- 28
贡献174
飞刀16 FD
注册时间2019-12-31
在线时间5 小时
Makefile:
CROSS_COMPILE := /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-
CC:= $(CROSS_COMPILE)gcc
LD:= $(CROSS_COMPILE)ld
obj-m := hello.o
KERNELDIR = /root/workspace/allwinner/A40i/bsp/lichee/linux-3.10
PWD := $(shell pwd)
modules:
$(MAKE) -C $(KERNELDIR) M=$(PWD) modules
modules_install:
$(MAKE) -C $(KERNELDIR) M=$(PWD) modules_install
clean:
rm -f *.o
rm -f *.symvers
rm -f *.order
rm -f *.ko
rm -f *.mod.c
.c文件:
* file name: hello.c
#include<linux/module.h>
#include<linux/init.h>
#include<linux/moduleparam.h>
MODULE_AUTHOR("Kevin Taylor");
MODULE_LICENSE("GPL");
static int nbr = 10;
module_param(nbr, int, S_IRUGO);
static int __init hello_init(void)
int i;
printk(KERN_ALERT"Init hello mudule...\n");
for(i=0;i<nbr;i++)
printk(KERN_ALERT"Hello, how are you? %d\n", i);
return 0;
static void __exit hello_exit(void)
printk(KERN_ALERT"Exit hello mudule...\n");
printk(KERN_ALERT"I come from hello's module, I have been unload.\n");
module_init(hello_init);
module_exit(hello_exit);
MODULE_DESCRIPTION("my first module");
MODULE_ALIAS("A **st module");
加载错误:
# insmod hello.ko -f
insmod: can't insert 'hello.ko': invalid module format
# ls -al
total 211
drwxr-xr-x 2 root root 1024 Jan 2 12:57 .
drwxr-xr-x 23 root root 1024 Jan 1 20:36 ..
-rwxrwxrwx 1 root root 31488 Jan 2 02:15 hello.ko
-rwx------ 1 root root 10012 Jan 1 12:35 helloworld
-rwxrwxrwx 1 root root 171684 Jan 2 04:57 udp_diag.ko
# dmesg |tail -6
[ 300.554213] hello: unknown relocation: 10
[ 3544.724890] hello: unknown relocation: 10
[ 6966.367209] ************Serial : 44c078a1840428060911
[14499.699228] hello: unknown relocation: 10
[14579.513269] ************Serial : 44c078a1840428060911
[15858.382734] hello: unknown relocation: 10
用内核一起编译的驱动没有问题。
