查看: 49362|回复: 1
[Linux] 启动音乐播放器软件报错
A40i\T3\T507\T527通行证i.MX8MM通行证
Yzp 发表于 2020-5-18 19:55:30 | 显示全部楼层 |阅读模式
使用开发板提供的QT音乐播放器后,串口输出如下的错误信息:
[  291.015190] imx-micfil sound-micfil: imx_micfil_hw_params: failed to set cpu sysclk: -22
[  291.023299] imx-micfil sound-micfil: ASoC: machine hw_params failed: -22
[  291.030119] fsl-micfil-dai 30080000.micfil: failed to find a suitable clock source
[  291.037714] fsl-micfil-dai 30080000.micfil: failed to set mclk[45158400] to rate 48000
[  291.045649] imx-micfil sound-micfil: imx_micfil_hw_params: failed to set cpu sysclk: -22
[  291.053758] imx-micfil sound-micfil: ASoC: machine hw_params failed: -22
[  291.060558] fsl-micfil-dai 30080000.micfil: failed to find a suitable clock source
[  291.068151] fsl-micfil-dai 30080000.micfil: failed to set mclk[45158400] to rate 48000
[  291.076088] imx-micfil sound-micfil: imx_micfil_hw_params: failed to set cpu sysclk: -22
[  291.084197] imx-micfil sound-micfil: ASoC: machine hw_params failed: -22
请求帮助。。。
难死了的猫崽仔 发表于 2020-6-10 16:56:21 | 显示全部楼层
您好 首先您播放我们提供的/home/forlinx/audo/test.mp3也是这个报错吗?然后您可以再用命令行播放一下试一下,先排除是不是一下硬件方面的问题
