p2, logical block 96256
[    8.935469] lost page write due to I/O error on mmcblk0p2
[    8.944360] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.953290] mmcblk0: retrying write for general error
[    8.961774] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.970693] mmcblk0: retrying write for general error
[    8.979158] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    8.988082] mmcblk0: retrying write for general error
[    8.996575] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.005492] mmcblk0: retrying write for general error
[    9.013979] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.022903] mmcblk0: retrying write for general error
[    9.031365] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.040284] mmcblk0: retrying write for general error
[    9.045360] end_request: I/O error, dev mmcblk0, sector 4733380
[    9.051385] Buffer I/O error on device mmcblk0p2, logical block 458760
[    9.057929] lost page write due to I/O error on mmcblk0p2
[    9.066992] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.075920] mmcblk0: retrying write for general error
[    9.084590] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.093511] mmcblk0: retrying write for general error
[    9.102143] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.111069] mmcblk0: retrying write for general error
[    9.119686] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.128607] mmcblk0: retrying write for general error
[    9.137259] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.146178] mmcblk0: retrying write for general error
[    9.154830] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.163751] mmcblk0: retrying write for general error
[    9.168828] end_request: I/O error, dev mmcblk0, sector 5781964
[    9.174814] Buffer I/O error on device mmcblk0p2, logical block 589833
[    9.181427] lost page write due to I/O error on mmcblk0p2
[    9.186891] end_request: I/O error, dev mmcblk0, sector 5781972
[    9.192861] Buffer I/O error on device mmcblk0p2, logical block 589834
[    9.199401] lost page write due to I/O error on mmcblk0p2
[    9.216443] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.225394] mmcblk0: retrying write for general error
[    9.234406] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.243345] mmcblk0: retrying write for general error
[    9.252283] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.261219] mmcblk0: retrying write for general error
[    9.270150] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.279071] mmcblk0: retrying write for general error
[    9.288019] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.296939] mmcblk0: retrying write for general error
[    9.305900] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.314819] mmcblk0: retrying write for general error
[    9.323513] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.332443] mmcblk0: retrying write for general error
[    9.340930] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.349820] mmcblk0: retrying write for general error
[    9.358303] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.367222] mmcblk0: retrying write for general error
[    9.375713] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.384633] mmcblk0: retrying write for general error
[    9.393100] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.402023] mmcblk0: retrying write for general error
[    9.410495] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.419382] mmcblk0: retrying write for general error
[    9.427961] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.436886] mmcblk0: retrying write for general error
[    9.445386] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.454314] mmcblk0: retrying write for general error
[    9.462784] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.471710] mmcblk0: retrying write for general error
[    9.480160] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.489047] mmcblk0: retrying write for general error
[    9.497529] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.506447] mmcblk0: retrying write for general error
[    9.514940] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.523860] mmcblk0: retrying write for general error
[    9.532396] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.541326] mmcblk0: retrying write for general error
[    9.549781] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.558701] mmcblk0: retrying write for general error
[    9.567194] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.576113] mmcblk0: retrying write for general error
[    9.584608] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.593527] mmcblk0: retrying write for general error
[    9.601983] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.610906] mmcblk0: retrying write for general error
[    9.619360] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.628276] mmcblk0: retrying write for general error
[    9.636848] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.645770] mmcblk0: retrying write for general error
[    9.654275] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.663198] mmcblk0: retrying write for general error
[    9.671671] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.680594] mmcblk0: retrying write for general error
[    9.689039] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.697955] mmcblk0: retrying write for general error
[    9.706443] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.715363] mmcblk0: retrying write for general error
[    9.723847] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.732766] mmcblk0: retrying write for general error
[    9.741330] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.750259] mmcblk0: retrying write for general error
[    9.758713] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.767634] mmcblk0: retrying write for general error
[    9.776131] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.785051] mmcblk0: retrying write for general error
[    9.793551] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.802468] mmcblk0: retrying write for general error
[    9.810934] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.819823] mmcblk0: retrying write for general error
[    9.828321] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.837240] mmcblk0: retrying write for general error
[    9.845815] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.854738] mmcblk0: retrying write for general error
[    9.863207] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.872129] mmcblk0: retrying write for general error
[    9.880609] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.889497] mmcblk0: retrying write for general error
[    9.897957] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.906878] mmcblk0: retrying write for general error
[    9.915374] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.924293] mmcblk0: retrying write for general error
[    9.932768] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.941691] mmcblk0: retrying write for general error
[    9.950238] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.959128] mmcblk0: retrying write for general error
[    9.967624] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.976545] mmcblk0: retrying write for general error
[    9.985046] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[    9.993963] mmcblk0: retrying write for general error
[   10.002445] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.011370] mmcblk0: retrying write for general error
[   10.019835] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.028754] mmcblk0: retrying write for general error
[   10.037242] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.046163] mmcblk0: retrying write for general error
[   10.054947] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.063874] mmcblk0: retrying write for general error
[   10.072500] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.081425] mmcblk0: retrying write for general error
[   10.090038] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.098958] mmcblk0: retrying write for general error
[   10.107604] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.116526] mmcblk0: retrying write for general error
[   10.125167] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.134087] mmcblk0: retrying write for general error
[   10.142727] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.151652] mmcblk0: retrying write for general error
[   10.160221] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.169111] mmcblk0: retrying write for general error
[   10.177606] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.186565] mmcblk0: retrying write for general error
[   10.195068] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.203989] mmcblk0: retrying write for general error
[   10.212459] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.221383] mmcblk0: retrying write for general error
[   10.229827] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.238781] mmcblk0: retrying write for general error
[   10.247283] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.256204] mmcblk0: retrying write for general error
[   10.264779] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.273706] mmcblk0: retrying write for general error
[   10.282196] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.291120] mmcblk0: retrying write for general error
[   10.299578] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.308498] mmcblk0: retrying write for general error
[   10.316995] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.325916] mmcblk0: retrying write for general error
[   10.334415] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.343333] mmcblk0: retrying write for general error
[   10.351807] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.360731] mmcblk0: retrying write for general error
[   10.369269] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.378195] mmcblk0: retrying write for general error
[   10.386692] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.395616] mmcblk0: retrying write for general error
[   10.404107] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.413027] mmcblk0: retrying write for general error
[   10.421511] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.430434] mmcblk0: retrying write for general error
[   10.438888] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.447810] mmcblk0: retrying write for general error
[   10.456297] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.465217] mmcblk0: retrying write for general error
[   10.473969] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.482898] mmcblk0: retrying write for general error
[   10.491553] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.500477] mmcblk0: retrying write for general error
[   10.509096] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.518017] mmcblk0: retrying write for general error
[   10.526670] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.535593] mmcblk0: retrying write for general error
[   10.544252] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.553174] mmcblk0: retrying write for general error
[   10.561804] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.570729] mmcblk0: retrying write for general error
[   10.580400] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.589291] mmcblk0: retrying write for general error
[   10.598888] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.607812] mmcblk0: retrying write for general error
[   10.617384] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.626306] mmcblk0: retrying write for general error
[   10.635866] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.644789] mmcblk0: retrying write for general error
[   10.654355] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.663275] mmcblk0: retrying write for general error
[   10.672829] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.681751] mmcblk0: retrying write for general error
[   10.690498] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.699390] mmcblk0: retrying write for general error
[   10.707892] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.716815] mmcblk0: retrying write for general error
[   10.725321] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.734243] mmcblk0: retrying write for general error
[   10.742708] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.751632] mmcblk0: retrying write for general error
[   10.760093] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.769011] mmcblk0: retrying write for general error
[   10.777495] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.786413] mmcblk0: retrying write for general error
[   10.794973] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.803972] mmcblk0: retrying write for general error
[   10.812466] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.821392] mmcblk0: retrying write for general error
[   10.829848] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.838771] mmcblk0: retrying write for general error
[   10.847258] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.856178] mmcblk0: retrying write for general error
[   10.864670] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.873592] mmcblk0: retrying write for general error
[   10.882074] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.890999] mmcblk0: retrying write for general error
[   10.899536] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.908463] mmcblk0: retrying write for general error
[   10.916964] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.925883] mmcblk0: retrying write for general error
[   10.934373] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.943291] mmcblk0: retrying write for general error
[   10.951767] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.960690] mmcblk0: retrying write for general error
[   10.969148] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.978069] mmcblk0: retrying write for general error
[   10.986557] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   10.995477] mmcblk0: retrying write for general error
[   11.004052] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.012976] mmcblk0: retrying write for general error
[   11.021459] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.030382] mmcblk0: retrying write for general error
[   11.038852] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.047770] mmcblk0: retrying write for general error
[   11.056307] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.065234] mmcblk0: retrying write for general error
[   11.073732] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.082652] mmcblk0: retrying write for general error
[   11.091123] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.100012] mmcblk0: retrying write for general error
[   11.108764] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.117692] mmcblk0: retrying write for general error
[   11.126353] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.135273] mmcblk0: retrying write for general error
[   11.143922] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.152843] mmcblk0: retrying write for general error
[   11.161474] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.170397] mmcblk0: retrying write for general error
[   11.178992] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.187948] mmcblk0: retrying write for general error
[   11.196611] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.205533] mmcblk0: retrying write for general error
[   11.214144] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.223070] mmcblk0: retrying write for general error
[   11.231522] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.240449] mmcblk0: retrying write for general error
[   11.248910] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.257843] mmcblk0: retrying write for general error
[   11.266329] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.275250] mmcblk0: retrying write for general error
[   11.283762] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.292683] mmcblk0: retrying write for general error
[   11.301164] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.310053] mmcblk0: retrying write for general error
[   11.318611] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.327539] mmcblk0: retrying write for general error
[   11.336042] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.344963] mmcblk0: retrying write for general error
[   11.353413] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.362333] mmcblk0: retrying write for general error
[   11.370803] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.379689] mmcblk0: retrying write for general error
[   11.388173] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.397091] mmcblk0: retrying write for general error
[   11.405595] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.414516] mmcblk0: retrying write for general error
[   11.423076] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.432005] mmcblk0: retrying write for general error
[   11.440477] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.449366] mmcblk0: retrying write for general error
[   11.457851] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.466768] mmcblk0: retrying write for general error
[   11.475256] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.484176] mmcblk0: retrying write for general error
[   11.492650] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.501573] mmcblk0: retrying write for general error
[   11.510024] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.518943] mmcblk0: retrying write for general error
[   11.527503] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.536427] mmcblk0: retrying write for general error
[   11.544920] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.553841] mmcblk0: retrying write for general error
[   11.562319] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.571242] mmcblk0: retrying write for general error
[   11.579689] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.588610] mmcblk0: retrying write for general error
[   11.597088] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.606007] mmcblk0: retrying write for general error
[   11.614508] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.623428] mmcblk0: retrying write for general error
[   11.632132] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.641061] mmcblk0: retrying write for general error
[   11.649675] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.658594] mmcblk0: retrying write for general error
[   11.667243] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.676161] mmcblk0: retrying write for general error
[   11.684823] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.693744] mmcblk0: retrying write for general error
[   11.702367] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.711290] mmcblk0: retrying write for general error
[   11.719898] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.728818] mmcblk0: retrying write for general error
[   11.737582] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.746509] mmcblk0: retrying write for general error
[   11.755158] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.764078] mmcblk0: retrying write for general error
[   11.772700] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.781624] mmcblk0: retrying write for general error
[   11.790255] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.799143] mmcblk0: retrying write for general error
[   11.807789] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.816710] mmcblk0: retrying write for general error
[   11.825354] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.834273] mmcblk0: retrying write for general error
[   11.842861] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.851788] mmcblk0: retrying write for general error
[   11.860259] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.869147] mmcblk0: retrying write for general error
[   11.877643] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.886562] mmcblk0: retrying write for general error
[   11.895049] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.903969] mmcblk0: retrying write for general error
[   11.912424] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.921345] mmcblk0: retrying write for general error
[   11.929789] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.938709] mmcblk0: retrying write for general error
[   11.947282] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.956208] mmcblk0: retrying write for general error
[   11.964705] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.973627] mmcblk0: retrying write for general error
[   11.982103] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   11.991027] mmcblk0: retrying write for general error
[   11.999483] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.008402] mmcblk0: retrying write for general error
[   12.016895] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.025816] mmcblk0: retrying write for general error
[   12.034301] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.043228] mmcblk0: retrying write for general error
[   12.051746] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.060674] mmcblk0: retrying write for general error
[   12.069136] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.078070] mmcblk0: retrying write for general error
[   12.086547] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.095466] mmcblk0: retrying write for general error
[   12.103961] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.112882] mmcblk0: retrying write for general error
[   12.121348] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.130274] mmcblk0: retrying write for general error
[   12.138726] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.147646] mmcblk0: retrying write for general error
[   12.156219] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.165144] mmcblk0: retrying write for general error
[   12.173636] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.182598] mmcblk0: retrying write for general error
[   12.191078] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.199966] mmcblk0: retrying write for general error
[   12.208451] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.217373] mmcblk0: retrying write for general error
[   12.225859] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.234811] mmcblk0: retrying write for general error
[   12.243268] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.252188] mmcblk0: retrying write for general error
[   12.260778] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.269669] mmcblk0: retrying write for general error
[   12.278161] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.287081] mmcblk0: retrying write for general error
[   12.295572] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.304494] mmcblk0: retrying write for general error
[   12.312973] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.321895] mmcblk0: retrying write for general error
[   12.330353] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.339239] mmcblk0: retrying write for general error
[   12.347733] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.356653] mmcblk0: retrying write for general error
[   12.365378] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.374304] mmcblk0: retrying write for general error
[   12.382934] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.391858] mmcblk0: retrying write for general error
[   12.400477] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.409364] mmcblk0: retrying write for general error
[   12.418012] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.426930] mmcblk0: retrying write for general error
[   12.435587] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.444505] mmcblk0: retrying write for general error
[   12.453138] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.462066] mmcblk0: retrying write for general error
[   12.470643] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.479534] mmcblk0: retrying write for general error
[   12.488043] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.496964] mmcblk0: retrying write for general error
[   12.505454] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.514374] mmcblk0: retrying write for general error
[   12.522850] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.531777] mmcblk0: retrying write for general error
[   12.540248] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.549137] mmcblk0: retrying write for general error
[   12.557628] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.566547] mmcblk0: retrying write for general error
[   12.575426] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.584353] mmcblk0: retrying write for general error
[   12.593146] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.602071] mmcblk0: retrying write for general error
[   12.610852] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.619740] mmcblk0: retrying write for general error
[   12.628541] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.637460] mmcblk0: retrying write for general error
[   12.646248] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.655167] mmcblk0: retrying write for general error
[   12.663945] mmcblk0: mmc_blk_err_check: general error sending status command, card status 0x80900
[   12.672868] mmcblk0: retrying write for general error
[   12.678054] JBD2: recovery failed
[   12.681531] EXT4-fs (mmcblk0p2): error loading journal
[   12.709846] yaffs: dev is 187695106 name is "mmcblk0p2" ro
[   12.715509] yaffs: passed flags ""
[   12.719191] yaffs: dev is 187695106 name is "mmcblk0p2" ro
[   12.724937] yaffs: passed flags ""
[   12.728465] List of all partitions:
[   12.732104] b300         7761920 mmcblk0  driver: mmcblk
[   12.737462]   b301          516460 mmcblk0p1 32f8b1a6-01
[   12.742882]   b302         7222845 mmcblk0p2 32f8b1a6-02
[   12.748231] 1f00            4096 mtdblock0  (driver?)
[   12.753430] 1f01            2048 mtdblock1  (driver?)
[   12.758519] 1f02            1024 mtdblock2  (driver?)
[   12.763708] 1f03            3072 mtdblock3  (driver?)
[   12.768797] 1f04            8192 mtdblock4  (driver?)
[   12.773920] 1f05          243712 mtdblock5  (driver?)
[   12.778996] No filesystem could mount root, tried:  ext3 ext2 ext4 vfat fuseblk yaffs yaffs2
[   12.787612] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
飞凌-chongzi 发表于 2019-11-11 10:30:02 | 显示全部楼层
您好,请确保您的制卡镜像和拨码开关正确,在制卡过程中是否有报错,建议您更换一个SD卡再试一下
