查看: 61318|回复: 3
[Linux] linux4.1.15内核编译
A40i\T3\T507\T527通行证i.MX6UL通行证
GDWY_SH 发表于 2020-6-16 17:20:59 | 显示全部楼层 |阅读模式
采用飞凌提供的4.1.15源码无修改,直接编译,然后将arch/arm/下的zImage文件和arch/arm/boot/dts下的imx6ul-14x14-evk-gpmi-c-256m-xx-xx.dtb文件(共8个)拷贝到mfgtools\Profiles\Linux\OS Firmware\files中对应位置,然后OTG烧写,烧写完成后启动失败
VFS: Cannot open root device "mtdblock5" or unknown-block(31,5): error -19
Please append a correct "root=" boot option; here are the available partitions:
0100           65536 ram0  (driver?)
0101           65536 ram1  (driver?)
0102           65536 ram2  (driver?)
0103           65536 ram3  (driver?)
0104           65536 ram4  (driver?)
0105           65536 ram5  (driver?)
0106           65536 ram6  (driver?)
0107           65536 ram7  (driver?)
0108           65536 ram8  (driver?)
0109           65536 ram9  (driver?)
010a           65536 ram10  (driver?)
010b           65536 ram11  (driver?)
010c           65536 ram12  (driver?)
010d           65536 ram13  (driver?)
010e           65536 ram14  (driver?)
010f           65536 ram15  (driver?)
1f00            4096 mtdblock0  (driver?)
1f01            2048 mtdblock1  (driver?)
1f02            1024 mtdblock2  (driver?)
1f03            3072 mtdblock3  (driver?)
1f04            8192 mtdblock4  (driver?)
1f05          243712 mtdblock5  (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,5)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,5)
random: nonblocking pool is initialized
请问使用linux源码需要修改什么吗
Forlinx-Niuzc 发表于 2020-6-16 18:02:17 | 显示全部楼层
应该是mfgtools\Profiles\Linux\OS Firmware\files\linux路径下,您的路径有问题
点评回复 支持 0 反对 1
楼主| GDWY_SH 发表于 2020-6-16 21:32:59 | 显示全部楼层
路径没有错,因为设备树文件和编译出来的zImage不在一个目录所以没有分别列出,不然烧写也不会成功对吧,关键式烧写完成后断电从NAND启动时,就出问题了。我想请问一下你们资料包中给出的源码压缩包解压后能否直接编译,或者需要修改文件才能使用,没有任何手册有描述
Forlinx-Niuzc 发表于 2020-6-17 08:37:43 | 显示全部楼层
源码解压后能直接编译,详细过程可查看OKMX6UL-C_Qt5.6+linux4.1.15软件手册      第四章
