查看: 4551|回复: 1
[Linux] qt debug时 出现下列错误是怎么解决
Great_007 发表于 2020-2-13 12:18:36 | 显示全部楼层 |阅读模式
Starting /root/helloQTT/helloQTT...
Failed to start program. Path or permissions wrong?
/root/helloQTT/helloQTT exited with code -1
The debugger engine 'LLDB engine' is disabled.
There is no gdb binary available for binaries in format 'arm-linux-generic-elf-32bit'
Forlinx-Niuzc 发表于 2020-2-13 14:56:32 | 显示全部楼层
因为还没开始正常上班,暂时无法确定问题出在哪,可以在正常上班后帮您查看吗
您可以仔细参考qt相关的资料手册,先自己看看操作上是否有问题
