查看: 29802|回复: 1
[Linux] 系统启动失败
xydjonny 发表于 2019-11-14 10:09:58 | 显示全部楼层 |阅读模式
ok335xs 直接烧写官方提供的bin目录下文件,系统启动不了,报如下错误,该如何处理呢?有遇到过这个现象的吗?
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=7,2048 rootfstype=ubifs rootwait=1 screentype=R screensize=800x480-7 calibrate=Y laohua=N
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash
input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    4.476725] rtc-ds1307 2-0068: setting system clock to 2000-01-01 00:00:22 UTC (946684822)
[    4.485807] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
[    4.493186] Please append a correct "root=" boot option; here are the available partitions:
[    4.501946] 1f00            2048 mtdblock0  (driver?)
[    4.507217] 1f01            2048 mtdblock1  (driver?)
[    4.512501] 1f02            2048 mtdblock2  (driver?)
[    4.517772] 1f03            2048 mtdblock3  (driver?)
[    4.523053] 1f04            2048 mtdblock4  (driver?)
[    4.528322] 1f05            2048 mtdblock5  (driver?)
[    4.533604] 1f06            8192 mtdblock6  (driver?)
[    4.538874] 1f07          241664 mtdblock7  (driver?)
[    4.544152] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    4.552782] Backtrace:
[    4.555371] [<c0017d68>] (dump_backtrace+0x0/0x110) from [<c04c5bb4>] (dump_stack+0x18/0x1c)
[    4.564179]  r6:df024000 r5:c068e7fc r4:c071a290 r3:c06bf0c8
[    4.570105] [<c04c5b9c>] (dump_stack+0x0/0x1c) from [<c04c5c24>] (panic+0x6c/0x1a0)
[    4.578111] [<c04c5bb8>] (panic+0x0/0x1a0) from [<c065fcb4>] (mount_block_root+0x184/0x228)
[    4.586824]  r3:c06bf0c8 r2:00000000 r1:df02df78 r0:c05b8610
[    4.592747]  r7:00008000
[    4.595394] [<c065fb30>] (mount_block_root+0x0/0x228) from [<c065ffd0>] (prepare_namespace+0xac/0x1e0)
[    4.605113] [<c065ff24>] (prepare_namespace+0x0/0x1e0) from [<c065f90c>] (kernel_init+0x124/0x130)
[    4.614458]  r5:c069aa68 r4:c069aa68
[    4.618213] [<c065f7e8>] (kernel_init+0x0/0x130) from [<c0041770>] (do_exit+0x0/0x67c)
[    4.626472]  r5:c065f7e8 r4:00000000
Forlinx-Niuzc 发表于 2019-11-14 11:50:51 | 显示全部楼层
您烧写的镜像好像与开发板不对应,检查一下烧写镜像是1Gnand还是256Mnand
