查看: 29515|回复: 1
[Android] 无法获取root权限
i.MX8MM通行证
hyxzyx1588 发表于 2020-5-2 09:05:26 | 显示全部楼层 |阅读模式
需求:获取root权限
操作:
1.>>adb remount
Use "adb disable-verity" to disable verity.
If you do not, remount may succeed, however, you will still not be able to write to these volumes.
2.>>adb disable-verity
Device is locked. Please unlock the device first
3.>>开发者选项打开OEM unlocking选项
4.>>adb reboot bootloader
5.>>fastboot flashing unlock
< waiting for any device >
然后一直就卡在这。。。
获取root权限是否有其他特殊方法,请说明,谢谢。
xhh 发表于 2020-5-6 16:31:13 | 显示全部楼层
您可以和您负责的销售沟通一下,给他说一下您需要8MM的root方法,然后让他帮您管负责8MM的技术服务人员要即可
