查看: 21890|回复: 4
[Linux] 更换开机界面,开发板启动不了
XX18通行证
YCG2018 发表于 2020-1-28 12:48:44 | 显示全部楼层 |阅读模式
你好
产品开发中需要更新开机logo,在请英飞凌工程师帮忙编译了boot.img后,发现开机后一直处于开机界面,kernel似乎启动不了。
0K4418平台,android5.1
我按照spec说明,自己编译了boot.img/ubootp.bin,download之后问题一样。
抓了部分串口log,麻烦看看原因,谢谢!
[    0.065000] mach: add amba device uart-pl011.0
[    0.065000] mach: add amba device uart-pl011.1
[    0.065000] mach: add amba device uart-pl011.2
[    0.066000] mach: add amba device uart-pl011.3
[    0.066000] mach: add amba device uart-pl011.4
[    0.066000] mach: add amba device uart-pl011.5
[    0.066000] mach: add amba device pl08xdmac.0
[    0.066000] mach: add amba device pl08xdmac.1
[    0.066000] mach: add amba device ssp-pl022.0
[    0.066000] mach: add amba device ssp-pl022.1
[    0.066000] mach: add amba device ssp-pl022.2
[    0.072000] mach: add device syncgen [2]
[    0.072000] mach: add device lcd 800x480
[    0.072000] mach: add device i2c bus (array:2)
[    0.072000] mach: add device generic pwm (array:4)
[    0.072000] mach: add device generic gpio (array:6)
[    0.073000] mach: add device i2s (array:1)
[    0.073000] mach: add device spdif tx
[    0.073000] mach: add device usb_ehci
[    0.073000] mach: add device usb otg
[    0.073000] mach: add device ion-nxp
[    0.073000] mach: add device adc
[    0.073000] mach: add graphic device opengl|es
[    0.073000] mach: add device watchdog
[    0.073000] [Register board platform devices]
[    0.073000] plat: add dynamic frequency (pll.1)
[    0.074000] plat: add device adc temp
[    0.074000] plat: add framebuffer
[    0.074000] plat: add device asoc-wm8960
[    0.074000] plat: add device rx8010
[    0.074000] plat: add device sdmmc [2]
[    0.075000] plat: add device sdmmc [0]
[    0.076000] plat: add device sdmmc [1]
[    0.077000] plat: add backlight pwm device
[    0.077000] plat: add device nxp mac
[    0.078000] plat: add device keypad
[    0.078000] plat: add device nxe2000 pmic
[    0.078000] plat: add device spdif playback
[    0.078000] plat: add device nxp-v4l2
[    0.078000] plat: register spidev
[    0.078000] gt928_reset 561 74
[    0.078000] gt928_reset 568 76
[    0.102000] gt911_reset 593 66
[    0.102000] gt911_reset 600 141
[    0.147000] plat: add touch(gt9xx).0 device
[    0.147000] plat: add device gpio_led_heartbeat
[    0.147000] plat: add device hdmi-cec
[    0.147000] plat: add device ppm_device
[    0.147000]
[    0.148000] Serial: AMBA PL011 UART driver
[    0.148000] uart-pl011.0: ttyAMA0 at MMIO 0xc00a1000 (irq = 7) is a PL011 rev
[    0.148000] uart-pl011.1: ttyAMA1 at MMIO 0xc00a0000 (irq = 6) is a PL011 rev
[    0.149000] uart-pl011.2: ttyAMA2 at MMIO 0xc00a2000 (irq = 8) is a PL011 rev
[    0.149000] uart-pl011.3: ttyAMA3 at MMIO 0xc00a3000 (irq = 9) is a PL011 rev
[    0.149000] uart-pl011.4: ttyAMA4 at MMIO 0xc006d000 (irq = 10) is a PL011 re
v3
[    0.150000] uart-pl011.5: ttyAMA5 at MMIO 0xc006f000 (irq = 11) is a PL011 re
v3
[    0.153000] console [ttyAMA5] enabled
[    0.182000] bio: create slab <bio-0> at 0
[    0.184000] gpiochip_add: registered GPIOs 0 to 31 on device: nxp-gpio.0
[    0.187000] gpiochip_add: registered GPIOs 32 to 63 on device: nxp-gpio.1
[    0.190000] gpiochip_add: registered GPIOs 64 to 95 on device: nxp-gpio.2
[    0.193000] gpiochip_add: registered GPIOs 96 to 127 on device: nxp-gpio.3
[    0.196000] gpiochip_add: registered GPIOs 128 to 159 on device: nxp-gpio.4
[    0.199000] gpiochip_add: registered GPIOs 160 to 167 on device: nxp-gpio.5
[    0.203000] pl08xdmac pl08xdmac.0: Unbalanced pm_runtime_enable!
[    0.206000] pl08xdmac pl08xdmac.0: initialized 8 virtual memcpy channels
[    0.209000] pl08xdmac pl08xdmac.0: initialized 16 virtual slave channels
[    0.215000] pl08xdmac pl08xdmac.0: DMA: PL080 rev1 at 0xc0000000 irq 1
[    0.218000] pl08xdmac pl08xdmac.1: Unbalanced pm_runtime_enable!
[    0.221000] pl08xdmac pl08xdmac.1: initialized 8 virtual memcpy channels
[    0.225000] pl08xdmac pl08xdmac.1: initialized 15 virtual slave channels
[    0.231000] pl08xdmac pl08xdmac.1: DMA: PL080 rev1 at 0xc0001000 irq 2
[    0.235000] nxp_ion_probe success!!!
[    0.237000] SCSI subsystem initialized
[    0.240000] ssp-pl022 ssp-pl022.0: ARM PL022 driver, device ID: 0x00041022
[    0.243000] pl022: mapped registers from 0xc005b000 to f005b000
[    0.246000] ssp-pl022 ssp-pl022.0: setup for DMA on RX dma1chan7, TX dma1chan
[    0.250000] ssp-pl022 ssp-pl022.0: Max speed that can be programmed is 500000
0 Hz, you requested 10000000
[    0.253000] ssp-pl022 ssp-pl022.0: will use autosuspend for runtime pm, delay
10ms
[    0.256000] ssp-pl022 ssp-pl022.1: ARM PL022 driver, device ID: 0x00041022
[    0.259000] pl022: mapped registers from 0xc005c000 to f005c000
[    0.262000] ssp-pl022 ssp-pl022.1: setup for DMA on RX dma1chan9, TX dma1chan
[    0.266000] ssp-pl022 ssp-pl022.2: ARM PL022 driver, device ID: 0x00041022
[    0.269000] pl022: mapped registers from 0xc005f000 to f005f000
[    0.272000] ssp-pl022 ssp-pl022.2: setup for DMA on RX dma1chan11, TX dma1cha
n10
[    0.276000] usbcore: registered new inte**ce driver usbfs
[    0.278000] usbcore: registered new inte**ce driver hub
[    0.281000] usbcore: registered new device driver usb
[    0.285000] i2c-gpio i2c-gpio.0: using pins 72 (SDA) and 71 (SCL)
[    0.288000] i2c-gpio i2c-gpio.3: using pins 80 (SDA) and 79 (SCL)
[    0.292000] nxp-i2c.1:   195312 hz [pclk=200000000, clk = 256, scale= 3, time
out= 500 ms]
[    0.296000] nxp-i2c.2:    97656 hz [pclk=200000000, clk = 256, scale= 7, time
out= 500 ms]
[    0.300000] Linux media inte**ce: v0.10
[    0.303000] Linux video capture inte**ce: v2.00
[    0.305000] pps_core: LinuxPPS API ver. 1 registered
[    0.308000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti <giometti@linux.it>
[    0.311000] PTP clock support registered
[    0.314000] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.317000] Bluetooth: Core ver 2.16
[    0.320000] NET: Registered protocol family 31
[    0.323000] Bluetooth: HCI device and connection manager initialized
[    0.326000] Bluetooth: HCI socket layer initialized
[    0.329000] Bluetooth: L2CAP socket layer initialized
[    0.332000] Bluetooth: SCO socket layer initialized
[    0.335000] cfg80211: Calling CRDA to update world regulatory domain
[    0.343000] NXE2000_DC1: 950 <--> 2000 mV at 1250 mV normal standby
[    0.351000] NXE2000_DC2: 1000 <--> 2000 mV at 1100 mV normal standby
[    0.359000] NXE2000_DC3: 1000 <--> 3487 mV at 3300 mV normal standby
[    0.367000] NXE2000_DC4: 1000 <--> 2000 mV at 1500 mV normal standby
[    0.375000] NXE2000_DC5: 1000 <--> 2000 mV at 1500 mV normal standby
[    0.384000] NXE2000_LDO1: 1000 <--> 3475 mV at 2800 mV normal standby
[    0.393000] NXE2000_LDO2: 1000 <--> 3475 mV at 1800 mV normal standby
[    0.401000] NXE2000_LDO3: 1000 <--> 3475 mV at 1800 mV normal standby
[    0.409000] NXE2000_LDO4: 1000 <--> 3475 mV at 1800 mV normal standby
[    0.417000] NXE2000_LDO5: 1000 <--> 3475 mV at 1200 mV normal standby
[    0.426000] NXE2000_LDO6: 1000 <--> 3475 mV at 3300 mV normal standby
[    0.435000] NXE2000_LDO7: 1000 <--> 3475 mV at 3300 mV normal standby
[    0.443000] NXE2000_LDO8: 1000 <--> 3475 mV at 3300 mV normal standby
[    0.451000] NXE2000_LDO9: 1000 <--> 3475 mV at 3300 mV normal standby
[    0.460000] NXE2000_LDO10: 1000 <--> 3475 mV at 1000 mV normal standby
[    0.469000] NXE2000_LDORTC1: 1700 <--> 3475 mV at 1800 mV normal standby
[    0.478000] NXE2000_LDORTC2: 1000 <--> 3475 mV at 1000 mV normal standby
[    0.485000] i2c-core: driver [nxe2000] using legacy suspend method
[    0.492000] i2c-core: driver [nxe2000] using legacy resume method
[    0.498000] Switching to clocksource source timer
[    0.504000] Clockevents: could not switch to one-shot mode:
[    0.504000] Clockevents: could not switch to one-shot mode: dummy_timer is no
t functional.
[    0.504000]  dummy_timer is not functional.
[    0.504000] Could not switch to high resolution mode on CPU 2
[    0.504000] Could not switch to high resolution mode on CPU 0
t functional.
[    0.504000] Could not switch to high resolution mode on CPU 3
[    0.553000]  dummy_timer is not functional.
[    0.557000] Could not switch to high resolution mode on CPU 1
[    0.563000] NET: Registered protocol family 2
[    0.568000] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.576000] TCP established hash table entries: 131072 (order: 8, 1048576 byt
es)
[    0.586000] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.594000] TCP: Hash tables configured (established 131072 bind 65536)
[    0.601000] TCP: reno registered
[    0.604000] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.610000] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.617000] NET: Registered protocol family 1
[    0.622000] RPC: Registered named UNIX socket transport module.
[    0.628000] RPC: Registered udp transport module.
[    0.633000] RPC: Registered tcp transport module.
[    0.638000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.645000] Disply Reset Status : On
[    0.649000] Display LCD register operation
[    0.653000] Display.0 fps=60 (16 ms), wait=32 jiffies(1000), Pixelclk=5119991
6hz
[    0.660000] LCD : [1]=LCD connect to [5]=SYNCGEN0
[    0.677000] NFS: Registering the id_resolver key type
[    0.683000] fuse init (API version 7.18)
[    0.687000] msgmni has been set to 1504
[    0.694000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
49)
[    0.697000] io scheduler noop registered
[    0.699000] io scheduler deadline registered
[    0.701000] io scheduler cfq registered (default)
[    0.704000] display.0 connected to fb.0  ...
[    0.707000] nxp-fb.0: dma addr = 0x70600000, buf[0xb01b6940]
[    0.709000] nxp-fb.0: dma addr = 0x70777000, buf[0xb01b6ac0]
[    0.727000] nxp-fb 0: out[0], 800 * 480 - 32 bpp (phys:70600000 virt:0xb06000
00 max:3072000)
[    0.736000] display.1 connected to fb.1  ...
[    0.740000] nxp-fb.1: dma addr = 0x708ee000, buf[0xb00b1e00]
[    0.746000] nxp-fb.1: dma addr = 0x70c72000, buf[0xb00b1f80]
[    0.752000] nxp-fb 1: out[1], 1280 * 720 - 32 bpp (phys:708ee000 virt:0xb08ee
000 max:7372800)
[    0.761000] uart-pl011 uart-pl011.0: no DMA platform data
[    0.766000] uart-pl011 uart-pl011.1: no DMA platform data
[    0.772000] uart-pl011 uart-pl011.2: no DMA platform data
[    0.777000] uart-pl011 uart-pl011.3: no DMA platform data
[    0.783000] uart-pl011 uart-pl011.4: no DMA platform data
[    0.788000] uart-pl011 uart-pl011.5: no DMA platform data
[    0.803000] brd: module loaded
[    0.811000] loop: module loaded
[    0.815000] CAN device driver inte**ce
[    0.819000] ssp-pl022 ssp-pl022.0: Max speed that can be programmed is 500000
[    1.830000] mcp251x spi0.1: MCP251x didn't enter in conf mode after reset
[    1.837000] mcp251x spi0.1: Probe failed
[    1.841000] mcp251x spi0.1: probe failed
[    1.845000]  -- nxpmac initialize --
[    1.849000] stmmac - user ID: 0x37, Synopsys ID: 0x37
[    1.854000]  Ring mode enabled
[    1.857000]  DMA HW capability register supported
[    1.862000]  Enhanced/Alternate descriptors
[    1.866000]  Enabled extended descriptors
[    1.870000]  RX Checksum Offload Engine supported (type 2)
[    1.875000]  TX Checksum insertion supported
[    1.880000]  Wake-Up On Lan supported
[    1.883000]  Enable RX Mitigation via HW Watchdog Timer
[    1.923000] stmmac: probed
[    1.925000] eth0: No PHY found
[    1.934000] stmmac_pltfr_probe: main driver probe failed
[    1.939000] PPP generic driver version 2.4.2
[    1.944000] PPP BSD Compression module registered
[    1.948000] PPP Deflate Compression module registered
[    1.955000] PPP MPPE Compression module registered
[    1.960000] NET: Registered protocol family 24
[    1.964000] usbcore: registered new inte**ce driver asix
[    1.970000] usbcore: registered new inte**ce driver cdc_ether
[    1.976000] usbcore: registered new inte**ce driver net1080
[    1.982000] usbcore: registered new inte**ce driver cdc_subset
[    1.988000] usbcore: registered new inte**ce driver zaurus
[    1.993000] usbcore: registered new inte**ce driver cdc_ncm
[    1.999000] GobiNet: Quectel_WCDMA<E_Linux&Android_GobiNet_Driver_V1.3.0
[    2.006000] usbcore: registered new inte**ce driver GobiNet
[    2.012000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.018000] nxp-ehci nxp-ehci: SLsi Synopsys EHCI Host Controller
[    2.025000] nxp-ehci nxp-ehci: new USB bus registered, assigned bus number 1
[    2.032000] nxp-ehci nxp-ehci: irq 50, io mem 0xc0030000
[    2.043000] nxp-ehci nxp-ehci: USB 0.0 started, EHCI 1.00
[    2.048000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.055000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
[    2.062000] usb usb1: Product: SLsi Synopsys EHCI Host Controller
[    2.068000] usb usb1: Manufacturer: Linux 3.4.39 ehci_hcd
[    2.074000] usb usb1: SerialNumber: nxp-ehci
[    2.079000] hub 1-0:1.0: USB hub found
[    2.083000] hub 1-0:1.0: 3 ports detected
[    2.087000] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.296000] Core Release: 2.93a
[    2.299000] Setting default values for core params
[    2.304000] Finished setting default values for core params
[    2.389000] usb 1-1: new high-speed USB device number 2 using nxp-ehci
[    2.509000] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[    2.512000] Using Descriptor DMA mode
[    2.512000] Dedicated Tx FIFOs mode
[    2.512000] dwc_otg dwc_otg: DWC OTG Controller
[    2.512000] dwc_otg dwc_otg: new USB bus registered, assigned bus number 2
[    2.513000] dwc_otg dwc_otg: irq 49, io mem 0x00000000
[    2.513000] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.513000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=
[    2.513000] usb usb2: Product: DWC OTG Controller
[    2.513000] usb usb2: Manufacturer: Linux 3.4.39 dwc_otg_hcd
[    2.513000] usb usb2: SerialNumber: dwc_otg
[    2.513000] hub 2-0:1.0: USB hub found
[    2.513000] hub 2-0:1.0: 1 port detected
[    2.514000] Initializing USB Mass Storage driver...
[    2.514000] usbcore: registered new inte**ce driver usb-storage
[    2.514000] USB Mass Storage support registered.
[    2.514000] usbcore: registered new inte**ce driver usbserial
[    2.514000] usbserial: USB Serial Driver core
[    2.515000] usbcore: registered new inte**ce driver option
[    2.515000] USB Serial support registered for GSM modem (1-port)
[    2.515000] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    2.515000] xr_usb_serial_common: Exar USB UART (serial port) driver
[    2.517000] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    2.517000] android_usb gadget: Number of LUNs=1
[    2.517000]  lun0: LUN: removable file: (no medium)
[    2.518000] android_usb gadget: android_usb ready
[    2.518000] mousedev: PS/2 mouse device common for all mice
[    2.519000] input: Nexell Keypad as /devices/platform/nxp-keypad/input/input0
[    2.522000] msg ft_i2c_chip_id_read i2c read error: -11
[    2.522000] ft i2c test failed time 1.
[    2.534000] msg ft_i2c_chip_id_read i2c read error: -11
[    2.534000] ft i2c test failed time 2.
[    2.546000] msg ft_i2c_chip_id_read i2c read error: -11
[    2.546000] ft i2c test failed time 3.
[    2.558000] msg ft_i2c_chip_id_read i2c read error: -11
[    2.558000] ft i2c test failed time 4.
[    2.570000] msg ft_i2c_chip_id_read i2c read error: -11
[    2.570000] ft i2c test failed time 5.I2C communication ERROR!
[    2.581000] i2c-core: driver [ft5x06_ts] using legacy suspend method
[    2.581000] i2c-core: driver [ft5x06_ts] using legacy resume method
[    2.581000] <<-GTP-928-INFO->> GTP driver installing...
[    2.581000] <<-GTP-911-INFO->> GTP driver installing...
[    2.581000] <<-GTP-911-INFO->> GTP Driver Version: V2.2<2014/01/14>
[    2.581000] <<-GTP-911-INFO->> GTP Driver Built@08:59:34, Jul 19 2019
[    2.581000] <<-GTP-911-INFO->> GTP I2C Address: 0x14
[    2.581000] gt911_reset 593 66
[    2.581000] gt911_reset 600 141
[    2.626000] <<-GTP-911-INFO->> Guitar reset
[    2.710000] <<-GTP-911-INFO->> IC Version: 911_1060
[    2.735000] <<-GTP-911-INFO->> X_MAX: 800, Y_MAX: 480, TRIGGER: 0x01
[    2.746000] input: goodix-ts as /devices/virtual/input/input1
[    2.746000] <<-GTP-911-INFO->> GTP works in interrupt mode.
[    2.746000] <<-GTP-911-INFO->> Esd started
[    2.749000] rtc-rx8010 1-0032: Update timer was detected
[    2.751000] rtc-rx8010 1-0032: rtc core: registered rx8010 as rtc0
[    2.751000] i2c /dev entries driver
[    2.752000] lirc_dev: IR Remote Control driver registered, major 247
[    2.752000] IR AD009 protocol handler initialized
[    2.753000] Registered IR keymap rc-ad009
[    2.754000] input: nxp_ir_recv as /devices/virtual/rc/rc0/input2
[    2.754000] rc0: nxp_ir_recv as /devices/virtual/rc/rc0
[    2.754000] i2c-core: driver [OV5640] using legacy suspend method
[    2.755000] JJx:video0
[    2.755000] JJx:video1
[    2.756000] ov5645: ov5645_probe
[    2.756000] ov5645: ov5645_initialize_ctrls
[    2.756000] JJx:video2
[    2.756000] JJx:video3
[    2.757000] ov5640: ov5640_probe
[    2.757000] ov5640: ov5640_initialize_ctrls
[    2.758000] JJx:video4
[    2.758000] JJx:video5
[    2.758000] JJx:video6
[    2.759000] JJx:video7
[    2.759000] JJx:video8
[    2.760000] JJx:v4l-subdev0
[    2.760000] JJx:v4l-subdev1
[    2.761000] JJx:v4l-subdev2
[    2.761000] JJx:v4l-subdev3
[    2.761000] JJx:v4l-subdev4
[    2.761000] JJx:v4l-subdev5
[    2.761000] JJx:v4l-subdev6
[    2.762000] JJx:v4l-subdev7
[    2.762000] JJx:v4l-subdev8
[    2.762000] JJx:v4l-subdev9
[    2.762000] JJx:v4l-subdev10
[    2.763000] JJx:v4l-subdev11
[    2.763000] JJx:v4l-subdev12
[    2.763000] nxp_hdmi_cec_probe success
[    2.764000] usbcore: registered new inte**ce driver uvcvideo
[    2.764000] USB Video Class driver (1.1.1)
[    2.764000] nxp_wdt: NXP Watchdog Timer, (c) 2014 SLsiAP
[    2.766000] nxp-wdt nxp-wdt: watchdog inactive, reset disabled, irq disabled
[    2.767000] device-mapper: uevent: version 1.0.3
[    2.767000] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-d
evel@redhat.com
[    2.768000] usbcore: registered new inte**ce driver btusb
[    2.768000] usbcore: registered new inte**ce driver rtk_btusb
[    2.768000] DVFS: ASV[0] IDS(10mA,  6) Ro(110, 81)
[    2.768000] ASV  0 =  1000000khz,  1175000 uV
[    2.768000] ASV  1 =   900000khz,  1150000 uV
[    2.768000] ASV  2 =   800000khz,  1125000 uV
[    2.768000] ASV  3 =   700000khz,  1100000 uV
[    2.768000] ASV  4 =   600000khz,  1075000 uV
[    2.768000] ASV  5 =   500000khz,  1075000 uV
[    2.768000] ASV  6 =   400000khz,  1075000 uV
[    2.768000] DVFS: regulator vdd_arm_1.3V
[    2.768000] DVFS: cpu DVFS with PLL.1 [tables=7]
[    2.769000] cpuidle: using governor ladder
[    2.769000] cpuidle: using governor menu
[    2.770000] Synopsys Designware ** Card Inte**ce Driver
[    2.770000] dw_mmc dw_mmc.2: Using internal DMA controller.
[    2.770000] mmc0: no vmmc regulator found
[    2.772000] dw_mmc dw_mmc.2: Version ID is 250a
[    2.772000] dw_mmc dw_mmc.2: DW MMC controller at irq 45, 32 bit host data wi
dth, 32 deep fifo hw timeout 500 ms
[    2.772000] dw_mmc dw_mmc.0: Using internal DMA controller.
[    2.772000] mmc1: no vmmc regulator found
[    2.772000] dw_mmc dw_mmc.0: Using external card detect irq 225 (io 161)
[    2.774000] dw_mmc dw_mmc.0: Version ID is 250a
[    2.774000] dw_mmc dw_mmc.0: DW MMC controller at irq 43, 32 bit host data wi
[    2.774000] dw_mmc dw_mmc.1: Using PIO mode.
[    2.774000] mmc2: no vmmc regulator found
[    2.776000] dw_mmc dw_mmc.1: Version ID is 250a
[    2.776000] dw_mmc dw_mmc.1: DW MMC controller at irq 44, 32 bit host data wi
[    2.777000] usbcore: registered new inte**ce driver usbhid
[    2.777000] usbhid: USB HID core driver
[    2.778000] ADC: CHs 8, 200000(1000000 ~ 130208) sample rate, polling mode, s
cale=166(bit 6)
[    2.780000] snd pcm: register sound platform 'nxp-pcm'
[    2.781000] snd i2s: ch 0, master, iis mode, 48000(47999)hz, 32 FBITs, MCLK=1
2287980hz, RFS=256
[    2.781000] wm8960 1-001a: No platform data supplied
[    2.783000] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz
, actual 396825HZ div = 63)
[    2.794000] mmc_host mmc0: device is being hw reset
[    2.838000] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000
Hz, actual 50000000HZ div = 0)
[    2.839000] mmc0: new high speed MMC card at address 0001
[    2.839000] mmcblk0: mmc0:0001 8GME4R 7.28 GiB
[    2.840000] mmcblk0boot0: mmc0:0001 8GME4R partition 1 4.00 MiB
[    2.840000] mmcblk0boot1: mmc0:0001 8GME4R partition 2 4.00 MiB
[    2.843000]  mmcblk0: p1 p2 p3 p4 < p5 p6 p7 >
[    2.848000]  mmcblk0boot1: unknown partition table
[    2.851000]  mmcblk0boot0: unknown partition table
[    2.862000] mmc_host mmc2: Bus speed (slot 0) = 25000000Hz (slot req 400000Hz
, actual 390625HZ div = 32)
[    2.901000] mmc_host mmc2: Bus speed (slot 0) = 25000000Hz (slot req 300000Hz
, actual 297619HZ div = 42)
[    2.912000] asoc: wm8960-hifi <-> nxp-i2s.0 mapping ok
[    2.913000] wm8960-dai: register card wm8960-hifi -> nxp-i2s.0
[    2.914000] spdif-tx: 48000(47999)Hz, MCLK=12287980hz HDMI out
[    2.916000] asoc: dit-hifi <-> nxp-spdif-tx mapping ok
[    2.917000] GACT probability NOT on
[    2.917000] Mirror/redirect action on
[    2.917000] u32 classifier
[    2.917000]     Actions configured
[    2.917000] Netfilter messages via NETLINK v0.30.
[    2.917000] nf_conntrack version 0.5.0 (12036 buckets, 48144 max)
[    2.918000] ctnetlink v0.93: registering with nfnetlink.
[    2.918000] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    2.918000] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    2.919000] xt_time: kernel timezone is -0000
[    2.919000] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.920000] arp_tables: (C) 2002 David S. Miller
[    2.920000] TCP: cubic registered
[    2.920000] Initializing XFRM netlink socket
[    2.921000] NET: Registered protocol family 10
[    2.922000] Mobile IPv6
[    2.922000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.922000] IPv6 over IPv4 tunneling driver
[    2.924000] NET: Registered protocol family 17
[    2.924000] NET: Registered protocol family 15
[    2.924000] can: controller area network core (rev 20090105 abi 8)
[    2.924000] NET: Registered protocol family 29
[    2.924000] can: raw protocol (rev 20090105)
[    2.924000] Bluetooth: RFCOMM TTY layer initialized
[    2.924000] Bluetooth: RFCOMM socket layer initialized
[    2.924000] Bluetooth: RFCOMM ver 1.11
[    2.924000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.924000] Bluetooth: BNEP filters: protocol multicast
[    2.924000] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    2.925000] NET: Registered protocol family 35
[    2.925000] lib80211: common routines for IEEE802.11 drivers
[    2.925000] Registering the dns_resolver key type
[    2.925000] Registering SWP/SWPB emulation handler
[    2.930000] otg_wakelock_init: No USB transceiver found
[    2.931000] rtc-rx8010 1-0032: hctosys: unable to read the hardware clock
[    2.931000] TMU: register adc.2 to hwmon
[    2.931000] ALSA device list:
[    2.931000]   #0: I2S-WM8960
[    2.931000]   #1: SPDIF-Transciever
[    2.944000] mmc_host mmc2: Bus speed (slot 0) = 25000000Hz (slot req 200000Hz
, actual 198412HZ div = 63)
[    2.993000] mmc_host mmc2: Bus speed (slot 0) = 25000000Hz (slot req 100000Hz
, actual 100000HZ div = 125)
?[    3.428000] hub 1-1:1.0: USB hub found
[    3.431000] hub 1-1:1.0: 4 ports detected
[    3.438000] EXT4-fs (mmcblk0p2): recovery complete
[    3.443000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O
pts: (null)
[    3.451000] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.458000] devtmpfs: error mounting -2
[    3.462000] Freeing init memory: 212K
[    3.466000] Write protecting the kernel text section 80008000 - 80808000
[    3.473000] rodata_test: attempting to write to read-only section:
[    3.479000] write to read-only section trapped, success
[    3.487000] Kernel panic - not syncing: No init found.  Try passing init= opt
ion to kernel. See Linux Documentation/init.txt for guidance.
[    3.500000] [<80014ac8>] (unwind_backtrace+0x0/0x138) from [<805defb0>] (pani
c+0x8c/0x1e0)
[    3.508000] [<805defb0>] (panic+0x8c/0x1e0) from [<805de31c>] (init_post+0xa8
/0xcc)
[    3.516000] [<805de31c>] (init_post+0xa8/0xcc) from [<8083a9e4>] (kernel_init
+0x184/0x1c0)
[    3.524000] CPU1: stopping
[    3.524000] [<80014ac8>] (unwind_backtrace+0x0/0x138) from [<800138fc>] (hand
le_IPI+0x1a8/0x1e0)
[    3.524000] [<800138fc>] (handle_IPI+0x1a8/0x1e0) from [<80008558>] (gic_hand
le_irq+0x50/0x58)
[    3.524000] [<80008558>] (gic_handle_irq+0x50/0x58) from [<8000e900>] (__irq_
svc+0x40/0x70)
[    3.524000] Exception stack(0xb0067f88 to 0xb0067fd0)
[    3.524000] 7f80:                   ffffffed 00000001 00a6a000 00000000 b0066
000 b0066000
[    3.524000] 7fa0: 808efb88 805ebe74 b0066000 413fc090 808920f0 00000000 00000
019 b0067fd0
[    3.524000] 7fc0: 8000f888 8000f88c 60000113 ffffffff
[    3.524000] [<8000e900>] (__irq_svc+0x40/0x70) from [<8000f88c>] (default_idl
e+0x28/0x30)
[    3.524000] [<8000f88c>] (default_idle+0x28/0x30) from [<8000fc2c>] (cpu_idle
+0xc8/0x104)
[    3.524000] [<8000fc2c>] (cpu_idle+0xc8/0x104) from [<40008168>] (0x40008168)
[    3.524000] CPU2: stopping
le_IPI+0x1a8/0x1e0)
le_irq+0x50/0x58)
svc+0x40/0x70)
[    3.524000] Exception stack(0xb0097f88 to 0xb0097fd0)
[    3.524000] 7f80:                   ffffffed 00000002 00a72000 00000000 b0096
000 b0096000
[    3.524000] 7fa0: 808efb88 805ebe74 b0096000 413fc090 808920f0 00000000 00000
019 b0097fd0
[    3.524000] 7fc0: 8000f888 8000f88c 60000013 ffffffff
e+0x28/0x30)
+0xc8/0x104)
[    3.524000] CPU0: stopping
le_IPI+0x1a8/0x1e0)
le_irq+0x50/0x58)
svc+0x40/0x70)
[    3.524000] Exception stack(0x80871f60 to 0x80871fa8)
[    3.524000] 1f60: ffffffed 00000000 00a62000 00000000 80870000 80870000 808ef
b88 805ebe74
[    3.524000] 1f80: 80870000 413fc090 808920f0 00000000 00000019 80871fa8 8000f
888 8000f88c
[    3.524000] 1fa0: 60000013 ffffffff
e+0x28/0x30)
+0xc8/0x104)
[    3.524000] [<8000fc2c>] (cpu_idle+0xc8/0x104) from [<8083a800>] (start_kerne
l+0x2f4/0x354)
[    3.524000] Rebooting in 5 seconds..
Forlinx-Niuzc 发表于 2020-2-3 14:07:26 | 显示全部楼层
用的是原资料的镜像替换logo相关文件烧写的吗
Forlinx-Niuzc 发表于 2020-2-4 14:46:23 | 显示全部楼层
之前做的boot.img是Linux的,Android修改logo按照手册上4.2节的方法应该不会出错,您可以检查下是否是修改了其他的内容
XX18通行证
楼主| YCG2018 发表于 2020-2-6 17:32:59 | 显示全部楼层
你好,我是按照手册上的方法编译的,但编译后的Boot.img只有13M大小,而原始的Boot.img是23M左右,没搞明白大小不一样的原因,当然,下载进去也不好用
Forlinx-Niuzc 发表于 2020-2-7 09:46:23 | 显示全部楼层
您先试试我们提供的镜像烧写是否有问题,再试试用我们提供的源码不修改进行编译烧写后是否有问题,看看是否是编译过程出的问题
