查看: 58158|回复: 1
[Linux] OKMX6UL-C2 nand 256m 添加SPI驱动不能正常工作
i.MX6UL通行证
Xiaoooo 发表于 2019-12-7 18:32:22 | 显示全部楼层 |阅读模式
使用OKMX6UL-C2 nand 256m添加了两路SPI驱动,烧录后显示了spidev0.0和spidev1.0,但是使用测试代码输出全为0,连接我们自己的设备通信也不成功。设备树文件:
&ecspi1 {
             compatible = "fsl,imx51-ecspi";
             fsl,spi-num-chipselects = <1>;
             cs-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>;
             pinctrl-names = "default";
             pinctrl-0 = <&pinctrl_ecspi1>;
             status = "okay";
                spidev@0{
                        compatible = "spidev";
                        spi-max-frequency = <20000000>;
                        reg = <0>;
                        status = "okay";
&ecspi2 {
        cs-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>;
        pinctrl-0 = <&pinctrl_ecspi2>;
        status = "okay";
                spidev@0{
                        reg = <0>;
                        status = "okay";
pinctrl_ecspi1: ecspi1grp {
                         fsl,pins = <
                                MX6UL_PAD_CSI_DATA07__ECSPI1_MISO   0x100b1
                                MX6UL_PAD_CSI_DATA06__ECSPI1_MOSI   0x100b1
                                MX6UL_PAD_CSI_DATA04__ECSPI1_SCLK   0x100b1
                                MX6UL_PAD_CSI_DATA05__ECSPI1_SS0    0x100b1
pinctrl_ecspi2: ecspi2grp {
                         fsl,pins = <
                                MX6UL_PAD_CSI_DATA03__ECSPI2_MISO   0x100b1
                                MX6UL_PAD_CSI_DATA02__ECSPI2_MOSI   0x100b1
                                MX6UL_PAD_CSI_DATA00__ECSPI2_SCLK   0x100b1
                                MX6UL_PAD_CSI_DATA01__ECSPI2_SS0    0x100b1
Forlinx-Niuzc 发表于 2019-12-9 15:48:35 | 显示全部楼层
您是按照应用笔记上的办法改的是吧,引脚的其他复用是否关掉了,看一下硬件是否有问题,如果还不行,把修改内容都发给我,我再看看
