查看: 60326|回复: 1
[Linux] ov5640摄像头测试
i.MX6Q通行证
feiyang90 发表于 2020-2-20 14:22:49 | 显示全部楼层 |阅读模式
imx6q开发板ov5640摄像头测试运行得linux4.1.15版本,
上电后得log打印显示:ov5640_read error,ov5640_mipi is not found,摄像头已经连接好了,为啥出现打印错误了
[    2.210902] IR XMP protocol handler initialized
[    2.244781] hub 1-1:1.0: USB hub found
[    2.248725] hub 1-1:1.0: 4 ports detected
[    2.333594] camera ov5640 is found
[    2.523793] ov5640_read_reg:write reg error:reg=300a
[    2.528768] camera ov5640_mipi is not found
[    2.533594] usb 1-1.3: new high-speed USB device number 3 using ci_hdrc
[    2.540291] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
[    2.547157] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
[    2.554184] usbcore: registered new inte**ce driver uvcvideo
[    2.559939] USB Video Class driver (1.1.1)
Forlinx-Niuzc 发表于 2020-2-20 15:37:59 | 显示全部楼层
ov5640_mipi是mipi摄像头,和ov5640不一样
